Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Thread Tools Display Modes
Old 05-21-2008, 05:08 PM   #1
A few Turbo Questions
Ok I've been reading alot about turbos on this forum, as well as a bunch of other places for about 2 months. I'm not the type to ask stupid questions without first looking for the answers myself, but I'm not having much luck with a few specific things.
First of all I have a basically stock maxima. Y pipe is pretty much the only performance mod I've got going right now. I want to prep for turbo-ing at the begining of next year. If I decide to continue, then I will be collecting parts while I continue to learn.
My planned prep for this summer is:
3" exhaust (if possible, if not than catback)
00vi swap with injectors + fuel rail
Pathy TB
Some kind of piggy back fuel management
My questions are:
1. Am I correct in thinking that the Y pipe must be custom made and run to wherever I decide to place the turbo?
2. Is the same true for one of the headers?
3. Is it best to get a piggyback A/F controller or get the car tuned by a performance shop?
4. Will a nonrestrictive 2.5" exhaust really not work or is 3" just optimal? (planning on running about 8-9 pounds of boost)
__________________
'96 GLE: Y pipe, Test pipe, Cone filter on stock mid-pipe, Debadged, Re-Wired Amber Corners, Megan Catback, Clear bumper lights, tinted tails
Coming soon: oovi, and wait for my tranny to blow...(starting to lust after 5spd)
Future plans: 3.5, RMT, 6spd
Shoto925 is offline   Reply With Quote
Old 05-22-2008, 12:16 PM   #2
Pathy TB
My questions are:
1 yes you have to connect front and back exhaust to one pipe and the to the turbo then make the down pipe
2 idk what you mean
3 actualy what i did is i used a fuel timing control made buy spit second but you have to have a show that can tune it
4 and yes the 2.5" is enough you have to have sone restriction to it
(i'm only running 8 lbs)
example mine
__________________
02turbomax is offline   Reply With Quote
Old 05-22-2008, 05:29 PM   #3
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
You can use a afc or eb,eu. I am using SAFCII's in both my supercharged and turbo cars. If you plan to stay low boost go for a afc,but if you plan to get the most out of your setup go eb or eu. Also if you need pics on how things are ran on my car let me know i can help ya out.
__________________
99 GXE Auto V1 370cc injectors and Modded vb.
97 5sp SE New build Holset HX52 and spray. More to come.
91 GXE Auto bone stock beater
Led retro's Pm me
kzoosho is online now   Reply With Quote
Old 05-22-2008, 06:40 PM   #4
thanks alot, I was starting to think the budget and learning curve for turbos was too much, but I'm taking it back into consideration now
how much did it cost you guys for your custom piping?
__________________
Old 05-22-2008, 07:49 PM   #5
my piping cost 3000 for the pipe work the injectors installed battery located and ftc hooked up you just need the tuner turbo intercooler and injectors it will run you abought 5000
__________________
Old 05-22-2008, 10:05 PM   #6
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
1) Yes the piping would need to be custom made unless you buy one of the premade kits.
2) Same as above, you could use aftermarket headers and then modify them to make a custom setup if you wanted.
3) Any shop will need something to tune with, meaning you'll need to have a piggy back installed (or a standalone, which is complete overkill for a person just learning about boost). The only other option is an off the shelf ECU tune by JWT which makes things simple, but doesn't allow for user changes. Any changes you need, you'd need to ship the ECU back to JWT, wait for them to make the changes, then send it back. Meanwhile your car is sitting there.
4) 2.5" will work ok, 3" will work better. On a turbo car, after the turbo, there is no such thing as too large of an exhaust. Anyone that says otherwise does not know what they're talking about. You want as little backpressure as possible after the turbine on a turbo vehicle. Obviously the larger and more free flowing the exhaust, the less backpressure you'll have.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto Drag Radials
3.5L - I/Y/E - USIM
13.26 @ 101 - 1.80 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - stock 3.0L - I/Y/E/MEVI/JWT ECU - Totalled
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Totally Stock - winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 05-22-2008, 10:56 PM   #7
Carbon Fiber addict
Quote:
Originally Posted by 02turbomax View Post
4) and yes the 2.5" is enough you have to have some restriction to it
Bzzzzz.... I disagree with you. Neal said it best. Backpressure is never a good thing.
__________________
My Max:
99 Maxima 5 spd SE, SC'd, MEVI, Cattman Headers, KEVLO LED tails,R34 S2000 AP1 projector retro, Brembo GT BBK, Emanage Ultimate..
The Wizard is offline   Reply With Quote
Old 05-23-2008, 08:51 AM   #8
thanks for the help, there are just a couple more things I'm not sure on (well more than a couple, but a couple for right now)
1. does the compressed air run into the midpipe of the intake?
2. Are the '00 injectors and fuel rail big enough? or do I need 300zx injectors?
__________________
Old 05-23-2008, 09:04 AM   #9
Waiting...
Merlyn's Avatar
Send a message via AIM to Merlyn
1. Not sure if you understand the fundamentals, if you do ignore my post but a Turbo charger has 2 sides your intake side and your exhaust side.
The exhaust side takes hot air into it and spins a turbine wheel which is connected to a shaft leading into the intake side (where your compressor is). The spinning of the turbine wheel allows the compressor to take air into it and compress the air (to the amount of Boost or PSI) which is then feed through the compressor housing out to the intercooler then up through the intake (charge) piping into your engine.
