Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-23-2009, 07:41 AM   #1
Super Moderator
JAY25's Avatar
Send a message via AIM to JAY25
How to install oil cooler
I posted the simple instructions on the bottom of this thread. Pictures are nice and clear enjoy. Yes I am SCing a maxima, is not my maxima. Scroll all the way down. Please dont post on there leave it as a info post thanks!
Jaime
Supercharger facts. directions, part numbers, belts etcc
scroll down for anyone who wants to install that motivating cooler on their boosted maximas
__________________
www.titanstaffords.com yes that is my new hobby now
JAY25 is offline   Reply With Quote
Old 06-23-2009, 08:17 AM   #2
You can't friend yourself
Kevlo911's Avatar
Do you know if we can just buy the sandwich plate? I already have my old tranny cooler on the car(from when I was auto). I think I can just use that as the oil cooler when I go boost.
__________________
97 Pearl White Max GLE
I has car
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 06-23-2009, 08:36 AM   #3
'Trynna' is not a word
mtrai760's Avatar
Quote:
This is the one that Jay used: http://www.racerpartswholesale.com/p...andwich_Plates
You probably don't need this in FLORida, but I'm using: http://www.racerpartswholesale.com/p...Sandwich_Plate
__________________
98 SE - VQ35
2k SE - Stock... pretty much
Boost, juice, conversions, been there, done that.
mtrai760 is offline   Reply With Quote
Old 06-23-2009, 08:46 AM   #4
Kevlo911's Avatar
Ha that's too big and expensive.
Im surprised most people don't have oil coolers, oil keeps the engine temps down and is just as important as upgrading the coolant/radiator.
__________________
I has car
Old 06-23-2009, 09:10 AM   #5
Send a message via AIM to streetzlegend Send a message via Yahoo to streetzlegend
Another alternative, similar to the post on the SC thread is that you can a sandwhich plate, like the one youll be getting to use as feed for the turbo (those like mine, have like 4 ports on them), so you basically run a line from one port into a cooler, then return it to the oil pan(even the lower oil pan since the pressure will force it to get in and no gravity issues)
__________________
Streetz goes into the 11's!!!
440CC RC injectors for sale, $220 Shipped. PM ME
streetzlegend is offline   Reply With Quote
Old 06-23-2009, 09:11 AM   #6
mtrai760's Avatar
The first one is cheap, and you likely won't need the thermostat anyway. I however, get snow and since it's my daily, I need the thermostat for year round driving. I was just throwing it in there since I had to look up the other one for ya anyway
Come on now Kev, you have been around long enough to know that most people do the bare minimum. An oil cooler? They want to run a stock clutch and fuel system and use a 2.XX pulley and have everything work perfect!
__________________
98 SE - VQ35
Old 06-23-2009, 09:15 AM   #7
mtrai760's Avatar
They also have cheap, quality oil coolers, if you decide not to reuse what you have already: http://www.racerpartswholesale.com/c...ol_Oil_Coolers
__________________
98 SE - VQ35
Old 06-23-2009, 10:00 AM   #8
Kevlo911's Avatar
They are all pretty much built the same, my hayden is a decent size so I will prob run that with about 4.5 quarts of oil
Oil coolers are cheap insurance.
__________________
I has car
Old 06-23-2009, 10:21 AM   #9
Super Moderator
JAY25's Avatar
this is a easy install, some people may have no clue. I had no clue of nothing way back in 98 when I bought my new maxima. I went to auto tech school in California. Hope this helps you guys and any one else that wants to add a cooler.
You can buy a sandwich from any company, jegs, summit whomever. Just use some permatex grey or black on your threads. It will seal and lock at high temperatures. It really dont matter which one you use. If your picky your permatex grey. Thats what most Japaneese cars use!
__________________
Old 06-23-2009, 01:43 PM   #10
Well Kev for your low boost realistically your not going to need a cooler, but like everyone says, you WILL increase the boost real soon so it might be good idea to use one. In my case I am not sure if im going to be adding how, however I will be using 15w50 oil for the added protection since thicker is good for higher heat range.
I say you do it the way I say, since your already going to be buying a sandwhich plate (the an ebay one, dont spend more than 50 on it), you just need to add more oil for both the turbo and the cooler. so probablly end up putting like 6qt, I run about 5.5qt without a cooler right now.
__________________
Old 06-23-2009, 01:45 PM   #11
Kevlo911's Avatar
Yeah, I figure for like 20 bucks plus hoses it is not a bad idea. I will be going higher boost eventually so I might as well do it whenever I can
But you should def do it!
