Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Closed Thread
Thread Tools Display Modes
Old 03-02-2009, 04:31 AM   #41
Quote:
Originally Posted by ser_altima View Post
Current goal is 420 whp tuned
550's will get you there.
__________________
Parting out a 1990 Pearl White 5-speed SE...PM ME FOR PARTS!!!
The Cuban is offline
Old 03-03-2009, 11:49 AM   #42
Send a message via AIM to ghostmax301 Send a message via MSN to ghostmax301
So over the last few months, I have been piecing together a turbo kit for my 5.5 gen 6-spd HLSD. I have listed 2 different sections of what I have and what I need still. Feel free if you have something on the "need" list that you want to get rid of shoot me a reply or PM. Thanks
Purchased:
- Garrett 60-1 Journal Bearing Turbo
- Tial 38mm wastegate
- 3" custom down-pipe
- Custom reverse y-pipe (mounts to turbo)
- 3" custom CAI
- 2.5" custom ICP
- K&N Cone Filter
- Godspeed Front Mount Intercooler
- Custom fit steel braided oil feed/return lines
- Auto Meter Boost Gauge
- Auto Meter Oil Pressure Gauge
- Zeitronix Wide band/datalogger
- Walbro 255
Need:
- BOV
- Z32 MAF
- Emanage Ultimate w/ harness (NEED BADLY)
- 440 or 555cc Injectors
WTF!!! youre turboing Merlyns old car right? and still have the red se-r or am i mistaking you for someone else?
Either way, i cant wait to see this!!
__________________
VQ30DE-13.98@98
VQ30DE-K-13.61@101
VQ35-13.55@103
(no tune,street tires)
DE-K. Walbro 255lph. Z32TT fuel filter. PFTB. Full exhaust. Fidanza Flywheel. 5spd swap. S/S full clutch & brake lines. I.D. Lip kit. 97-99 Int. & ext. conversion. 2k1 cluster. 2k3 seats
ghostmax301 is offline
Old 03-03-2009, 01:25 PM   #43
sparks03max's Avatar
to OP: It's possible that the UPREV Osirus tuner (PC-based tuning/reflash program like HPtuners for most GMs) will work with our ECU. I'm currently trying to get in contact with someone to see if they will let me return the product if it doesn't work with this vehicle.
__________________
2003 SE 6MT Titanium Edition - Sterling Mist
Power mods: SRI, VIAS Delete, NWP spacers, Cattman Headers, Custom exhaust, TurboXS UTEC + Tuner
12-second 5.5 gen track vid: http://www.youtube.com/watch?v=HDz_fIHZgig
sparks03max is offline
Old 03-03-2009, 05:49 PM   #44
Send a message via AIM to wirelessdude04 Send a message via Yahoo to wirelessdude04
nice
__________________
Under Major Overhaul
Team All Out Nissan: President
Visit us @ teamalloutnissan.com
wirelessdude04 is offline
Old 03-03-2009, 06:45 PM   #45
Yep I am turboing Merlyns old car. I no longer have the SE-R. Sold it for business reasons, loved the SE-R Altima, wish I had it stilll But this Maxima is gonna be quick and I have it lowered on the 18" G35 wheels so it is clean.
ser_altima is offline
Old 03-03-2009, 10:50 PM   #46
i jus jizzed my pants.
thanks.lol
__________________
VQ30DE-13.98@98
VQ30DE-K-13.61@101
VQ35-13.55@103
Old 03-04-2009, 05:00 PM   #47
What are you going to use as fuel managment?
deatschwerks makes injectors that are a direct drop in. Would 600cc be too big though or would 440cc be plenty enough?
SpooledVQ35 is offline
Old 03-04-2009, 05:41 PM   #48
I am going to use Emanage Ultimate and 440s will be good until i go with a T67 (built motor) and then 600s will come in to play.
Old 03-06-2009, 07:46 AM   #49
Send a message via AIM to MDeezy
you could use 600s just tune them properly and you will be fine. You may need to play with fuel pressure too to get a nice balance. This way you'll be ready for down the line when your ready to upgrade... depends on the how high the duty cycle is on the 440s @ your desired boost level.
