Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-15-2009, 11:23 PM   #1
Turbo Install Few More Weeks
Piecing together a turbo kit. But I have a few questions.
I'm gonna be running 370cc injectors, apexi neo, afpr, and z32 maf, walboro hp fuel pump,
but what size fmu?
Im looking to be a reliable daily driver on no more than 8 pounds of boost. Starting at 5 pounds.
BkGreen97 is offline   Reply With Quote
Old 05-15-2009, 11:34 PM   #2
Send a message via Yahoo to STILLENGLE
max boost on these cars is 8-9 psi.
what size turbo are you gonna be running?
Id run anything between 440-650CC injectors.
what are you using for tuning?
__________________
Take it to the Max!
STILLENGLE is offline   Reply With Quote
Old 05-16-2009, 05:26 AM   #3
Shift_Broken Tranny
at 5lbs you will not need a fmu
__________________
My Cardomain _ _Maxima runs 13.4@109
Dyno:? whp & ? wtq
Nitrous PB: 13.4@110mph
All Motor PB: 14.0@99mph
3280lb with driver, full trim, rims, spare, jack, fluids, etc & notorized proof
t6378tp is offline   Reply With Quote
Old 05-16-2009, 10:18 AM   #4
Where did you hear this? There are many cars running more than 10 psi on stock internals. its all dependant on turbo anyways.
Those injectors are overboard for anything less than 350 whp and i doubt he will hit those numbers with 8 psi on anything smaller than a gt35r.
Carlos is offline   Reply With Quote
Old 05-16-2009, 10:52 AM   #5
KH3 by popular demand
maxgtr2000's Avatar
Send a message via Yahoo to maxgtr2000
I'm running an average of 8 lbs now with a similar setup on my daily driver:
370cc
Stock maf
Emanage Blue with all harnesses and map sensor
Walbro 255lph
Don't forget the one step colder plugs though.
__________________
Retrofit headlight services
My VQ30DET
Emanage Blue and Ultimate Forums
There can be no peace until you possess the Prince of Peace.
maxgtr2000 is offline   Reply With Quote
Old 05-16-2009, 11:14 AM   #6
10 psi on stock internals is pushing it. Its a little over kill but your running a risk even with running 8-9 Psi on a 35R with these cars, unless your engine is fully built it wouldn't matter what you throw at it.
Read the turbo stickies and you"ll see what I am talking about. I am not saying your totally wrong but if you read the beginning of the Turbo FAQ they say that its just safer to run 8-9 PSI with 450-650CC injectors. Your compression maybe slightly slower as well.
__________________
Take it to the Max!
Old 05-16-2009, 11:15 AM   #7
Quote:
370cc
Stock maf
Walbro 255lph
what size turbo you running? 30R or 35R.
__________________
Take it to the Max!
Old 05-16-2009, 11:58 AM   #8
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
Psi means nothing. I have ran 25psi on a stock block with a Turbonetics 60-1. What you need to find out is what the cfm rating of that turbo you are going to run is at the boost pressure. I find it funny when i hear people saying our cars can only handle 8psi. People you have to remember that PSI MEANS nothing. You want to know the flow rate of the turbo. With that said. wat turbo man?
Feel free to call me bro i can still help ya out lol.
__________________
97 SE Auto Built Auto
97 SE Holset HX52|N2O|6 SP|Built 3.56|More to come
91 GXE Auto bone stock beater
91 GXE 5sp Another beater
Led retro's Pm me
kzoosho is offline   Reply With Quote
Old 05-16-2009, 03:30 PM   #9
Apexi Neo for Tuning. I know many people that have gone beyond 10 psi. T4 Holset Back Split Exhaust Housing . 84/a/r/ garret compressor .70 a/r
Quote:
What about for 8 pounds?
I'll hit u up i keep forgetting.
Old 05-16-2009, 07:24 PM   #10
Shift_Broken Tranny
Quote:
nope just up the fuel psi and retune with the neo, btw is this a 3.5 or 3.0
if it's a 3.5 nope, 3.0 your pushing
__________________
Dyno:? whp & ? wtq
Old 05-16-2009, 07:27 PM   #11
3.0 for now
Old 05-16-2009, 07:39 PM   #12
maxgtr2000's Avatar
8 lbs is not much for a vq30. There are people that run that daily and more with no problems, as long as your tune is good you are ok. The vq30 is very forgiving, trust me, I've been running 8lbs untuned/non dyno tuned (only guess tuned by me) for about a year now. As long as you have the equipment to monitor what's going on, namely wideband. I'm partial to the stuff I have because I log afr, psi, rpms and egts and can pull timing. There are quite a few turbo max owners that tune the car themselves, just educate your self, search, and read especially I30TMikeD threads.
__________________
My VQ30DET
Old 05-16-2009, 07:52 PM   #13
well said i havent heard to many horror stories of with a 3.0 blowing up on 8 lbs.
Because you though i got the zeinetronix full kit. egt, boost, connections as well.