__________________
I has car
Old 06-23-2009, 02:36 PM   #12
This is the plate i have been using for years on my turbo max, i have a sending unit for my gauge, the feed for the turbo, and soon im going to add a feed for the cooler and return to lower oil pan.
http://cgi.ebay.com/SANDWICH-PLATE-O...3%3A1|294%3A50
__________________
Old 06-24-2009, 01:48 PM   #13
Licensed to Spell
ptatohed's Avatar
Quote:
Jaime
Jaime, you stated "It really works, I have attached a oil temp gauge to monitor the temps when I was turboed/SCed and you wont believe how hot that oil can get. This little cooler will drop your temps by alot.".
One, there is no such word as "alot" , but two, could you please provide the actual temperature reduction you observed? I installed a cooler a few years ago but I don't know my actual temperature drop, as I do not have a gauge. Thanks!
This is the cooler I have:
Here is a link to my photobucket full of pictures taken during my install.
__________________
Cleaning up the .org's grammar, one member at a time.
1999 SE, Pearl White/Black leather - Fully loaded with all factory options except TC (ABS, heated seats, side airbags, etc.) - Supercharged (322 HP / 307 TQ)
1996 GLE, Pearl/Black - Superchargerless
1993 SHO, Pearl White/Gray - Stock
Super Charger install instructions
ptatohed is offline   Reply With Quote
Old 06-24-2009, 06:18 PM   #14
Super Moderator
JAY25's Avatar
I can not give you specific temperatures. I remember for a fact it dropped the temperature by 30-40 degrees Celsius.
Jaime
__________________
Old 06-25-2009, 05:41 PM   #15
Licensed to Spell
ptatohed's Avatar
Jaime
Celsius?
30-40^ is a good drop.
Thanks.
__________________
Old 06-26-2009, 11:24 AM   #16
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
Any of you guys ever actually observe oil temps in a VQ before? My oil temps are pretty weird in my NA VQ35, seems to defy logic some times...
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 06-26-2009, 02:37 PM   #17
Quote:
What temps are you seeing during normal driving conditions, and during aggressive driving?
__________________
Old 06-27-2009, 08:56 AM   #18
SLOW
Nealoc187's Avatar
Depends on how hot it is outside and the speed at which I'm driving. Keep in mind this is without any oil cooler, not even the stock VQ35 one that sandwiches by the oil filter and has coolant running through it, I removed that.
This is what I seem to be noticing, try to bear with me as it may be a bit confusing because like I said they seem to be all over the place under different conditions.
If the temp is mild like 75 or below, all highway cruising (all speeds, from 65-85mph) I usually see like 185-195 steady. surface street cruising 35-45mph will stay steady at those temps too, as will idle temps stopped at stoplights for a few minutes. no noticeable fluctuations.
Warmer temps, 80s, I can end up seeing 205-210 cruising on the highway if I'm above 75mph. If I'm going slower like 65-70mph it will be more around 200 . When moving on surface streets like 30 or 40mph it will stay around 205, but if I come to a complete stop at a stop light it will start to creep up as long as I am stationary. Could creep into the 215-220 range.
Hot temps in the low 90s it will creep a bit on the highway at speed, but the faster I go the faster the temp goes up, this is highway speeds I'm talking about - but I haven't done any long trips at this outside temperature to see how high it would end up going. cruising at like 70mph I've seen as high as 215 and slowly climbing. cruising at 80mph I've seen as high as 220 and slowly climbing - this was after driving at that speed for like 30 minutes. surface street speeds like 30-45mph cool it down into the 205-210 range. BUT if I come to a complete stop it will start to go up pretty well I've seen as high as 225 stopped at a stop light for only a couple minutes. Once I start moving again it will start to go down into the 210 range.
Really hot like 100 degrees (we had two of these days earlier this week) I saw as high as 232F and still climbing in a 25 minute drive on the freeway at 75-80mph cruising at like 70mph was about 225F. On surface streets I was seeing 215 cruising at 35-45mph. At stop lights it would really go up I saw as high as 233F and climbing fairly rapidly at one stop light right after I got off the freeway (when I coast the car down in neutral on the off ramp, the temp drops like 10 degrees from whatever it was at while cruising on the highway at speed, and then will start climbing again once I stop). I'm curious to see how high it would have gone had I kept idling.
I don't drive the car hard on the street but I have driven it on the road course in like 85 degree heat and I saw as high as 265 which is high but I run synthetic diesel oil which is the most protective oil you can buy by a large margin, so I'm not worried too much about those temps. I will be installing an oil cooler before I do any track days with a turbo installed though.