MDeezy is offline
Old 03-06-2009, 01:44 PM   #50
VQ35 FTW
mastercater7's Avatar
Deatchwerks 600cc injectors FTFMW!!!
mastercater7 is offline
Old 03-08-2009, 02:33 PM   #51
The Original CF Maxima
Flava_24/7's Avatar
Its now the 8th, any updates?
__________________
Chumps try to imitate but can never duplicate
377hp 338tq
Flava_24/7 is offline
Old 03-08-2009, 02:39 PM   #52
Quote:
Tearing out the transmission right now the freakin input shaft bearing is out I believe... but hey couldnt be a better time everything was going to be pulled apart anyway. Better now.. so at the same time Im going to replace both input shaft bearing and throw out bearing with OEM Nissan instead of the Exedy bearing. So install will perceed Monday. Will keep you guys updated with pics and such.
Old 03-15-2009, 02:55 AM   #53
Okay guys after a painful week of waiting for parts, changing things up on the fly... and a billion trips to machine shops, lowes, performance shops, mcdonalds, etc...
I have transmission back in with a Spec Stage 4 Clutch and Fidanza Light Weight Flywheel (re-surfaced), I had to do this due to a a faulty Exedy Stage 1 Clutch that broke apart at the disc Piece of $Hit! Called Exedy and they could care less and would not give me the time of day. Sad thing is, it only had 5k miles on it. Anyway, called Spec on Monday, Ordered it Tuesday, it shipped out sameday and had it Thursday. We installed it, through the tranny back on.
Had to make sure the turbo was getting oil, so tapped into the block, wasnt TOO TOO hard, but you just HAVE to make sure the fitting you use is super tight and sealed as you dont want to leak oil, also take into consideration where you locate it so running the line wont have any problems in terms of backing the oil up.. you will have oil blowing past your turbo seals at that point then. Feed line is easy just used stock oil pressure sensor location, with a T fitting from turbonetics and BAM done, connect feed line, and connect your oil pressure sensor.
Next was to re-locate the battery since it had not been done yet, this was done with a Summit Racing Battery relocation kit, not hard, took about an hour.
One hard part was getting the down pipe, and reverse y-pipe to bolt up to stock manifolds since that is what the kit uses, it was a pain in the rear, but got it done. In the mean time, while under the car and bolting up downpipe, particles got in my eye and I had to drive to a Medclinic to get the shavings removed. Sucked, but ill live.
At this point, I have decided to get a slighlty bigger turbo then what I have, and that should be here Tuesday, and we will just bolt that right in connect some feed lines, return lines, etc and be good to go Well, nothing went on easy, the Maxi gave me trouble the WHOLE way, so I dont expect smoothe sailing from here lol
Tomorrow we put on and modify some intercooler piping, mount the intercooler, put on the front wheels, put some oil, tranny fluid, and coolant, lower her, and wait for turbo to come in.
Will let you know when she is up and running.
Old 03-15-2009, 07:33 AM   #54
KRRZ350's Avatar
Send a message via AIM to KRRZ350
It's always the stuff that you think is going to take 5 minutes that ends up going on 5 hr's not including getting crap out of your eye, but damn sounds like you had it rough. Patience will be worth it when your system is TROUBLE FREE and you're confident it will stay that way, little things like slicing thick hose down one side & wrapping it parts of the feed line, extra time zip-tying stuff just right, etc goes a long way. Leaks suck, sounds like it's going to be a quality install.
Don't know if you got a BOV yet, but you'll want a recirculating set-up OR an engine managment with an anti stall feature. (edit) I see you have that with the EU. Not to take this back to the engine managment discussion but I've found the eu's tend to break alot, just my .02
KRRZ350 is offline
Old 03-15-2009, 10:39 AM   #55
KH3 by popular demand
maxgtr2000's Avatar
Send a message via Yahoo to maxgtr2000
Current progress install Pics ftw??
