Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Thread Tools Display Modes
Old 08-23-2008, 06:17 PM   #1
Send a message via AIM to urmab Send a message via MSN to urmab
First pics of my setup
I finally decided to go turbo so here are few picture of my progress so far, I just install the IC and finished running pipes from the IC, just about to relocate the battery. Once that's done I'm going to start on feed pipe fabrication.
__________________
Ultimate mod 1.6 L IVtec LOL
urmab is offline   Reply With Quote
Old 08-23-2008, 06:32 PM   #2
Looks good can't wait to see more.
VTMaxima is offline   Reply With Quote
Old 08-23-2008, 06:47 PM   #3
Good start man... Are you gonna dyno that sucker once you're finished?
__________________
04 Maxima SL
FUJITA CAI,Magnaflow mufflers, Progress Springs,TSW Snetterton 20"x8.5",Toyo Proxes4 245/35/20R,STILLEN FSTB,PROGRESS RSB,Racingline V2 endlinks,TRex Upper and Lower grill,NISSAN lip spoiler,20% Tints,STILLEN battery tie down,Nismo oilcap,MomoPedals
MAXIMUS Page
ILL-Maxima is online now   Reply With Quote
Old 08-24-2008, 12:00 AM   #4
Yea once finished ill probably dyno it, but before that I got a long way to go tomorrow ill probably install the fuel pump and relocate the battery.
__________________
Old 08-24-2008, 02:52 AM   #5
KH3 by popular demand
maxgtr2000's Avatar
Send a message via Yahoo to maxgtr2000
Looking good, are you going to be using upgraded injectors? Check out my setup in my sig. You doing front feed or u turn feed pipe?
__________________
Dual lens retro thread
Retrofit services
My VQ30DET
Obama on the U.S Constitution- "It is a document with negative liberties."
maxgtr2000 is offline   Reply With Quote
Old 08-24-2008, 03:46 AM   #6
good looking keep up the progress.
__________________
Mods installed: 00vi, Megan Headers/Y-Pipe/Street Pipe, Pacesetter B-Pipe/Cat/Muffler, JWT ECU Upgrade, OBX Underdrive Pulley, FSTB/RSTB, Rear Sway Bar + Much More... And More To Come
mista0406 is offline   Reply With Quote
Old 08-24-2008, 08:59 AM   #7
Send a message via AIM to 95BLKMAX
did you dyno that 3.5 while all-motor to see how its working out so far before sticking the turbo on it? What turbo are you going to run and how high is your realistic power goal? List more of what your setup is going to be meng! lol
Looking good so far though!
__________________
NA-Built Baseline
95BLKMAX is online now   Reply With Quote
Old 08-24-2008, 09:15 AM   #8
Send a message via Yahoo to nwell2k3
Looking good... Welcome to the world of FI...
nwell2k3 is offline   Reply With Quote
Old 08-24-2008, 10:01 AM   #9
Quote:
Well temporary Is going to be using stock 3.5 injectors, I'm doing the front feed similar to your set up.
Actually no I didn't dyno all motor, but another 3.5 that I did the person dyno it, his results where about 205 hp and 200 tq, Im expecting my car to be somewhere around there.
Im runing a T3/T4 60 trim turbo for now.
My realistic power goals are 300-320 hp, If ill get that Ill be happy.
as far as the rest of the setup
Tial 38mm wastegate, TurboXS BOV, Walbro 225 fuel pump, Inovative LC-1 Wideband, EB, Q45 Maf. Im probably forgetting something
__________________
Old 08-24-2008, 10:50 AM   #10
00vi'dvq30devq354.5genftw
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
Couldnt you easily get those power numbers from a turbo 3.0? If it were me i'd aim higher.
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The Dark Phoenix 13.517@102.3mph 60' 2.0 AUTO 245 RWHP 3280lb w/driver
Fear me.
VQ35 Swap Progress Thread
ajcool2 is online now   Reply With Quote
Old 08-24-2008, 11:29 AM   #11
00VI Guy
Tatanko's Avatar
Send a message via AIM to Tatanko
Quote:
Seems like an unimpressive goal for the amount of money and time involved to me.
