Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-28-2009, 05:55 PM   #1
Compressed Air for boost
Ok so i was talking to my grandpa the other day while working on his small block about boost.... Need for lower compression etc etc
Then he told me about a guy who designed and built a drag car that used compressed air for boost instead of blower, supercharger, turbo, etc....
Nowadays drags cars must be rebuilt after every run because of extreme heat. The guy who built the car ran 20some runs on the dyno and absolutely nothing wrong with the engine...yet he ran the same hp as the other guys whose engine needed to be rebuilt every time..
I was just wondering if anyone has heard of this or has experimented with it...Or if anyone would know how this works
Just a thought i had thanks
__________________
youtube username= pntball99
Quote:
Originally Posted by mantis40 View Post
Well this happen to me, my 98 i30t was going very slow compared to normal and my rpms wouldnt pass 4500rpm (i have an auto). Turns out my floor mat was stuck under the pedal.
95Maxima719 is offline   Reply With Quote
Old 06-29-2009, 09:39 AM   #2
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
never heard of it. the logic is fairly sound - what ever way you get more oxygen into the engine will work, the implementation of it especially in a street car would be problematic to say the least though.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 06-29-2009, 11:19 PM   #3
you wouldn't use compressed air if you had the option of nitrous,
i've done the maths on this as well. and a 55lt (13 gallons?) bottle would give you 7psi for approx 5 seconds at 6000rpm if you pressurised to 100psi. compaired to a 10lb bottle being able to give you a 100shot (7psi equivelent in our engines) for about 30seconds?
In conclusion it would work, but not as well as you would hope
__________________
mywhitewolf is offline   Reply With Quote
Old 06-29-2009, 11:40 PM   #4
I don't see how compressing the air differently would have a major effect on motor reliability. If you're getting 7psi of boost from a turbo, or 7psi of boost from a supercharger, or 7psi of boost from a compressed air tank, or 7psi of boost from a very large elephant sneezing into your motor, wouldn't it be pretty much the same effect on power (neglecting parasitic loss) and engine durability?
__________________
*nalc
97 Maxima SE 5MT - Neptune Blue
R34 Quad Projectors - M35/MDX
nalc is offline   Reply With Quote
Old 07-06-2009, 04:53 PM   #5
Fravor of da monf yo!
XeroX's Avatar
Send a message via AIM to XeroX
Im assuming since the compressed air is isolated and not introduced to heat like the compressed air from a turbo...that maybe this would be better? But then again u get a similar effect with an FMIC...so i think the idea of it being more reliable or anything better than a turbo setup is invalid...unless you want to start thinking about points of failure...then there is nothing really to worry about...other than the container and whatever method of valves you have to introduce it to the engine...in essence there are no moving parts...just like an n2o setup...
On the other hand, it is probably alot cheaper than a turbo setup or filling up nitrous bottles...
I think the idea only gets browny points for creativity rather than efficiency
XeroX is offline   Reply With Quote
Old 07-07-2009, 02:58 PM   #6
choray911's Avatar
I fail to understand how it could increase power. With NO2 you are injecting 2 oxygen molecules attached to a nitrogen molecule. You are saturating the incoming air with additional oxygen and at the same time freezing the incoming air, hence the power. If you are just using compressed air, there is no saturation of oxygen, the make up of the air is the same. Additionally, there would be no increase of manifold pressure unless you were to block off the throttle body and force the compressed air into the cylinders rather than it exiting through the path of least resistance (throttle body).
I'm not saying its impossible, but it is improbable
__________________
'96 black Se, 5spd, T04E turbo, Spearco FMIC, Tial 38mm waste gate, HKS SSBOV, Deachwerks 570 injectors, GReddy E-manage Blue, Sard FPR, Stillen Flywheel, XTD 6 puck kevlar clutch, Zeitronix WBO2 TSW Laguna wheels, Z32 brakes, K-Sport Coilovers 84' 300ZX hood scoop, blacked turn signals, and tails.
choray911 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
