Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-09-2008, 12:44 AM   #1
KH3 by popular demand
maxgtr2000's Avatar
Send a message via Yahoo to maxgtr2000
Another turbo 4th gen setup.
Well I finally have this setup somewhat put together. There is still alot of fine tuning and cleaning up to do. Don’t stare down the engine bay too hard I got all kinda of wires that need to come off or be loomed. I also haven’t had time to redo my first projector retrofit, I need r34s.
Equipment:
Master Power t3/t4 Turbo 50 trim .63 a/r
370cc injectors
Stock MAF
Walbro 255 lph
Monza Bov
Mishimoto Intercooler 28x7.5x2.5
Tial 38 mm Wastegate
Custom front feed Y pipe
2.5" downpipe and full 2.5" exhaust
2.5" catalytic converter and 24" resonator
3" Dynomax Super Turbo Muffler
Emanage Blue /w injector and ignition harnesses
Emanage Pressure Sensor
Pivot turbo timer
Zeitronix ZT2 Full Wideband set up with boost sensor and egt
iEqqus Oil Pressure Gauge
Turbo oil feed restrictor
Dual air intake temp gauge (pending)
The fabrication work was done by Mark and the crew at Fastech Motorsports in Louisville, TN back in 05. My front feed was made and intercooler piping. I removed the intercooler piping and such and took the car to a muffler shop where they made this pipe to go from the front feed y to the cat.
I liked doing it this way because the car can be returned to n/a by just swapping out the turbo feed for the feed to connector pipe if needed.
The car was still N/A until three weeks ago while I got my parts together and stopped being lazy and such. Check my cardomain for part install dates cause they are spread out pretty far.. Doing retrofits don't help with free time either. I also moved cross country from TN to the Left liberal coast of WA state, over the years I gathered parts and read the boost forums everyday. Thanks to all the guys that helped me with information and answering my questions like Nealoc, Mardi, I30tMikeD, Choray911, Speedcrazie, and various members that shared their install pics.
Still figuring out how to use the emanage for tuning and trying to figure out the boost. I guess this thing starts spooling around 2800 rpm, full boost???? rpm? I really haven't taken it past 4k yet, still in testing phase. Ironically one of the highest psi I hit was 11 but the wg is set at 8. So I have to figure that out. I think my ks is dead. But the car feels nice with boost. The oil feed restrictor also works for me because before I was burning a little oil in boost. Now the exhaust is clean.
maxgtr2000 is offline   Reply With Quote
Old 07-09-2008, 12:45 AM   #2
maxgtr2000's Avatar
Initial Mock Up at Fastech. The turbo in the pic is not mine obviously. It was on order at this stage.
__________________
Retrofit headlight services
My VQ30DET
Emanage Blue and Ultimate Forums
There can be no peace until you possess the Prince of Peace.
Old 07-09-2008, 12:45 AM   #3
maxgtr2000's Avatar
This is how the feed looked on the car while n/a. Notice the connector pipe that runs back to the cat.
Y pipe feed during fabrication.
__________________
My VQ30DET
Old 07-09-2008, 12:46 AM   #4
maxgtr2000's Avatar
Forward feed, turbo exhaust housing, and downpipe coated with DEI high temp spray. I got pretty good prices for the spray and wrap at Summitracing.com. Still need to wrap downpipe.
Wrapped y
Turbo timer (left) and Zeitronix display temporary location.(note car was not running on that display)
The ZT2 display will be located on the steering column like Choray911's setup. Bose is coming out and carputer going in so I can do emanage and zt2 logging without a laptop. I will forego that if someone will give me an E-01 display.
2.5" Exhaust, flex, cat, and resonator. Mad clearance boyz.
You can also see a portion of the oil feed line, and the wastegate.
I am going back and forth since I have a empty hole in my dual gauge cluster. I was thinking about putting in an intake air temp gauge but I don’t race or anything so that info would just be for personal knowledge.
Here is a mini write up for this. Nordskog has a digital air temp gauge (in red led only) and it comes with the sensor. You can get another sensor for this gauge separate from another website. Get a relay and wire the sensor lead before the intercooler to prong 87a, prong 30 will be the led to the gauge. The second intake sensor’s sensor wire will go to prong 87. When the relay is off you will get the preintercooler reading, hit a switch and get the after intercooler reading. There is also a time circuit you can build found on the12volt.com that will automatically activate the relay off and on so you wouldn’t physically have to hit a switch. Just an idea, maybe its something track maximas can use.