Props nonetheless, though. Another turbo 3.5 isn't a bad thing
__________________
SHIFT_obsession
Tatanko's Maxima Site & VQ35DE.com
Tatanko is offline   Reply With Quote
Old 08-24-2008, 11:43 AM   #12
Send a message via AIM to streetzlegend Send a message via Yahoo to streetzlegend
I agree, no sense in doing 3.5 plus adding FI to only aim for 300. Could have easily done that with the 3.0.
__________________
Currently Under construction check my progress so far http://forums.maxima.org/supercharge...-new-post.html
Auto, TO4b(10psi), 2.1 60' 8.6@82 1/8th , 312WHP/301WTQ[/b]
streetzlegend is offline   Reply With Quote
Old 08-24-2008, 12:04 PM   #13
Quote:
Well, I do agree with the numbers that's my minimum goal. I did 3.5 swap about about 2 years ago even before I was thinking about the turbo. And you right I can achieve that with the 3.0 turbo. I have to finish it first to see what power I will achieve to see where I can go for more. To tell you the truth my real goal is 400 but It doesn't seem to be all that realistic for a daily driver although I may be wrong. Also for my setup I'm also thinking of adding Meth/Water injection.
__________________
Old 08-24-2008, 01:40 PM   #14
maxgtr2000's Avatar
Quote:
You are closer to 400 than you think, just get the right injectors and tuning.
__________________
Retrofit services
My VQ30DET
Old 08-24-2008, 01:52 PM   #15
Yea i suggest to do the setup initially to handle ur maximum goal. That way you dont do things now for 300hp, then later on you wanna make it to 400hp an gotta change things around and add stuff like injectors, etc... so set everything up to be ready for 400, saves you time and money... thats my opinion anyway.
__________________
Old 08-24-2008, 02:56 PM   #16
I agree, well In my opinion my current setup should handle up to 400 hp , the only thing I need are injectors
__________________
Old 08-24-2008, 04:13 PM   #17
Send a message via AIM to wirelessdude04 Send a message via Yahoo to wirelessdude04
nice start cant wait to see the finished product
__________________
Under Major Overhaul
Team All Out Nissan: President
Visit us @ teamalloutnissan.com
wirelessdude04 is offline   Reply With Quote
Old 08-24-2008, 06:49 PM   #18
Send a message via AIM to PharoNDmist
Ahhh 3.5 Boost I'm going that route pretty soon. Are you going to build it? If so A mild build would be under 1k with arp rod bolts arp head bolts,
arp main bolts and cometic headgasket etc. Looking good so far.
__________________
Supercharged 99 Black SE 5spd
MODS:V1 3.33 pulley @10psi\3' piping\CAI\budget y-pipe\ stock exhaust\ 1 step colder plugs NGK\Spec 3 clutch\Quaife\Fstb\Cattman-progress coilovers\Brembo Cross Drilled rotors\ Diamond clears\7%tint\ Stillen Front Lip\ Sarona side skirts\ Aluminum dash Kit\Self made rear red clears\shaved a$$& keyhole\ Colbalt guages\Panasonic DVD
PharoNDmist is offline   Reply With Quote
Old 08-24-2008, 07:44 PM   #19
The JDM Rat.
timmay5835's Avatar
looks good so far. 400whp would be nice to see, but are you 5-speed or 6-speed?
__________________
Granny's GLE, its stock i sware.
4th gen OWNZ ALL!
timmay5835 is offline   Reply With Quote
Old 08-24-2008, 08:04 PM   #20
Build.
Send a message via AIM to nismology
Every one of those items is a waste of money.
__________________
"Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing ever happened."
nismology is offline   Reply With Quote
Old 08-24-2008, 08:38 PM   #21
Hibernating
accordingtou's Avatar
Quote:
Lol I love wasting money
__________________
Weird things happen when drawings come to life.
Old setup=3.5/ssim/H/Y/C/Arp stuff/Fidanza Flywheel/Vlsd/3"exhaust/Stock ecu/safcII
N/A 13.9@100.27 M/T ET street radials
N/X 12.9@111.81 M/T ET street radials
Click below to watch the maximas go
http://www.youtube.com/user/weelman1
3080 Lbs with driver (notarized proof)10/2008
2950 (est) with driver "complete interior"
accordingtou is online now   Reply With Quote
Old 08-24-2008, 09:08 PM   #22
at least say why its a waste of money
__________________
Old 08-24-2008, 09:42 PM   #23
So what would you suggest?????
__________________
Old 08-24-2008, 10:09 PM   #24
