Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Thread Tools Display Modes
Old 07-25-2008, 09:51 AM   #1
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
Emanage Blue Question
Ok well i have searched and searched but i cant find out why the emanage says to tap the injector wires and not intercept them. Am i going to be doing it right just tapping them or do i need to intercept. Also does any one know the pins to use? All i keep coming up with is ultimate wiring. Any help would be great i would like to get this thing tuned better.
__________________
99 GXE Auto V1 370cc injectors and Modded vb.
97 5sp SE New build Holset HX52 and spray. More to come.
91 GXE Auto bone stock beater
Led retro's Pm me
kzoosho is online now   Reply With Quote
Old 07-25-2008, 12:49 PM   #2
3.5 in the works
DandyMax's Avatar
Send a message via AIM to DandyMax Send a message via MSN to DandyMax
Quote:
The reason they're tapped and not intercepted is because the EB can't remove fuel directly using the injector lines, it can only add fuel by extending the pulse time. To take out fuel the airflow map must be used.
Which pins are you talking about, on the EB or on the ECU? Because the ECU injector pins are the same.
__________________
1998. 3L. 5-spd. Sterling Mist. SE.
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
DandyMax is offline   Reply With Quote
Old 07-25-2008, 12:52 PM   #3
EB but i think you answered what i needed so i can search more and find the rest out. Thanks Dandy. Im still trying beat your e/t and im boosted lol. Thanks a ton for the info.
__________________
Led retro's Pm me
Old 07-25-2008, 03:14 PM   #4
Send a message via AIM to MDeezy
just curious are diodes still needed for the EB on the 4gs? always heard mixed answers, melted coil packs, some not. never knew a solid answer.
MDeezy is offline   Reply With Quote
Old 07-26-2008, 12:00 AM   #5
3.5 in the works
DandyMax's Avatar
For what it costs I'd put them in.
__________________
Best 60': 1.73
Old 07-26-2008, 12:25 AM   #6
KH3 by popular demand
maxgtr2000's Avatar
Send a message via Yahoo to maxgtr2000
I think the latest blue update was supposed to fix it but I would run diodes to be safe. I had the ignition harness but a pin got damaged when I was installing it and the weak connection caused the car to misfire but I had diodes on mine. The way to test it is to run the car with the a/c on and feel the coil packs, if they are getting warm then you need diodes. According to this I think it was version 1.36 firmware that had the fix. Firmware Upgrade fix list.
maxgtr2000 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
