Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Thread Tools Display Modes
Old 07-14-2008, 09:24 PM   #1
Send a message via AIM to euromaxima Send a message via MSN to euromaxima
turbo did underdrive pulley help increase spool up
For the price of one is it worth the gain, thanks
Brandon
euromaxima is offline   Reply With Quote
Old 07-15-2008, 02:26 PM   #2
Carbon Fiber addict
IMO, it's not worth it for the price. I believe any gains with the UDP will go un-noticed and spool will not change enough to even notice.
I have no experience with this, but some have stated that ceramic coating or header wrapping the tubing will allow the turbo spool up a little sooner. Keep in mind though, that header wrap will eat away and kill the piping over time.
__________________
My Max:
99 Maxima 5 spd SE, SC'd, MEVI, Cattman Headers, KEVLO LED tails,R34 S2000 AP1 projector retro, Brembo GT BBK, Emanage Ultimate..
The Wizard is offline   Reply With Quote
Old 07-15-2008, 02:46 PM   #3
Build.
Send a message via AIM to nismology
UDP's are pretty much useless in any application.
__________________
"Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing ever happened."
nismology is offline   Reply With Quote
Old 07-15-2008, 05:21 PM   #4
Send a message via MSN to khantalha Send a message via Yahoo to khantalha
lets put it this way auto 4th gen with intake and udp < bone stock 5 speed at 1/4 mile
__________________
95 SE (VQ35DE EATER) - 96 GXE (Weekend Fun) - 98 GXE (Daily Day/Grocery Getter) = sold
myspace.com/shady_aftermath_
Quote:
Originally Posted by irish44j View Post
khantalha, in case you didn't see my other post - your signature is not appropriate for this forum and needs to be deleted. Please take care of it...
Lots of NEW/USED 4th Gen Parts , Click here, if dont see what ur looking for then PM me...
khantalha is online now   Reply With Quote
Old 07-15-2008, 10:05 PM   #5
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
UDPs are damn near worthless in any capacity, even less than worthless in a boosted application, if there is such a thing. it certainly wouldn't do a thing for spool up - that's not how they work.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto Drag Radials
3.5L - I/Y/E - USIM
13.26 @ 101 - 1.80 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - stock 3.0L - I/Y/E/MEVI/JWT ECU - Totalled
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Totally Stock - winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 07-15-2008, 10:55 PM   #6
Send a message via MSN to 96blkonblkse
Meh when i put my UDP on i noticed the car seemed to rev a little quicker but thats just the but dyno. I dont think it would make any difference in spool time at all. I got mine used for cheap, so i thought what the hell.
__________________
VQ30DET - Holset HE351, Tial 38MM, HKS SSQ, MEVI, 3" Turbo back, Tein Coilovers, 17" Superleggeras, Full Z32 BBK
"Because boosted is beter.."
96blkonblkse is online now   Reply With Quote
Old 07-15-2008, 10:58 PM   #7
Build.
Quote:
Sure...it revs up quicker in neutral, not while in gear.
__________________
Old 07-15-2008, 11:22 PM   #8
i did see it revving up a little faster but again i had crap load of other mods to go with it too but lightened flywheel and udp combo does help u rev quicker... but it doesnt have anything to do with ur turbo spooling
__________________
Old 07-15-2008, 11:50 PM   #9
UnPr3d!cT@bL3 M@X !!!
JonBlz's Avatar
Send a message via AIM to JonBlz
the good thing about it is less stress at the crankshaft but other than that your wasting money that can be use for something way better
__________________
Y0u kNoW Wh@T !t !$ !!!!! Money/Cash
V2 S/C kit 11PSI | 01 AE de-k 40k engine | V-afc2 | headers | air-intake | full exhaust | KYB GR2'S | eibach springs | fidanza light flywheel | Stage 3 SPEC clutch | FSTB | RSTB | RSWB | Z32 Brakes | 13" Cobra Rotors | SS brake lines front & rear | 01 AE Vlsd tranny | Stillen front & rear spoiler kit | Sarona sideskirts | 18" Azul rims hyperblack/polished lip | ES inserts front & rear mounts | poly filled left & right mounts | etc......
JonBlz is offline   Reply With Quote
Old 07-16-2008, 12:16 AM   #10
^ i agree
__________________
Old 07-16-2008, 01:06 AM   #11
Yeah, personally id put the money towards something thats difference is more noticable..lighter flywheel if you were so inclined to reduce rotating mass..a set of light weight wheels would be better spent as fidanza's arent exactly cheap. I noticed a small difference in neutral, nothing while moving, but i noticed a significant difference in first gear with the flywheel and even more in neutral.
Nothing beats a set of light wheels though. Dropping 4lbs per rim made the biggest difference.
__________________
Old 07-16-2008, 10:21 AM   #12
SLOW
Nealoc187's Avatar
UDPs are undamped (as far as I know, I've never had one) so if anything it could actually be more harmful to your crank. when the rotating assembly is properly balanced, VQ cranks have been used into the 2000hp range (performance motorsports). if you get one unbalanced though, it could easily tear itself apart. without an balancer, you run that risk. i wouldn't run one on my car.
the physics say that, just like a lightweight flywheel, the gains diminish with each successive gear. it'll be most noticeable in neutral, then 1st, then 2nd, by the time you hit 3rd or 4th gear the gains are so small as to be not worth mentioning.
