Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Thread Tools Display Modes
Old 07-24-2008, 07:58 AM   #1
The Original CF Maxima
Flava_24/7's Avatar
Fuel Setup
Ok, I know these are going to be ultra newbie questions so please dont flame me too bad. Im still new to the tuning world.
Im in the middle of swapping out my fuel management setup. Replacing the JWT ECU with the EU.
Now, Im also running 555's now and removed the 370's.
Now here is my problem. Once the 555's were in with the Emanage I had a really hard time getting the car to start.
As many of you are aware of Im sure, with the Walbro and the new injectors the car flooded out majorily.
The only way I could get it started was by pulling the fuel pump fuse long enough to get Emanage going and then put the fuse back in to avoid flooding the motor. Once I did get it started it still ran very rough and the person doing my tuning just couldnt seem to find a sweet spot for it to idle correctly.
Now, the only thing I was running besides the JWT is a Cartech FMU which is still currently hooked up.
My base FP at idle is around 40-41 which is really high I know. So with the new inj. and the Walbro Im figuring the best way to get the car running and get started with tuning is by installing an AFPR to bring down the base FP to stock at idle if not a bit lower,.. or does the EU have the EU have capabilty of adjusting FP?
Im really not familiar with all that the EU can do just yet, and the person setting up the base tune knows the Emanage Blue really well but is new to the EU as well.
Im also assuming that I should just go ahead and remove the FMU as well now that I will be using the EU?
Now if I need to install an AFPR, ive read that many hollow out there OEM unit and then install it somewhere after it. Is this really needed or can the OEM unit be removed and the AFPR be installed in its place.
Flava_24/7 is offline   Reply With Quote
Old 07-24-2008, 08:13 AM   #2
matty's Avatar
Send a message via AIM to matty
Get the FMU out of there for one. Also you can put in the FPR and bring that FP down a bit to around 34 with vac. Get a stand off fitting for your fuel rail unless you want to gut out the stock unit. I think the stand off fitting is cleaner.
Now on starting the car. I had the same problem you're having. I actually went through three sets of plugs and changed the oil twice while trying to get the dam* thing started.
The ONLY thing that worked for me, and I mean ONLY, is changing the LAG time on the injectors. I even set the maps to -5 all the way acrost the board and it didnt do anything.
There is a start and an end on the LAG. Set it to about START: -.2 END: -.7 and see where that leaves you. I forget what I have mine set at but once I messed with that setting the car fired right up. Might need to go a bit higher on the END lag but mess with it.
Report back.
-matt
__________________
**Matty's Steel V1 Supercharger Plate Kits**
**NEXT Run of S/C Plate Kits**
...........(3) $300 Deposits Needed to do run..........
1.
2.
3.
***PM Me if your interested in being Added***
**PM Me for a BOLT KIT**
.....Build Your OWN ::V1 Starter Kits::...
.....or Finally Fix Your V2 Belt Shredding Issues....
Information and Pricing : http://forums.maxima.org/supercharged-turbocharged/334310-fs-new-v1-s-c-plate-kits.html
matty is offline   Reply With Quote
Old 07-24-2008, 08:30 AM   #3
Flava_24/7's Avatar
Report back.
-matt
Thanks for the response and info. I too have gone through a couple of sets of plugs and had to change out the oil once already.
I will do what you said and report back. Its going to be about a week before we tackle it again. The car is at my buddies house and Im trying to gather as much info as posible before we start again.
I figure Im going to order an AFPR to bring down the FP to make things easier.
Im guessing the ideal one to go for is the SARD from sx7r?
Anyone have any thoughts on the Aeromotive or other AFPR?
Old 07-24-2008, 08:32 AM   #4
Use the Search Function!!
mtrai760's Avatar
Send a message via AIM to mtrai760
For a AFPR, there are not any that fit in the stock rail that I am aware of, at least not one that will fit with the throttle body where it is. You can either hollow out the stock regulator, or you can pull it out and replace it with a fitting. This thread has some useful info: Is HKS the only maker of AN fuel rail adapter?
__________________
98 SE - Supercharged at 10psi w/the works - VQ35 coming soon...
2k SE - Stock... pretty much
88 RX-7 - Sold
95 240sx KA-T 10psi - sold
3 4th gens.... gone....
mtrai760 is offline   Reply With Quote
Old 07-24-2008, 12:11 PM   #5
Carbon Fiber addict
An AFPR and FMU are not needed. Use the stock FPR.
__________________
My Max:
99 Maxima 5 spd SE, SC'd, MEVI, Cattman Headers, KEVLO LED tails,R34 S2000 AP1 projector retro, Brembo GT BBK, Emanage Ultimate..
The Wizard is offline   Reply With Quote
Old 07-25-2008, 10:42 AM   #6
Flava_24/7's Avatar
Quote:
This is the route Id rather go. Dont really want to buy more items if I dont need to.
__________________
Old 07-31-2008, 04:46 PM   #7
I30tMikeD's Avatar
Send a message via AIM to I30tMikeD Send a message via Yahoo to I30tMikeD
40psi of fuel pressure is not high. Stock is 43.5.
__________________
2004 Silver G35 6spd Sedan
1996 Turbo 5spd I30 380whp...sold
I30tMikeD is offline   Reply With Quote
Old 07-31-2008, 05:40 PM   #8
Carbon Fiber addict
For reference purposes, stock FP is 34psi at idle.
__________________
My Max:
Old 07-31-2008, 05:54 PM   #9
Flava_24/7's Avatar
Thats what Ive always thought a swell.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