Old 05-17-2009, 05:41 AM   #14
Shift_Broken Tranny
Depending on your setup at 8lbs you'll be close to maxing out the 370's and will need to either get a fmu or bigger injector
I am a fan of just getting bigger injectors, I would suggest selling the neo and getting a e-blue they cost the same but you get alot more options
__________________
Dyno:? whp & ? wtq
Old 05-17-2009, 09:59 AM   #15
a great source told me i shoulddddddd be alright with an 8:1 and the 370's. Im planning on getting bigger injectors just now now.
Old 05-17-2009, 12:19 PM   #16
Send a message via AIM to streetzlegend Send a message via Yahoo to streetzlegend
8psi is rather low to be maxing out 370cc's, I was at 15psi on my turbo(t04b) and injectors were still not maxed out with 1:1 fpr.
__________________
Streetz goes into the 11's!!!
440CC RC injectors for sale, $220 Shipped. PM ME
streetzlegend is offline   Reply With Quote
Old 05-17-2009, 12:26 PM   #17
Well seeing that you have a gt40 i would deff do what i said, 370's and the fmu to be safe. U will want to get a good wideband also to monitor your a/f . I would get one that logs.
__________________
Led retro's Pm me
Old 05-17-2009, 04:35 PM   #18
Shift_Broken Tranny
Quote:
but how much hp were you pushing, remember it's not the amount of psi that max's out the injectors it's the power
you can push 40psi but if your only making 300hp then 370's are fine
__________________
Dyno:? whp & ? wtq
Old 05-17-2009, 06:10 PM   #19
My turbo like kzoosho said below is pretty large. gt40 we believe. so im guessing 15 psi on mine would should definetly max them out. im check the flow map on a t04b compared to a gt40.
i got that zeinetronix joint that maxgtr2000 has i think it does datalog.
Your very right same thing kzoosho said. jeeve broke 300 wheel hp on his gt40 with 8 psi i think
Old 05-17-2009, 08:37 PM   #20
The Original CF Maxima
Flava_24/7's Avatar
Are you even boosted?
450cc-600cc for 9psi? Serious overkill, of course its safer being able todeliver so much fuel but its not needed at all.
10psi isnt pushing it if the car is tuned well and has adequate fuel.
Maybe on a motor that has over 200k, then yeah I would think so.
Most of us boosted guys are running stock internals, theres only a small handfull that have built motors.
__________________
Chumps try to imitate but can never duplicate
377hp 338tq
Flava_24/7 is offline   Reply With Quote
Old 05-17-2009, 09:09 PM   #21
Shift_Broken Tranny
yes, he did
I pretty sure he was closer to the 350 range. Depending on how efficient your piping is I think you'll be around 400hp at 14-15psi.
__________________
Dyno:? whp & ? wtq
Old 05-17-2009, 09:55 PM   #22
what would you recommend using 370CC.
And when you say built motor are you talking just pistons and connecting rods with a bored out block with sleeves?
__________________
Take it to the Max!
Old 05-18-2009, 08:05 AM   #23
Flava_24/7's Avatar
If he intends on staying at 8-9psi, stock inj. would work. Of course 370's would be a safe margin. Built meaning upgraded pistions and connecting rods and valvetrain. Boring out the block isnt a have to in order to upgrade the pistons.
__________________
377hp 338tq
Old 05-18-2009, 10:15 AM   #24
350z injectors would work as well right?
__________________
Take it to the Max!
Old 05-18-2009, 09:38 PM   #25
Come on man, not another spoon feed you post. Search please. My next post to you wont be so nice.
__________________
Led retro's Pm me
Old 05-26-2009, 10:23 PM   #26
I've been running 11psi for more than two years on my daily driver with stock injectors. The engine has been boosted for 5 years and 80,000 kms (54,000 mi) without tragedy. My tune is often bad, and my peak FP is 100psi. I destroy clutches, not connecting rods. The stock engine internals and injectors are plenty good for 8-9 psi.
What seems to kill these cars is not the boost.... it's the crashing.
__________________
Visit my Cardomain homepage!
mhadford is offline   Reply With Quote
Old 06-19-2009, 08:27 PM   #27
Have Yet Another Problem
I can't find a vband flange and clamp.
I bought a 4" with 2 flanges and clamp- No Good
I bought a 3.5" with 2 flanges and clamp- No Good
I'm ordering a 3" with 2 flanges and clamp- Maybe
Do any of you guys have with vband downpipes remember what sizes or how you measured to get the right size?
Old 06-20-2009, 10:26 AM   #28
Measure the inside diameter of the turbine outlet.
