Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Thread Tools Display Modes
Old 08-07-2008, 06:12 PM   #1
matty's Avatar
Send a message via AIM to matty
Guys with Intercoolers...
Just a quick reference.
Ive been having a/c problems over the past two summers, and at the end of last summer, I got a new compressor, and evaporator inside. Spent a nice chunk of change and its still not cold cold.
I figured I would drop it off at Nissan today and let them look at it since on the highway after driving for about 30 min, it gets cold. (Climate control on 65F, it stays at full fan the entire ride home)
They hooked it up to the machine and measured all the pressures.
AMBIENT DATA:
Ambient Humidity: 39%
Ambient Tempurature: 87 F
VEHICLE DATA:
Red Vent Temp: 82 F
Blue Vent Temp: 51 F
High Side Maximum: 183 psi
Low Side Minimum: 28 psi
Charge Weight: 1.5lbs
They are blaming the temp not being so good on the front mount intercooler saying not enough air is making it past there onto the condensor. They are saying I should install a push fan between the intercooler and the condensor. How real does this sound ??
-matt
matty is offline   Reply With Quote
Old 08-07-2008, 07:04 PM   #2
96sleeper's Avatar
Send a message via AIM to 96sleeper
my A/C works like a champ on an untouched original cooling system and factory fans. My intercooler is fairly large also.
__________________
96 Pebble Beige SE
14.2@97mph as an auto
13.7@102mph as a 5spd
12.9@106mph after 3.5 swap
11.6@120mph with the S/C
Visit here for mods and dyno.
2005 Nismo Frontier 4x4
96sleeper is offline   Reply With Quote
Old 08-07-2008, 07:05 PM   #3
KH3 by popular demand
maxgtr2000's Avatar
Send a message via Yahoo to maxgtr2000
Seems to me like a lot of mechanics when they can't figure out a problem they blame it on mods. Does the intercooler even get that hot? No. What about when it is 75 degrees vs 90 and the a/c acts the same way and the car isn't even being push hard? I think those guys are just lazy. Without getting a fan you can disconnect the s/c from the intercooler and go for a ride, the charge air won't be going in so there won't be any heat, and you can check and see if the a/c feels better to you. If it does then get the fan.
__________________
Dual lens retro thread
Retrofit services
My VQ30DET
Obama on the U.S Constitution- "It is a document with negative liberties."
maxgtr2000 is offline   Reply With Quote
Old 08-07-2008, 07:06 PM   #4
the stealership blames everything on mods!!!!!! they just don't want to look any further!!!
really pisses me off
__________________
Whered that VQ go??
1. 2003 titanium edit blacked out, staggered 20" (yaya i know)
2. 2000 pearl white 5 spd all basic bolt ons g35 whls, it was good while it lasted.
3 87 stang Project 306ci built motor full susp. (in garage) its sloow .....
perkman87 is offline   Reply With Quote
Old 08-07-2008, 07:13 PM   #5
matty's Avatar
Pisses me off too. They are insisting on saying the intercooler is to blame. What is a little stupid fan going to do at 60-70mph ?? Past 30, the fan is going to be useless.
Old 08-07-2008, 07:42 PM   #6
Send a message via ICQ to Torgus Send a message via AIM to Torgus Send a message via MSN to Torgus Send a message via Yahoo to Torgus Send a message via Skype™ to Torgus
the intercooler will get hot fwiw...
but as the other guy said disconnect it and see if the problem is still there.
also it should be plenty cold just sitting in your driveway...
__________________
--Jon--
Currently driving:
03 Maxima: 40k miles, Bodykit, CF hood, 20'' Chrome DUBz, Alarm, Tint, Eclipse AVN6500, Rainbow Profi Vandiums, Boston Pro60s, 2 12'' Type Rs, Suspension, Cleared 8k HIDs w/ DDE Angel Eyes, Intake, Exhaust, Timing Adv, Custom 2 Tone Interior, x drilled/slotted/zinc rotors, SS brake lines, etc.
92 Max SE: 5 speed LSD 230k Daily Driver FTW 4DSC!!!!
Retired:
97 Max modded: BURNED IN FLAMES
96 Max modded: Sold to brother
95 Max modded: Attacked By Volvo
Quote:
Originally Posted by KRRZ350 View Post
I'm the only one showing my e-manliness to compensate for my small penis size.
Torgus is offline   Reply With Quote
Old 08-07-2008, 08:17 PM   #7
Send a message via AIM to euromaxima Send a message via MSN to euromaxima
no problem here my air blows ice cold, it could be the filter in the line, my uncle told me one time with my other maxima that that might be the problem but i had too much freon, but he told me that there should be an inline filter somewhere in the line, check the haynes manual to see if there is one.
euromaxima is online now   Reply With Quote
Old 08-07-2008, 08:54 PM   #8
Send a message via MSN to 96blkonblkse
The thing that were forgetting is. Does it blow cold when your idling? My AC blows cold while idling, and theres no air coming through the condensor. Yes there is a puller fan, but honestly, its not doing that much. I am assuming you still have your stock AC Fan.
