Supercharged/TurbochargedThe increase in air/fuel pressure above atmospheric pressure in the intake system caused by the action of a supercharger or turbocharger attached to an engine.
I have a V2 Blower (6psi) on my 99 max.... and im planning on making a few long trips this summer the shortest one being over 5/6 hours away. I have stock injectors, the vortech fuel pump and riser. I only get 460kms on an avg trunk of 94 octane. A few weeks back i had a boost problem, it was turned out to be my blow off value. The BOV was actually sliding off, and boost was leaking out from the bottom. So when i was driving my car, my boost gauge would show only vaccum, and my car drove like stock again, but the bov still went off.
Now im thinking about doing a leak again from the BOV on purpose. Hoping this will get some of my kms back on long trips. Does anyone have any ideas or pitfalls i might run into any probs, or have any other ideas to get more kms?
Why not unhook your charge pipe and put a filter on it? I mean i know with turbos you can overspin the turbo this way but i odnt think it would hurt a s/c as bad. I can be wrong.
__________________
99 GXE Auto V1 370cc injectors and Modded vb.
97 5sp SE New build Holset HX52 and spray. More to come.
91 GXE Auto bone stock beater
Led retro's Pm me
Just take the SC belt off, and tie it up in the engine bay, and put your stock belt back on.
Well both of these trips are for car shows.... so don't want to have to do alot of fooling around at the shows, and explain to the judge why it's not hooked up....
I dont see how your gas mileage is so unbearable if your driving normal and not always in boost? You hit your peak boost of 6psi at 6500 right?
When does boost begin to kick in for you? 3500?
__________________ **Matty's Steel V1 Supercharger Plate Kits**
**NEXT Run of S/C Plate Kits**
...........(3) $300 Deposits Needed to do run..........
1.
2.
3. ***PM Me if your interested in being Added*** **PM Me for a BOLT KIT**
.....Build Your OWN ::V1 Starter Kits::...
.....or Finally Fix Your V2 Belt Shredding Issues.... Information and Pricing :http://forums.maxima.org/supercharged-turbocharged/334310-fs-new-v1-s-c-plate-kits.html
If you drive normal you shouldn't be seeing any boost anyway.
__________________
98 SE - Supercharged at 10psi w/the works - VQ35 coming soon...
2k SE - Stock... pretty much
88 RX-7 - Sold
95 240sx KA-T 10psi - sold
3 4th gens.... gone....
Quote:
Originally Posted by matty
Just leave it hooked up and dont boost.
Quote:
Exactly. Drive nice and easy and your gas mileage will be the same as being NA. No changes to your setup need to be made.
__________________
My Max:
99 Maxima 5 spd SE, SC'd, MEVI, Cattman Headers, KEVLO LED tails,R34 S2000 AP1 projector retro, Brembo GT BBK, Emanage Ultimate..
Well i'm going to both car shows with my team.... So I'm hoping everyone can keep it under control, with speed... at 2900 i'm already reading 0 to 1 psi.... I gotta do my Emissions test tmw, I hope i pass it..... p.s. Wizard..wha is ur lowering setup?
460kms highway or city? I barely get that city, while i was NA.
If your SC'ed 1-2psi wont affect your gas mileage that much, so keep the revs down and leave the lead foot at home.
its a little harder on a TC'ed car, as spool is not directly related to RPM in comparison to a SC. But the same saying goes, leave the lead foot at home, and gas mileage should not be that much different then NA.
__________________
VQ30DET - Holset HE351, Tial 38MM, HKS SSQ, MEVI, 3" Turbo back, Tein Coilovers, 17" Superleggeras, Full Z32 BBK
When my '96 was boosted, I had the patience for a whole tank (as a test) and I drove very conservatively. I got 25 mph with mixed city and hwy.
I haven't had the patience with my now-boosted '99 so he usually gets low 20's. My now-NA '96 gets mid/high 20s every time with very conservative driving and 70% highway.
__________________ Cleaning up the .org's grammar, one member at a time.
1999 SE, Pearl White/Black leather - Fully loaded with all factory options except TC (ABS, heated seats, side airbags, etc.) - Supercharged (322 HP / 307 TQ)