__________________
Colorado Springs first turbo maxima. <gone
t61 equipped...Should have gone with the to4r
03 t61 350z < current
wunfstmax is offline   Reply With Quote
Old 07-03-2009, 12:11 PM   #29
Update: With Pics To Follow In A Few Days
Currently Have:
Check List
t4 garret compressor .70a/r exhaust side .84/holset divided
370cc 300zx injectors
300zx maf
walbro hp fuel pump
begi fmu
ebay afpr
apexi neo
mevi
300zx bbk
triple gauge pod : boost, fuel pressure, oil pressure
zeinotrix wideband with boost, and egt,afr, and lamba display hookups
hks ssqv bov
tial 38mm wastegate
mishimoto aluminum radiator
mishimito intercooler 27x6x2.5
Remaining items:
mishimoto oil cooler
intake spacers nwp
intercooler piping
exhaust piping (dont know if i want a full 3" exhaust from downpipe back. Or a 3" downpipe to 3" cutout replacing the cat then a reducer to a greddy sp2 or an apexi ws2") what do you guys think?
Help:
I need info on oil feed and return lines? I know the sizes already
But where can i find the best equipment?
I need to know what should i buy to run the afpr and the begi fmu in terms of lines and vacuum hoses?
Also feel free to tell me what im missing and also to critique my setup.
In case anyone is wondering im replicating the pfi setup as close as possible seeing as it is the setup i have the most experience with.
Old 07-04-2009, 11:05 PM   #30
Send a message via Skype™ to bryan163
What will you be using for a turbo manifold? Check out page 5 of my cardomain. I just finished turboing my max. I'll be firing up the motor for the first time tomorrow morning after i get some fluids back in the motor. I have 370 injectors, Z32 MAF, Jim Wolf ECU, Walbro 255 fuel pump, an ebay generic T3/T4 turbo, and a home made manifold.
bryan163 is offline   Reply With Quote
Old 07-05-2009, 08:29 AM   #31
Quote:
Congrats bro. From reading threads and talking to a few buddes. Depending on the size of that turbo and its flow rate. keep boost at a decent psi and with what you have you should be ok. If you welded up everything bravo. You are pretty good. Let me know how everything turns out.
Is the jim wolf modified for a turbo setup with walrbo, 370 injectors and a z32 maf?
Generic Ebay turbo will hold up for a bit but have heard a few bad stories about them over the long haul.
Old 07-05-2009, 02:23 PM   #32
Send a message via AIM to wirelessdude04 Send a message via Yahoo to wirelessdude04
yes, he did
Yea jeeve broke i think 365 hp on 7 or 8 lbs... He's running like 10 or 11 now i beleive so he should be breaking 400 at the wheels easily.. I will tell him to chime in on this thread
__________________
Under Major Overhaul
Team All Out Nissan: President
Visit us @ teamalloutnissan.com
wirelessdude04 is offline   Reply With Quote
Old 07-05-2009, 10:59 PM   #33
Yeah, the JW ECU is so easy. It was tuned for the 370s and the z32. You just plug it in and your tuned. I drove the car all day today at 10psi. The raw acceleration and sound of the turbo are indescribable. The car runs perfect. It revs to 7200 RPM with the new ECU and Idles like stock. What a sleeper! I can hardly wait to go race some unsuspecting corvettes.
I did make the manifold myself. Pics are on page 5 of my cardomain.
Thanks BkGreen97 for letting me get some posts in on your thread. I'm a newbie so Im trying hard to earn my 15 posts.
I saw your pics on cardomain and it looks like your doing a good job with the fab work. can't wait to see the end result. I might build a few more manifoldes just to sell. Not sure if its worth the trouble though.
Old 07-31-2009, 04:11 PM   #34
^ na bro building manifolds and selling them would be great alot of guys are doing it
Old 07-31-2009, 09:26 PM   #35
Yeah, I'm gonna be making some more.
Old 07-31-2009, 09:37 PM   #36
Hows your project going?
Old 08-02-2009, 11:31 AM   #37
blew out front coilovers. dont have a back up set so i sent them out and had to buy some other suspension so progress was halted again.
Looks like the car pulling hard bro.
Old 08-17-2009, 01:35 PM   #38
Sorry to hear about your coil overs. Mine has been doing great. Had to swap my kevlar disc clutch out for a ceramic 6 puck though. It was not strong enough. You should consider doing the same if you haven't already.
Old 09-20-2009, 05:06 PM   #39
Tryed 3" vband clamp and it did not work. Tooooo small. I cannot get in touch with the previous owner...but i found this old picture that he sent to me...
Finding this picture lets me know what i have to do... stay tuned for progress updates...
Old 10-24-2009, 05:16 AM   #40
Feed Pipe Made
Decided to go with forward y pipe, for ground clearence, hopefully quicker spool, and less piping.. All piping will be sanded down, high temp painted, and wrapped..
We reinforced the motor mount as you can see, at the top, bottom, and both sides.. Downpipe will be finished today hopefully. Still having trouble with the flange, need to make a custom one but its kicking my ***...
Sorry for the extra large pics but hopefully, someone cause use these as a reference one day...
The pipe is in two pieces for easier removal. We added somewhat of a vband flange right after the bend in front of the motor mount.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