At the drag strip oil temps are not out of the normal range though I have never hot lapped this car at the drag strip since I've had the oil temp gauge installed.
__________________
Old 06-27-2009, 10:56 AM   #19
Damn thats crazy, what im wondering is, for oil temps what is considered to be too high? also if there are no coolers installed I wonder why outside temps make such an impact on the oil temp.
btw thanx for sharing ur observation.
__________________
Old 06-27-2009, 03:25 PM   #20
SLOW
Nealoc187's Avatar
well I've been doing some reading and been told by people that 50-60 degrees above coolant temp is not abnormal under racing conditions. oil temps seem very subjective i've seen some people on forums say they don't like seeing higher than 220 deg while lapping and others saying they are fine with theirs at 270 lol so there's a big margin.
__________________
Old 06-27-2009, 06:04 PM   #21
Super Moderator
JAY25's Avatar
I dont have a oil gauge hooked up to my 94 Honda civic Hatchback. The Vtec engines have coolant lines to the oil filter just like the 3.5 VQ Engines. I was pretty surprised to see that. Then again that may explain why those engines last very long time. I have 370,000 miles on that Honda civic. I purchased it with 270,000 miles. Still going very strong. One more thing I also noticed with this civic is the oil is not jet black at 3000 miles like the nissan 3.0 VQ engines. I am not using synthetic either. Its just a gas saver to get me from point a to b. Does have a alloy flywheel. I must have that for quick revs.
__________________
Old 06-27-2009, 08:13 PM   #22
wat
AceofSpds's Avatar
Send a message via AIM to AceofSpds
you guys think -6AN would be a bit too much on the small side?
__________________
00' Maxima
95' 240sx
AceofSpds is offline   Reply With Quote
Old 06-27-2009, 09:46 PM   #23
Super Moderator
JAY25's Avatar
Quote:
8 or 10 would be better, regular line is 10!
__________________
Old 07-14-2009, 11:45 PM   #24
You guys think its safe to stack two sand which plates together? Reason I ask is because the permacool sandwhich plate does not bring additional ports (for example turbo feed or sending unit for gauge), so I was thinking leaving my current one (that i posted above) and putting the permacool plate on top of it. what ya'll think??
OR, the other option is to get a plate that has ports for turbo and sender, and also big ports for cooler like this one:
If stacking is no issue, then id def go with that instead!
__________________
Old 07-15-2009, 12:27 AM   #25
Well I answered my own question, over at the Z forum this guy did a HowTo writeup on his oil cooler, and he stacked up the coolers plate, ontop of the plate for the turbo/sending unit, and then on top of the stock cooler (so 3 plates)
Looks like i'll be ordering the permacool kit.
Old 07-20-2009, 11:57 AM   #26
Wild for Width
Fr33way™'s Avatar
Send a message via AIM to Fr33way™
Would there any concerns with overcooling on a bolt-on N/A VQ? I lap the car occasionally at Road Atlanta but it's primarily a DD.
__________________
Fr33way™ is offline   Reply With Quote
Old 07-20-2009, 12:06 PM   #27
Kevlo911's Avatar
Shouldn't be since you push it
__________________
I has car
Old 07-20-2009, 03:47 PM   #28
Super Moderator
Send a message via AIM to nismology
Quote:
Yep unless the sandwich plate you use has a built-in t-stat or you implement some other type of thermostatic control.
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
nismology is offline   Reply With Quote
Old 07-21-2009, 09:20 AM   #29
Send a message via AIM to 95BLKMAX
keep us posted streetz!
__________________
Guys I need money to recover from my recent engine build (it wasnt by choice LOL). Im selling a Holset turbo if you are interested
95BLKMAX is offline   Reply With Quote
Old 08-04-2009, 05:38 PM   #30
drunkiethepanda is offline   Reply With Quote
Old 08-04-2009, 07:37 PM   #31
Quote:
Originally Posted by drunkiethepanda View Post
k dude, enough with the post whorng
__________________
Old 08-04-2009, 07:37 PM   #32
So I installed the kit above, i love it, although I dont have a way to monitor the oil temp but the installation went smooth. At least now I have a peace of mind.
Here are pics installed:
Old 08-04-2009, 07:55 PM   #33
guys just wondering may be a really stupid question. but how many rows should the oil cooler have. the larger the better im guessing but how my rows are on you guys oil cooler?
BkGreen97 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
