07-05-2008, 11:08 PM
my attempt at a build thread
So i decided to rebuild my setup. Old setup has over 50k miles on it and since it was only made of regular steel to begin with, its has become a bit tired. There were a few cracks that were starting to bother me. Since i built my last setup my fabricating capabilities have changes so.. i figured i would finally apply it to my own car. With this new build i wanted to experiment with something that has been on my mind for quite some while. A "Quick Spool Valve". Basically ..My turbo is huge, and i Love the top end. Yet, i know i could really benefit from better spool. So rather than sacrifice the great top i decided to try this. To sum it all up, the valve when you first hit the gas, it will divert all the exhaust through one scroll of the turbo. This essentially changes the turbo from being a 1.32 a/r into a .66 a/r. Hopefully this mean i will get full boost sooner than 4000-4500 rpms. so.. on with the pictures.
Valve.
closed
open
headers and y pipe
__________________
12.8 @ 114 mph 14 PSI
07-05-2008, 11:09 PM
__________________
07-05-2008, 11:10 PM
__________________
07-05-2008, 11:11 PM
__________________
Got maximas?
yup.. i hope the pics explain it so far. much more to come.
__________________
07-05-2008, 11:22 PM
Looking good man.
__________________
99 GXE Auto V1 370cc injectors and Modded vb.
97 5sp SE New build Holset HX52 and spray. More to come.
91 GXE Auto bone stock beater
Led retro's Pm me
07-06-2008, 08:37 AM
Very nice, can't wait to see the results.
07-06-2008, 09:13 AM
WOW, awesome work man
__________________
OEM RIMS FTW!
07-06-2008, 10:20 AM
Very clever!!
How do you plan to control the valve?
This gives you the best of both worlds, a smaller a/r for spool up, but then opens up for better top end.
in for more results/pics
__________________
1996 Nissan Maxima 5MT 3.5 (Getting a fresh remix)
1995 Nissan Maxima 4AT "Champagne Coolie" * Sold*new home in FL
1997 Nissan Maxima "Powder Fresh" 5MT 3.5 (performance built)(*new plans*)
07-06-2008, 11:04 AM
Build.
Bad a$$! It's not too often I'm truly impressed by maxima turbo setups.
__________________
"Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing ever happened."
07-06-2008, 11:05 AM
The valve will be controlled electronically using a starter style solenoid to actuate it. the solenoid will be controlled using a circuit that my electrical engineer friend is building for me. Basically using the same map sensor voltage that my engine management datalogs, at chosen points in that voltage scale it will turn on the solenoid and then at a higher voltage turn the valve off again. The kick in and kick out points will all be adjustable. This will mean while cruising the valve will be open allowing the engine to breath as well as possible in order to maximize mileage, then once i punch the throttle and manifold pressure reaches say 3 inchs vacuum, the valve will slam shut. This in order to help spool. From there once the boost reaches say 10psi, the valve will be ordered open again. The turbo is ideally spooled at this point and the engine will have no problem reaching the ultimate desired boost levels of some where in the high teens and eventually twenty's.
__________________
07-06-2008, 03:27 PM
SLOW
It's about time...
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto Drag Radials
3.5L - I/Y/E - USIM
13.26 @ 101 - 1.80 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - stock 3.0L - I/Y/E/MEVI/JWT ECU - Totalled
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Totally Stock - winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
07-06-2008, 03:53 PM
Nice work!
__________________
'96 black Se, 5spd with grey cloth interior because leather sucks! Turbonetics T04E turbo, Spearco FMIC, Tial 38mm waste gate, HKS SSBOV, Deachwerks 570 injectors, GReddy E-manage Blue, Sard FPR, Stillen Flywheel, XTD 6 puck kevlar clutch, Zeitronix WBO2 with all the trimmings, and some other crap. TSW REVO 17" bronze wheels, Z32 brake conversion, K-Sport Coilovers with pillow ball mounts and camber plates, 84' 300ZX hood scoop, blacked turn signals, and tails.
07-06-2008, 09:18 PM
man, finally....a build thread from my little brother.
the pics dont do it justice, the fab. work is very impressive. the old setup turned heads for 3 years, and the new one should do that much better, while making the car an 11 second car finally
07-06-2008, 11:36 PM
Sexay !
__________________
07-07-2008, 12:01 AM
2nd Gen Boostinator
pretty bitchin, where did you get your exaust pipes from?...
07-07-2008, 10:28 AM
Merc signs my checks
very nice setup you having going.
Ive seen that valve setup on a camaro and it seemed to work pretty well. I htink his was done with a switch in the car he controlled or something if i recall
07-09-2008, 11:36 PM
__________________
07-09-2008, 11:37 PM
__________________
07-09-2008, 11:38 PM
__________________
__________________
07-09-2008, 11:40 PM
__________________
07-11-2008, 05:36 AM
the mounts look amazing in person...the rear mount is beautiful.
this is going to be a mean setup. this car rules a lot more now than when i drove it to high school 8 years ago!
07-11-2008, 07:54 PM
KH3 by popular demand
You have a car lift in your garage and you know how to weld.
Maaaan the possibilities. That thing looks like it will be a beast.
07-12-2008, 12:17 AM
__________________
07-12-2008, 12:26 AM
__________________
