Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Thread Tools Display Modes
Old 06-17-2008, 06:00 AM   #1
Twin RMT?
First of all, Ive read the turbo FAQ so no need to send me the link.
I've been reading up on RMT's and It looks like I'm going through with that towards the end of this year, so I started thinking. Would it be possible to use one front mount and one RMT to make a TT setup?
Or even convert to dual exhaust and do a Twin RMT like they have for corvettes?
I'm not saying I'd Twincharging my car this year, just wondering if that would make up for the space issue.
Opinions??
__________________
'96 GLE: Y pipe, Test pipe, Cone filter on stock mid-pipe, Debadged, Re-Wired Amber Corners, Megan Catback, Clear bumper lights, tinted tails
Coming soon: oovi, and wait for my tranny to blow...(starting to lust after 5spd)
Future plans: 3.5, RMT, 6spd
Shoto925 is offline   Reply With Quote
Old 06-17-2008, 06:32 AM   #2
Send a message via AIM to MDeezy
Space will always be an issue but its possible with a lot of planning and measuring. Mexmax max was able to make a true dual setup on his car. If you are able to create a true dual setup you could (theoretically) put a turbo on each exhaust. You would need the proper intercooler to support it. and proper hardware, dual wategates, oil pump, etc.
I feels since meximax was able to make and fit true duals then, thats gives this a 1% more chance of actually being possible.
and by the way do the VQ35...bigger smile in the end
__________________
1996 Nissan Maxima 5MT 3.5 (Getting a fresh remix)
1995 Nissan Maxima 4AT "Champagne Coolie" *Sold*new home in FL
1997 Nissan Maxima "Powder Fresh" 5MT 3.5 (performance built)(*new plans*)
MDeezy is offline   Reply With Quote
Old 06-17-2008, 11:51 AM   #3
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
Sure it's possible. Anything is possible. You could make a quad turbo, twin supercharged max if you really wanted to. My buddy has a quad turbo plymouth fury. How much unnecessary complication do you want to deal with though? How much unnecessary money do you really want to spend?
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto Drag Radials
3.5L - I/Y/E - USIM
13.26 @ 101 - 1.80 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - stock 3.0L - I/Y/E/MEVI/JWT ECU - Totalled
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Totally Stock - winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 06-17-2008, 12:07 PM   #4
Merc signs my checks
liqidvenom's Avatar
Send a message via AIM to liqidvenom
i think unless you plan on putting down in the upper 600's i dont see the worth. people are knocking on the 400whp door hard with a single rmt.
do a 3.5 and a single big-ish rmt and you would be happy
__________________
which team are you with?
liqidvenom is offline   Reply With Quote
Old 06-17-2008, 12:24 PM   #5
12's or bust
what are your goals, cause the only thing I see a dual small turbo having over a single large turbo setup is quicker spool and high cost since you will need two of everything
__________________
My Cardomain _ _Maxima runs 14.30 N/A
3.5/SSIM/N/E
Dyno:? whp & ? wtq
Nitrous PB: 13.4@109mph
All Motor PB: 14.0@99mph
Looking to join the 300whp club in 2008
3280lb with driver, full trim, rims, spare, jack, fluids, etc and notorized proof
t6378tp is offline   Reply With Quote
Old 06-17-2008, 01:21 PM   #6
00vi'dvq30devq354.5genftw
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
It would be nice to see it done.
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The Dark Phoenix 13.517@102.3mph 60' 2.0 AUTO 245 RWHP 3280lb w/driver
Fear me.
VQ35 Swap Progress Thread
ajcool2 is offline   Reply With Quote
Old 06-17-2008, 01:36 PM   #7
two turbos will make lots of torque and still a nice peak hp compared to one massive turbo it is slightly benificial due to better response and lower temprature with increadible tq, unless they are very large themselves but that would be pointless! you can get two small turbos and do them in the engine bay and they'll make probably max 450-600 peak whp but that's a guess, all depends on size and setup but I would think it around that!