Old 07-09-2008, 01:00 AM   #5
Send a message via AIM to 95BLKMAX
oh wow congrats man! PLEASE take some videos of this baby when she's ready for some runs
P.S. I strongly suggest, that with the silicone paint, not only to paint the pipe before wrapping (as I read you did), but also, once its wrapped, spray the wrap itself with it. This will prevent most of the moisture from ever even going through the wrap to the painted pipe to start with.
__________________
95BLKMAX is offline   Reply With Quote
Old 07-09-2008, 01:58 AM   #6
SpeedCrazie's Avatar
VERY NICE!!! Glad to see you finally got around to getting this done! I'll have to meet up with you and go for a ride! Great Work!
__________________
1995 SE VQ30DE-T
Totaled: December 11, 2004
5 Speed Conversion, Custom Turbo Kit, Body Kit, Custom Body Work, Custom Paint, Chromed Engine Bay, Coilovers, Etc.
1995 SE 5MT
Purchased: May 12, 2006
Project Car.....Details Coming Soon
1997 SE 5MT Converted
Purchased: November 4, 2006
Daily Driver with Goodies
SpeedCrazie is offline   Reply With Quote
Old 07-09-2008, 05:20 AM   #7
Beater
Tatanko's Avatar
Send a message via AIM to Tatanko
Congratulations on finally getting it done! Looks like you managed to keep some pretty nice ground clearance with your feed pipes and downpipe.
__________________
SHIFT_obsession
Tatanko's Maxima Site & VQ35DE.com
Tatanko is offline   Reply With Quote
Old 07-09-2008, 06:36 AM   #8
Awesome job, and looking very good!!
__________________
T.I.
tibal is offline   Reply With Quote
Old 07-09-2008, 06:42 AM   #9
Project Ruby......
4DRSpeed's Avatar
Send a message via AIM to 4DRSpeed
Congrats Andrew.
Looks sweet I expect some vids ASAP .
__________________
'96 Nissan Maxima SE 5-SPD - Ruby Pearl/BLK Leather
http://www.sportscarfrenzy.com
4DRSpeed is offline   Reply With Quote
Old 07-09-2008, 09:43 AM   #10
I love lamp.
maximase86's Avatar
Send a message via MSN to maximase86
Man Andrew, that looks awesome. It's always nice to have another boosted guy in the area. Can't wait to see it in person!
Though I have one question....isn't the MAF a little close to the TB? I'd be worried that when TB is closed, you might get some surging thru the MAF.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
04 Sentra SE-R Spec-V - Super Black/Silver-Black Cloth
Northwest Nissan & Infiniti
maximase86 is offline   Reply With Quote
Old 02-10-2009, 11:52 AM   #11
Send a message via AIM to JAMAICANLOVRBOY Send a message via Yahoo to JAMAICANLOVRBOY
thats real nice man.
JAMAICANLOVRBOY is offline   Reply With Quote
Old 02-10-2009, 05:40 PM   #12
Shift_Broken Tranny
congrats, lol your motor mount is just like mine
I luv your idea about doing a half feed pipe so you can out it back to n/a if needed
__________________
My Cardomain _ _Maxima runs 13.4@109
Dyno:? whp & ? wtq
Nitrous PB: 13.4@110mph
All Motor PB: 14.0@99mph
3280lb with driver, full trim, rims, spare, jack, fluids, etc & notorized proof
t6378tp is offline   Reply With Quote
Old 02-26-2009, 11:26 PM   #13
thats pretty nice man, one of the cleanest turbo setup ive seen, usually i see people have the pipes all clustered up to where you can barley see the turbo. in your car it seems like you have space to work on stuff.
__________________
absolutely stock...FOR NOW!!!!
Old 03-04-2009, 07:35 PM   #14
where did you tap in fo the oil feed line?
timbrooks77 is offline   Reply With Quote
Old 03-04-2009, 10:19 PM   #15
maxgtr2000's Avatar
http://www.stealthmodeperformance.com/oil.shtml
I used the dual outlet block fitting that tees out where the oil pressure sensor sits. On the fitting is the op switch, my oil pressure gauge, and the feed.
Old 03-11-2009, 11:37 PM   #16
Send a message via MSN to 96blkonblkse
Any dyno numbers yet?
__________________
00 E39 M5 Alpine White/Silverstone
05 G35X Diamond Graphite/Grey
96blkonblkse is offline   Reply With Quote
Old 03-12-2009, 06:56 PM   #17
any way you could show a pic of the oil return line and tell how you did that. Thanks for the info on the feed line
Old 06-19-2009, 02:44 PM   #18
wich e-manage harness u r using ? the universal ? or somthing ales ?
maxam is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