The best setup is to have the exhaust gas that is going to be pushing through the exhaust housing of the turbo to be as hot as possible and to have some pressure to it. The heat is transfered into energy along with the pressure / speed of the exhaust gases, you want the largest downpipe / exhaust as possible so that the air coming out of the exhaust housing can get out as fast as possible to allow for faster spool etc etc...
here is a good picture to relate to the above terms...
Btw, I am not an expert at this stuff, so if I used the wrong term of wrong reasoning correct me but I feel my information is correct.
__________________
2002 Maxima SE 6-Speed (HLSD) 79xxx Miles - $11,000 (Reverted to Stock)
Tuning / Turbo Parts
Have a stock 5.5 Gen Exhaust in good condition? Close to Maryland? Send me a PM with your asking price
Merlyn is offline   Reply With Quote
Old 05-23-2008, 02:20 PM   #10
Quote:
So I was right, the compressed air from the turbo enters the engine via the intake piping. (which makes sense because otherwise how would it pass through the MAF ) Just wanted to be sure so I can have a clear picture in my mind.
__________________
Old 05-28-2008, 09:49 AM   #11
Are the 5th gen injectors going to be big enough or should I get 300zx injectors?
__________________
Old 05-28-2008, 11:27 AM   #12
Carbon Fiber addict
I'd go with the 370's once you go FI. The difference between 5th gen injectors and 4th gen injectors is small, and the 370's will accommodate you in the future as you seek more power. When you install the 00VI, I'd just go the route where you keep the stock injectors intact.
__________________
My Max:
Old 05-28-2008, 11:41 AM   #13
thanks Wizard!
that's what I was hoping to hear
So I need:
Least restrictive exhaust possible,
Walbro Fuel pump,
300zx injectors and MAF,
SAFC II,
and wideband o2 sensors?
That covers most of my turbo prep right?
have I missed anything important?
__________________
Old 05-30-2008, 05:23 PM   #14
Answers;
1. pending on the y-pipe and placement of the turbo you'll need to probably replace it with a custom forward y-pipe!
2. the headers can remain stock and be bolted up to a custom y-pipe!
3. car tuned by a performance shop is always the best way to go, but that doesn't mean its the only way, I have a afc-neo and a billet fmu 4:1 and a walbro fuel pump and it works well, but still needs to be tuned by a professional or at least someone with a wideband.
4. A nonrestictive 2.5" exhaust should be good till about 360whp at least and It will be a little more quite than 3", I have a 2.5" and it works great!
any questions that I can help u with u can PM me
__________________
vq30dek turbo 2000se
mooseq30 is offline   Reply With Quote
Old 05-30-2008, 05:25 PM   #15
but everyone goes there own way and the more upgrades done properly the better the car will be!
__________________
Old 06-25-2008, 07:32 AM   #16
Ti
as for the forward facing Y-Pipe, does anyone have any pictures of the set up. I know the absound has a very ncie set up, but i am not finding any "pictures" or diagrams of the set up through the search. Correct me if im wrong. I am interested in seeing how this is put together.
Also, when creating such a setup does one weld a new pipe, or just modify an existing one, such as the aftermarket cattman?
__________________
T.I.
tibal is online now   Reply With Quote
Old 06-25-2008, 08:02 AM   #17
Send a message via AIM to MDeezy
Custom Forward Y like that will be needed. add the turbo of your choice, route the down pipe to the exhaust.
MDeezy is offline   Reply With Quote
Old 06-25-2008, 08:06 AM   #18
Ti
awesome, so basically what is going on is the y is obviously "facing front", and instead of, as with the cattman, outputting to the exhaust, the down pipe takes its place and is outputted to the exhaust.
Also, is this 3" piping?
__________________
T.I.
Old 06-25-2008, 08:15 AM   #19
No you can use 2.5" piping on the forward y pipe.
nismomaxct is offline   Reply With Quote
Old 06-25-2008, 08:21 AM   #20
Ti
thanks nismo
__________________
T.I.
Old 06-25-2008, 10:29 AM   #21
Proud of his GroceryGetter!!!!
MaxInProgress's Avatar
Send a message via AIM to MaxInProgress
I did this when i was doing my turbo prep.
__________________
Shift_....Wait its SPOOLING!!!!
http://philadelphiadsm.com
http://tristatetuners.com
http://czgaming.com-----MY WORK!!
MaxInProgress is offline   Reply With Quote
Old 06-25-2008, 10:50 AM   #22
Ti
very impressive looking set up MaxIP!
__________________
T.I.
Old 06-25-2008, 11:17 AM   #23
i mean these are just the basics u might want to start with. NOw being a bit experienced with all of this i would really recommend getting the emanage ultimate because it makes life a whole lot easier. Also you dont really need to get a modified ecu if your gonna keep it below 10lbs depending on turbo. Also i dont have an afpr which i am getting one in a couple days. My max has been outta of it for the last 10 months because of a accident but im starting to rebuild her right now and changing a couple things.
Old 06-25-2008, 11:27 AM   #24
Quote:
i see you went with a 60-1 also. I have a t3/60-1 with a 70 compressor and a 63 turbine. Mine spools very very fast and still has top end. i cant wait to see yours back on the road man.
__________________
Led retro's Pm me