Two turbos require two up pipes two downpipes two intakes, two mafs or a cold y-pipe attached to one big maf to the two turbos, you could still convert the maf to a turbomaf that can read compressed air properly before throttle. could still use one large blow off valve but I suggest 2 for it to be safer on the turbo. I'd love to see it done properly with 2 gt25 ball bearing turbos or something and two waste gates two b.o.valves and one both sides intake from turbo to top out of inter-cooler (FMIC) to throttle with one turbo on each side of the engine feeding off 3 cylinders each and converging from two down pipes to a y-pipe like I'd always pictures in my mind! It would probably make 500-600 lbfeet of torque @ like 1700rpm in a low rpm start in 3rd,4th and 5th.
I hope one day I'm rich enough to get a rwd car and twin turbo it. lol!
__________________
vq30dek turbo 2000se
mooseq30 is offline   Reply With Quote
Old 06-17-2008, 11:46 PM   #8
Send a message via AIM to streetzlegend Send a message via Yahoo to streetzlegend
I always think of the idea, but in my opinion its a waste of money. its better off finding the right size turbo that will provide low end power and keep up top end. unless you wanna do like me and just be the first to do something new lol (rmt). However i did it because it was very inexpensive and effective, twins would just be throwing away money, you can build a 3.0 or 3.5 for the money ur going to spend and do a single rmt.
__________________
Currently Under construction check my progress so far http://forums.maxima.org/supercharge...-new-post.html
Auto, TO4b(10psi), 2.1 60' 8.6@82 1/8th , 312WHP/301WTQ[/b]
streetzlegend is offline   Reply With Quote
Old 06-17-2008, 11:58 PM   #9
KH3 by popular demand
maxgtr2000's Avatar
Send a message via Yahoo to maxgtr2000
FWD FTL. I would just go with one good turbo for these cars.
maxgtr2000 is offline   Reply With Quote
Old 06-18-2008, 05:30 AM   #10
Yikes
that's one hell of a project
why not just do an AWD conversion on the maxima?
__________________
Old 06-18-2008, 08:12 AM   #11
choray911's Avatar
I can't even get the power to the ground as it is with a t04e at 7 PSI. Boost usually comes in at 3500 to 4000 RPM and the tires are blowing up already at that point. If it was a rwd, I would consider it.
__________________
'96 black Se, 5spd with grey cloth interior because leather sucks! Turbonetics T04E turbo, Spearco FMIC, Tial 38mm waste gate, HKS SSBOV, Deachwerks 570 injectors, GReddy E-manage Blue, Sard FPR, Stillen Flywheel, XTD 6 puck kevlar clutch, Zeitronix WBO2 with all the trimmings, and some other crap. TSW REVO 17" bronze wheels, Z32 brake conversion, K-Sport Coilovers with pillow ball mounts and camber plates, 84' 300ZX hood scoop, blacked turn signals, and tails.
choray911 is offline   Reply With Quote
Old 06-18-2008, 09:35 AM   #12
Send a message via AIM to 95BLKMAX
Quote:
exactly comrade!
__________________
NA-Built Baseline
95BLKMAX is offline   Reply With Quote
Old 06-18-2008, 04:11 PM   #13
240sx's are RWD
I had a dream about a VQ30DETT powered 240sx
I don't know if the engine could be used....but that's for a 240 forum
__________________
Old 06-18-2008, 04:23 PM   #14
Quote:
Originally Posted by Shoto925 View Post
Yikes
I'd never do it, just a concept! next I'd rather do an engine build!
__________________
Old 06-19-2008, 07:26 AM   #15
choray911's Avatar
240sx's are RWD
There are a few guys running around with the VQ in 240s. I'd rather supercharge a LS1.
__________________
Old 06-22-2008, 12:27 PM   #16
First of all, thanks guys for shedding some light on the whole turbo set-ups and understanding it.
I'm completely new to the whole FI set ups, so i'm still learning and understanding it, but wouldnt it be possible to be able to use two turbo's and route it into a intercooler with with two inlets and one outlet and then have that routed into the throttlebody, thus eliminating the use of a second MAF?
__________________
915Max is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