__________________
3.5L - I/Y/E - USIM
Old 07-16-2008, 11:26 AM   #13
Build.
I'm careful not to lump a lightweight flywheel and an UDP into the same category.
__________________
Old 07-16-2008, 12:56 PM   #14
ud pulley is just another go fast mod. if you got the money buy it if not dont. i know race cars have them and i dont think they use them for no reason.
TurboA32 is offline   Reply With Quote
Old 07-16-2008, 01:45 PM   #15
Build.
Got some ocean-front property in Montana to show ya too.
__________________
Old 07-16-2008, 06:56 PM   #16
Send a message via AIM to streetzlegend Send a message via Yahoo to streetzlegend
i got an UDP with in mine, and let me say. Its the only mod i regret doing, all its good for is to dim your lights, make your a/c not work at its best while in idle. its a useless mod. dont do it.
__________________
Currently Under construction check my progress so far http://forums.maxima.org/supercharge...-new-post.html
Auto, TO4b(10psi), 2.1 60' 8.6@82 1/8th , 312WHP/301WTQ[/b]
streetzlegend is offline   Reply With Quote
Old 07-16-2008, 07:17 PM   #17
thanks for the advice, just trying to get the turbo to spool a bit faster, i have heat wraped every pipe, and it seamed to help a bit, I know it will be hard to get it to spool faster since it is kind of a big turbo. thanks
Brandon
Old 07-16-2008, 10:50 PM   #18
choray911's Avatar
Quote:
I concur! If you like to drive your car at night and listen to the radio, pass on the UDP. The only time I ever lost a motor, the set screw that holds the timing ring on the back of the UDP, backed out and milled a hole through timing cover. All the oil drained out and the motor locked up. Before ya'll start talking crap, I did use thread lock and the UDP was on for 2 years before it let go.
I ran a 200 dry shot for 20 bottles of hose and she still ran like a champ! Pass on the UDP.
__________________
'96 black Se, 5spd with grey cloth interior because leather sucks! Turbonetics T04E turbo, Spearco FMIC, Tial 38mm waste gate, HKS SSBOV, Deachwerks 570 injectors, GReddy E-manage Blue, Sard FPR, Stillen Flywheel, XTD 6 puck kevlar clutch, Zeitronix WBO2 with all the trimmings, and some other crap. TSW REVO 17" bronze wheels, Z32 brake conversion, K-Sport Coilovers with pillow ball mounts and camber plates, 84' 300ZX hood scoop, blacked turn signals, and tails.
choray911 is offline   Reply With Quote
Old 07-17-2008, 11:56 AM   #19
Merc signs my checks
liqidvenom's Avatar
Send a message via AIM to liqidvenom
this is the most correct post in this whole thread, once out of the shorter gears its effect is lost.
Quote:
why not? they both do the same thing at just different ends. granted the effects are felt more from the flywheel mod.
__________________
which team are you with?
liqidvenom is offline   Reply With Quote
Old 07-17-2008, 12:18 PM   #20
Build.
Quote:
Strictly speaking, the effect of a lightweight flywheel (or the crankshaft itself or anything attached to it) is only directly related to the rate of acceleration of the crankshaft, and only indirectly related to gear selection. Depending on the HP levels, the effect could extend into the higher gears as well if the crank accelerates fast enough despite the longer gearing.
Because one makes a difference in accleration once in gear and the other doesn't (only in neutral). You couldn't actually think I didn't know they operated on the same principle......
__________________
Old 07-29-2008, 06:18 AM   #21
goin to Z town
doc2278's Avatar
Gotta agree with the wizard on this one. I had a UDP with my trubo set up. The only thing that it did was give a healther feel to the engine. no MPG increase.
__________________
he's afraid of Ducks.......
doc2278 is offline   Reply With Quote
Old 07-29-2008, 12:35 PM   #22
Send a message via ICQ to Torgus Send a message via AIM to Torgus Send a message via MSN to Torgus Send a message via Yahoo to Torgus Send a message via Skype™ to Torgus
OT: fwiw a lw flywheel isn't always the best. especially when launching...
oh and i doubt the lw pully made your spool any faster.
__________________
--Jon--
Currently driving:
03 Maxima: 40k miles, Bodykit, CF hood, 20'' Chrome DUBz, Alarm, Tint, Eclipse AVN6500, Rainbow Profi Vandiums, Boston Pro60s, 2 12'' Type Rs, Suspension, Cleared 8k HIDs w/ DDE Angel Eyes, Intake, Exhaust, Timing Adv, Custom 2 Tone Interior, x drilled/slotted/zinc rotors, SS brake lines, etc.
92 Max SE: 5 speed LSD 230k Daily Driver FTW 4DSC!!!!
Retired:
97 Max modded: BURNED IN FLAMES
96 Max modded: Sold to brother
95 Max modded: Attacked By Volvo
Quote:
Originally Posted by KRRZ350 View Post
I'm the only one showing my e-manliness to compensate for my small penis size.
