Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-29-2009, 09:24 AM   #1
? about pcv valves and boost
i currently have my pcv valve plugged up and i put a small breather filter in the front valve cover, i was wondering what you boosted guys do with your pcv valves? i was planning on putting a oil catch can, what do you guys think about oil catch cans? i'm getting alot of smoke coming out the front valve cover where the breather filter is.
__________________
eat......sleep.......boost
chino86 is offline   Reply With Quote
Old 06-29-2009, 10:28 PM   #2
KH3 by popular demand
maxgtr2000's Avatar
Send a message via Yahoo to maxgtr2000
Why do you have the valve plugged? All I did was put the breather filter on and that was it on my set up. If you are getting blowby then you need a catch can.
__________________
Retrofit headlight services
My VQ30DET
Emanage Blue and Ultimate Forums
There can be no peace until you possess the Prince of Peace.
maxgtr2000 is offline   Reply With Quote
Old 06-30-2009, 06:26 AM   #3
the guy that did my setup told me i should plug up the pcv valve, i cant find any info on pcv valves with boosted setups . i was thinking since our cars have a pcv valve that just sits on the valve cover with no threads its possible that it can pop off under high boost like 15+ lbs
__________________
Old 06-30-2009, 08:24 AM   #4
'Trynna' is not a word
mtrai760's Avatar
You need a PCV valve. It should not be plugged.
__________________
98 SE - VQ35
2k SE - Stock... pretty much
Boost, juice, conversions, been there, done that.
mtrai760 is offline   Reply With Quote
Old 06-30-2009, 12:52 PM   #5
Send a message via AIM to streetzlegend Send a message via Yahoo to streetzlegend
Here are your two options with PCV. You can hook it up like stock into the intake manifold and put a filter on the front valve cover.
Or
You can leave the pcv open (no hose on it) and also leave the front valve cover open (with a breather), basically you will have the crank case vented, you will see a little amount of smoke come out, which is acceptable up to a point (now once u close the hood and u see smoke coming out still then u in trouble lol aka bad rings probably)
pro's and co's
the first way, while normal driving, not in boost, the vacum from the manifold will be pulling air in from the PCV, that air will contain the blowby smoke along with fresh air thats being sucked in from the front valve cover (since both covers are connected with a hose towards the timing cover), most of the time this is good because emmissions, you burn up the blowby in combustion, etc... also the con about this is that, it will be sucking in oil as well (that smoke is basically vapors that have oil, when it condenses you will get oil), here is where you need the catch can so it can condense inside the can and not let oil go into ur manifold (might still let oil go in but alot less), During boost, the manifold will develope positive pressure which will keep the pcv system from working, and at this point it will let out the blowby through the breather you have in the front (a possibility is that the crank case's pressure might actually be higher than your boost and therefore it will still be going into the manifold).
the easy way out, do it the second way, u dont have to deal with catch can, or pcv leaking while in boost, etc.., the bad part is that the vapors coming out or the smoke you see, STINKS and WILL get annoying, specially if you pick up your wife/girlfriend and she complains about her hair smelling like oil after u get out the car lol.
for both options, you have to look at your tune, because having pcv hooked up is basically like having a vacum leak (since its pulling unmeasured air from the valvecover/crankcase), disconnecting pcv system will make it rich. these both apply for (not in boost) condition.
BTW, im speaking from experience on this. I went with having it vented, less head ache and the smell is manageable (you can run hoses from valve cover to the back of car or figure something out). If yo u decide to go with vented way. I suggest you take off the hose that connects both valve covers, or if you want, cut it in the middle, put a T and put another filter there. This way when your in boost the crankcase(valvecovers) will let out vapors and blowby as quick as possible, the less pressure in there the better.
Hope this helps, its probably sticky material if a mod is reading this.
__________________
Streetz goes into the 11's!!!
440CC RC injectors for sale, $220 Shipped. PM ME
streetzlegend is offline   Reply With Quote
Old 06-30-2009, 07:14 PM   #6
i have it vented with the vacumm line to the pcv valve plugged up. i 've been driving my car like this for over a year now but my breather filter gets oil on it and starts dripping oil little by little. the smoke is not noticeable unless the hood is open and the smell i've gotten use to lol. i'll try putting another breather filter by the other hose that connects the two valve covers and see if this helps. thanks for the feedback
__________________
Old 06-30-2009, 09:43 PM   #7
Quote:
no problem, yea thats the best bet, try to have as many openings as possible if you have it vented, that way it releases the vapors quick and dosnt build up too much pressure in the crankcase.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