I find the AC in the 4th gens doesnt blow as cold as some of the new cars. My work car (07 Alti) blows ice cold.
__________________
VQ30DET - Holset HE351, Tial 38MM, HKS SSQ, MEVI, 3" Turbo back, Tein Coilovers, 17" Superleggeras, Full Z32 BBK
"Because boosted is beter.."
96blkonblkse is online now   Reply With Quote
Old 08-07-2008, 10:36 PM   #9
Hibernating
accordingtou's Avatar
Your low side psi seems a bit low. I would say it has verrry little to do with the fmic. Do you have a stock size UDP? A small UDP can cause this problem.
__________________
Weird things happen when drawings come to life.
Old setup=3.5/ssim/H/Y/C/Arp stuff/Fidanza Flywheel/Vlsd/3"exhaust/Stock ecu/safcII
N/A 13.9@100.27 M/T ET street radials
N/X 12.9@111.81 M/T ET street radials
Click below to watch the maximas go
http://www.youtube.com/user/weelman1
3080 Lbs with driver (notarized proof)10/2008
2950 (est) with driver "complete interior"
accordingtou is online now   Reply With Quote
Old 08-08-2008, 04:58 AM   #10
matty's Avatar
Stock UDP. The intercooler definetly doenst have anything to do with it. I went out to my car last night and ran the a/c for about 15 min and the A/C line going into the cabin was freezing cold and the air coming from the vents wasnt cold. Definetly somthing going on in the evaporator box, maybe a clogged expansion valve ? It is new along with the core inside that box.
Old 08-08-2008, 07:44 AM   #11
Use the Search Function!!
mtrai760's Avatar
Send a message via AIM to mtrai760
Off topic a little, but Iansw was having trouble with a vacuum leak and took his car to a local Nissan dealer for some assistance. He disclosed all his mods, including his supercharger. When he came back to get his car, they told him he needed a new motor, and that his current one was making too much noise and must be the problem...
Yeah, Vortech V1's are kinda noisy... and the car runs fine to this day
Moral of the story: never trust the stealership with a modified vehicle.
__________________
98 SE - Supercharged at 10psi w/the works - VQ35 coming soon...
2k SE - Stock... pretty much
88 RX-7 - Sold
95 240sx KA-T 10psi - sold
3 4th gens.... gone....
mtrai760 is offline   Reply With Quote
Old 08-08-2008, 08:43 AM   #12
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
Im rocking a ic and my ac runs ice cold. Mine is pretty large.
__________________
99 GXE Auto V1 370cc injectors and Modded vb.
97 5sp SE New build Holset HX52 and spray. More to come.
91 GXE Auto bone stock beater
Led retro's Pm me
kzoosho is online now   Reply With Quote
Old 08-08-2008, 02:48 PM   #13
Merc signs my checks
liqidvenom's Avatar
Send a message via AIM to liqidvenom
your low side looks good but your high side pressure should be in the 200-250 range if im correct. it seems as if its not pumping properly or something. your compressor might not be able to pump enough.
or your evap temp sensor might be freezing and not giving a reading any longer and thus why the car stops cooling. noirmally the low side will get to 32 or so and stop so it doesnt freeze anything up.
all of the turbo cars here at work have FMIC on them and they cool just fine.
__________________
which team are you with?
liqidvenom is offline   Reply With Quote
Old 08-08-2008, 08:25 PM   #14
Boosted 3rd Gen
I would also throw out checking your vent door to make sure it is closed all the way when the AC is on and not pulling in/mixing the hot outside air as the cold air is being pushed through the vents.
On my car, even without the intercooler, it works best on speed 2 or 3. It does not cool well on 4 when the cabin is really hot after been sitting. So, maybe try a lower fan speed to start off.
Plus 1 on the dealership being full of crap.
__________________
http://www.cardomain.com/ride/329804
*Work in Progress!
Chris Gregg is offline   Reply With Quote
Old 08-08-2008, 10:33 PM   #15
Did you run the A/C system self diagnostic?
When you open the evaporator box, can you see any frost? Is the thermal probe on the expansion valve attached to the freon pipe correctly?
SVI30 is offline   Reply With Quote
Old 08-09-2008, 10:35 AM   #16
matty's Avatar
Quote:
Whats done to run this ?
I havent opened up the box at all. I didnt think you could without taking off the two lines in the engine bay. How is it suppose to be attached ?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
