Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Thread Tools Display Modes
Old 06-29-2008, 05:53 PM   #1
Send a message via MSN to akurtzer57
Looking for better tune than just a SAFC
Using a SAFCII and have a LM-1. Im looking for something like the AEM FIC but what is capable with my car. I have a 1991 VG30E running 370cc injectors.
akurtzer57 is offline   Reply With Quote
Old 06-29-2008, 07:02 PM   #2
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Emanage Blue?
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 06-30-2008, 05:16 AM   #3
ya but will it how much fuel can I increase or decrease % wise?
__________________
From Nebraska? Post here.
http://forums.maxima.org/showthread.php?t=554848
Old 06-30-2008, 07:50 AM   #4
Use the Search Function!!
mtrai760's Avatar
Send a message via AIM to mtrai760
http://www.greddy.com/products/displ...SubCategory=48
__________________
98 SE - Supercharged at 10psi w/the works - VQ35 coming soon...
2k SE - Stock... pretty much
88 RX-7 - Sold
95 240sx KA-T 10psi - sold
3 4th gens.... gone....
mtrai760 is offline   Reply With Quote
Old 06-30-2008, 05:45 PM   #5
choray911's Avatar
E-Manage blue has tons of adjustments.
15x15 map for mass air adjustments
15x15 map for additional injection at certain RPM and air flow levels (optional Harness)
15x15 map for ignition retardation (optional harness)
15x15 map for additional fuel when Greddy Boost sensor is attached. (optional sensor)
I have all of the above except the boost sensor, and there are a lot of adjustments that can be made. With the E-Manage Ultimate there are more options.
__________________
'96 black Se, 5spd with grey cloth interior because leather sucks! Turbonetics T04E turbo, Spearco FMIC, Tial 38mm waste gate, HKS SSBOV, Deachwerks 570 injectors, GReddy E-manage Blue, Sard FPR, Stillen Flywheel, XTD 6 puck kevlar clutch, Zeitronix WBO2 with all the trimmings, and some other crap. TSW REVO 17" bronze wheels, Z32 brake conversion, K-Sport Coilovers with pillow ball mounts and camber plates, 84' 300ZX hood scoop, blacked turn signals, and tails.
choray911 is offline   Reply With Quote
Old 06-30-2008, 07:29 PM   #6
long as i can adjust at least 30% i might be ok.
__________________
Old 06-30-2008, 07:51 PM   #7
Send a message via AIM to streetzlegend Send a message via Yahoo to streetzlegend
Quote:
(Emanage blue) Dosnt matter how much % you can adjust or not. you can make adjustments so that -3% would be the same as -30% on the safc.
__________________
Currently Under construction check my progress so far http://forums.maxima.org/supercharge...-new-post.html
Auto, TO4b(10psi), 2.1 60' 8.6@82 1/8th , 312WHP/301WTQ[/b]
streetzlegend is offline   Reply With Quote
Old 07-01-2008, 06:47 AM   #8
Send a message via AIM to 95BLKMAX
Quote:
pff, what would YOU know? after all, you ARE "banned"
Yea man the next step up is obviously the E-Manage Blue- and its a heck of an upgrade at that. Im hoping to have mine wired up this week.
__________________
NA-Built Baseline
95BLKMAX is offline   Reply With Quote
Old 07-01-2008, 05:31 PM   #9
so does it will work on my 91 im taking?
__________________
Old 07-01-2008, 09:11 PM   #10
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
what...?
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto Drag Radials
3.5L - I/Y/E - USIM
13.26 @ 101 - 1.80 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - stock 3.0L - I/Y/E/MEVI/JWT ECU - Totalled
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Totally Stock - winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 07-01-2008, 09:57 PM   #11
Send a message via AIM to MDeezy
not sure if your aware of what your saying, but with the eblue you can make fuel and timing adjustments. those adjustments can be applicable to your octane levels. still the car is recommended to run on 91 octane gas.
MDeezy is offline   Reply With Quote
Old 07-01-2008, 11:19 PM   #12
choray911's Avatar
I can make the E-Mange Blue work on my lawn mower,
__________________
Old 07-02-2008, 07:26 AM   #13
Why not tune the ecu....
Bernardd is offline   Reply With Quote
Old 07-02-2008, 03:14 PM   #14
3.5 in the works
DandyMax's Avatar
Send a message via AIM to DandyMax Send a message via MSN to DandyMax
Check out NIStune also...
__________________
1998. 3L. 5-spd. Sterling Mist. SE.
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
DandyMax is offline   Reply With Quote
Old 07-02-2008, 03:50 PM   #15
Send a message via AIM to maxmaxima91
yup, best way to tune a VG30 is with the factory ecu. Budget method, liveedit+romulator.. Best way, Nistune... There is no reason at all to run a piggyback on these cars when the factory ecu is so tunable.
__________________
12.8 @ 114 mph 14 PSI
maxmaxima91 is offline   Reply With Quote
Old 07-02-2008, 04:10 PM   #16
Quote:
what does it cost?
__________________
Old 07-03-2008, 07:41 AM   #17
nistune.com has pricing, check out xtronics.com for an emulator or moates.net and look for the ostrich.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