__________________
Retrofit headlight services
My VQ30DET
Emanage Blue and Ultimate Forums
There can be no peace until you possess the Prince of Peace.
maxgtr2000 is offline
Old 03-15-2009, 12:04 PM   #56
Im going to go take some pics right now for my local forum as well.. but here are SOME pics when we were taking everything apart.
Old 03-15-2009, 12:46 PM   #57
good camera + no crappy quality pics FTW! cant wait to see the outcome
and since you're going with a bigger turbo, does that mean you'll be selling the T4/60-1?
__________________
VQ30DE-13.98@98
VQ30DE-K-13.61@101
VQ35-13.55@103
Old 03-15-2009, 12:55 PM   #58
No I had bought the 601 with a T3 Flange by accident.. im letting that go now to the first person who offers me money as i need the cash lol.. I now have the T4.
Old 03-16-2009, 08:57 AM   #59
It's great to see you are making progress. I cannot wait to see pictures of it installed. By the way, in what way did you have to modify the intercooler piping? I'm putting the turbo in the mail in an hour and will let you know when I do.
nismomaxct is offline
Old 03-16-2009, 09:09 AM   #60
Quote:
I had to locate where it went down in front of engine because the longer charge pipe that had gone across the section of the engine where the valve cover was at was too tight against one of the coolant passage locations for the radiator, as well as the the bottom part of the frame in front of the car hangs too low, so I am assuming since this kit was made for a VQ35 ON a 4th gen, the frame is different just slightly to where it affects how the piping mochs up to everything.
Old 03-16-2009, 11:54 AM   #61
That is strange. By the way, the kit came off a 5.5 gen. Look at the pictures in the for sale thread. It is just beyond me.
Old 03-16-2009, 12:09 PM   #62
Hmm Im not sure but this setup actually seems a little better IMO I will take pics when the finished product is done.
Old 03-19-2009, 04:04 PM   #63
ok guys got everything on it looks sweet.. problem is i went to start it to make sure everything was good to go and it idles but it wont start.. a buddy came over and we checked all IC piping by pressure testing it and we had some leaks MAJOR ones.. BUT fixed them all.
When the car tries to start its like the starter is running the car, even when i give it throttle a bit it does not help. We checked all electrical connections and they are good to go.
We replaced the clutch and had flywheel resurfaced.. could anything been messed up in the process with timing? Does the flywheel have to be put back on a certain way or ECU flashed aftwerwards? Im just trying to find anything. ANy help would be great.
Oh and last thing we have got to the point where we put the intake back on throttle body with MAF hooked up so it is NA right now. I do not have my EMU yet but it should fire over and idle fine. HELPP
Old 03-19-2009, 05:46 PM   #64
Flava_24/7's Avatar
So right now its just a regular 3.5 with the stock inj.?
__________________
377hp 338tq
Old 03-19-2009, 08:22 PM   #65
Send a message via MSN to 96blkonblkse
Did you plug the CPS back in? I cant remember, but on the 6spd, dont you have to index the flywheel? Could be confusing myself with auto tranny, but i seem to recall something.
Did you drop or bang the maf around at all?
__________________
98 Maxima SE 5MT - For sale, My first true love
00 E39 M5 Alpine White/Silverstone 6MT
19x10.5 Volk CE28N T/A, 275/30/19 Pilot Sport PS2's, AFE Intakes, ESS Tuning Reflash, Tubi exhaust #36
96blkonblkse is offline
Old 03-19-2009, 08:56 PM   #66
Yes we checked the crank position sensor several times and its plugged in.. we pulled the plugs and it reeked of gas it is flooded.. i bought new plugs just to see what the deal was and tried to turn it over a few times and they were soaked.. i believe it has a very very weak spark or not firing at all so something electrical im not sure.
Old 03-19-2009, 10:10 PM   #67
maxgtr2000's Avatar
If you have the walbro and no afpr or fuel management it probably won't start.
__________________
My VQ30DET
Old 03-19-2009, 11:35 PM   #68
nope nothing has been changed with fuel or anything.. i think i forgot to align flywheel notch with crank sensor.. oops could that be it?
Old 03-19-2009, 11:45 PM   #69
Send a message via AIM to NiZMo1o1
Quote:
Like he mention , but he said he pulled the plugs and they were soaked,
How are you getting fuel pressure ?
Did pull out the Coil pack and see if theres spark ?
Do you have any CEL lights ? trying clearing the codes/
We just went thru this lately at my shop with a 3.5 A33.5
How are you running your fuel system btw ?
__________________
http://www.facebook.com/home.php?#/p...e/194777241351
R.I.P. Kevin007
NiZMo1o1 is offline
Old 03-19-2009, 11:56 PM   #70
bow to the great beauty and power of your Maxima
99NightRiderMAX is offline
Old 03-20-2009, 12:11 AM   #71
The car came with an aftermarket fuel pump already a walbro.. I have not puilled coil packs yet to see if there is spark or not. I borrowed an OBDII reader and it stated NO codes which is very odd because before I did all this work there were codes on there for the cats due to me having aftermarket ones, so Im not sure if computer cleared them after having no power for over a week or what.
Fuel pressure like you asked is still stock FPR, no need to change yet, nothing with fuel has been tampered with so it should all work fine.
I believe its a bad ground somewhere and/or the crank angle position sensor, I dont believe we lined it up correctly when putting flywheel (after getting it turned at machine shop) back on to input shaft, which could really be making the ECU go nuts.
Old 03-20-2009, 07:35 AM   #72
Flava_24/7's Avatar
If the batt. was disconnected or if the ECU was, then yes you will have no codes.
Fuel pressure cannot be stock if your running a Walbro, but even with it you should be able to start it.
__________________
377hp 338tq
Old 03-20-2009, 09:02 AM   #73
My axles cry for mercy...
essential1's Avatar
Start rechecking the simple stuff. We recently finished some engine work on a 3.5 4th gen maxima. It was running perfect before but when we put everything back together it wouldnt start.
We rechecked all wiring and sensors. Eliminated all vacum leaks and what not. But all we ended up doing was add another ground under the hood and it started up just fine.
__________________
01 I30, [5 speed swap][4th gen pedals and master cylinder][OEM clutch][OEM flywheel][ksport coilovers front, D2 coilovers rear][10k hid headlights and fogs][custom WAI][cattman exhaust][tenzo type-M, 19x8.5 +17F, 19x10 +22R][300zx calipers][Cobra 13" drilled and slotted rotors]
5 speed swap myths BUSTED:
1. Both driver and passenger side AUTO axles work fine.
2. AUTO flywheel bolts work fine.
essential1 is offline
Old 03-20-2009, 10:00 AM   #74
You added another ground?? Hmm that is interesting.. where did you add the new ground too?? Now I will tell you when we did the battery relocation the stock ground wire was pulled and relocated I believe? Could this be an issue? Could a ground really keep the car from igniting the fuel?
Old 03-20-2009, 10:47 AM   #75
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
A ground can prevent lots of things. Thats why most techs will tell you to clean the surface on the block and tranny when doing a clutch to ensure a great ground.
__________________
97 SE Auto Built Auto
97 SE Holset HX52|N2O|6 SP|Built 3.56|More to come
91 GXE Auto bone stock beater
91 GXE 5sp Another beater
Led retro's Pm me
kzoosho is offline
Old 03-20-2009, 12:21 PM   #76
Quote:
Okay I had car dropped off at my buddies garage, he works on Infinitis all day, so hopefully he can get it worked out. Im sure he is going to look over the grounds and such.
Old 03-22-2009, 07:49 PM   #77
Keep us updated, hopefully they figure it out pretty quickly.
__________________
Old 03-22-2009, 08:43 PM   #78
Will do.. turbo that was sent to me had bad seals so it needs new ones.. Hopefully will get car back not this week but next
Old 03-22-2009, 11:28 PM   #79
maxgtr2000's Avatar
How do you know the seals were bad?
__________________
My VQ30DET
Old 03-23-2009, 06:30 AM   #80
There was oil in turbo housing and oil in my down-pipe and such
Closed Thread
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
