05-14-2008, 11:19 PM
Won't Idle: 370cc, T-Rex Pump, Z32 MAF, JWT SC Program
It cuts out shortly after startup--if I don't give it gas, it dies immediately. It won't even idle poorly.
I haven't tried rotating the MAF 90 degrees yet (I'm still using the Stillen charge pipe), but I assumed that it would at least idle poorly positioned as it is.
What could cause it to cut out like this aside from a huge vacuum leak? I figured that it could be too much fuel at start up, but shouldn't the JWT ECU correct for the larger injectors?
Thanks in advance.
A note on my previous setup:
Previously, I was running a Vortech FMU, 3.6 in. pulley and OEM injectors & MAFs.
__________________
FS: $245 17" Rims, Full Ionic Lip Kit, Tokico Springs, OEM Flywheel, Matty V1 SC Plate. All Best Offer!
WS Y, Monza Exhaust, Tein Coilovers, Stillen STS, Exedy Stage I, JWT ECU 255 Pilot Sports on 17x8 SSR-Cs, V1 @ 14psi+
05-14-2008, 11:35 PM
SLOW
The JWT should if it's programmed for those injectors. What is your FP.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto Drag Radials
3.5L - I/Y/E - USIM
13.26 @ 101 - 1.80 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - stock 3.0L - I/Y/E/MEVI/JWT ECU - Totalled
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Totally Stock - winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
05-15-2008, 01:25 AM
I don't have a fuel pressure gauge, so I'm not sure of the pressure, but I'm using a stock FPR.
__________________
05-15-2008, 01:40 AM
Carbon Fiber addict
Sounds like it might be time for an AFPR and a fuel pressure gauge.
Did you have JWT build the ECU for you? Sounds like you bought it used from another member. If so, what are the specs of this JWT ECU??
Try rotating the MAF first and see if that solves your problem (although this is difficult with your current setup). When I installed my Z32 MAF, I blindly followed IanSW advice and positioned it upright. I've always wondered in the back of my head if I would experience the same symptoms as IanSW if I had the Z32 MAF oriented like the stock 4th gen MAF.
__________________
My Max:
99 Maxima 5 spd SE, SC'd, MEVI, Cattman Headers, KEVLO LED tails,R34 S2000 AP1 projector retro, Brembo GT BBK, Emanage Ultimate..
05-15-2008, 10:17 AM
After it dies, pull one of the plugs out. If it is doused with fuel ,then your fuel pressure is too high. Right now I'm running 25PSI with 370 injectors. I had the same prob when I first put on the Emanage.
__________________
'96 black Se, 5spd with grey cloth interior because leather sucks! Turbonetics T04E turbo, Spearco FMIC, Tial 38mm waste gate, HKS SSBOV, Deachwerks 570 injectors, GReddy E-manage Blue, Sard FPR, Stillen Flywheel, XTD 6 puck kevlar clutch, Zeitronix WBO2 with all the trimmings, and some other crap. TSW REVO 17" bronze wheels, Z32 brake conversion, K-Sport Coilovers with pillow ball mounts and camber plates, 84' 300ZX hood scoop, blacked turn signals, and tails.
05-15-2008, 10:20 AM
My JWT ecu was fairly lean at idle. I added fuel pressure to accomodate. It works fine now.
__________________
96 Pebble Beige SE
14.2@97mph as an auto
13.7@102mph as a 5spd
12.9@106mph after 3.5 swap
11.6@120mph with the S/C
Visit here for mods and dyno.
2005 Nismo Frontier 4x4
05-15-2008, 10:35 AM
I bought the ECU used. I was told that it was programmed for "up to 740cc injectors", z32 MAFs, and a customized timing map. I'll try rotating the MAFs later today.
Quote:
I just pulled one of the plugs and it was a little shinny but when I smelled it, it didn't smell very strongly of gasoline. I could just be that I'm used to the smell at this point, so I'll have my brother smell it too.
__________________
05-15-2008, 10:41 AM
When I rev the car to keep it from dying, I hear a distinct popping noise--which I assume is backfire--so, I guess I could be running lean.
One quick question, which is going to make me sound like a newbie. When redoing the fuel lines after removing the FMU, I ran it from the in tank pump, to the T-Rex, to the front of the fuel rail, and from the rear of the fuel rail to return. Is this the correct way to route it? Second, to be sure, is the fuel return line the one with or without the fuel filter inline?
__________________
05-15-2008, 10:44 AM
Quote:
What size injectors was it programmed for though? They can do whatever size you need, but it isn't an any and all program, it is specifically for one size.
__________________
96 Pebble Beige SE
05-15-2008, 10:48 AM
Quote:
I'm really not sure. I was told "up to 740cc" and was told that 370s would work; the previous owner was using 450cc injectors. I might try using my original ECU to see if I have any luck.
Carbon Fiber addict
That sounds a little fishy. It's my understanding that JWT programs the ECU for a specific cc injector. ie 370cc, 440cc, 555cc etc., not a maximum cc.
Edit: 96sleeper beat me to it. I type too damn slow.
__________________
My Max:
05-15-2008, 10:52 AM
Carbon Fiber addict
You can always call JWT, give them their serial #, and they'll tell you exactly what the ECU was programmed for.
__________________
My Max:
I'm going to contact the seller to see if he can help me sort this out. If they are indeed programmed for 740s, that could explain my lean idle.
Could someone please clarify my question about fuel line routing in post #8? Thank y'all for your help so far.
edit: I just tried the car w/ my stock ECU and it was easier to keep alive w/ the gas pedal and didn't pop as much, but I had more or less the same issue.
__________________
05-15-2008, 11:04 AM
Could someone please clarify my question about fuel line routing in post #8? Thanks for y'alls help so far.
you bought wunfastmax's ecu right? He was running larger injectors.
__________________
99 GXE Auto V1 370cc injectors and Modded vb.
97 5sp SE New build Holset HX52 and spray. More to come.
91 GXE Auto bone stock beater
Led retro's Pm me
05-15-2008, 11:05 AM
Carbon Fiber addict
Backfire usually means you're running rich, not lean.
Your fuel lines are hooked up correctly. The return line is the one w/o the fuel filter inline.
__________________
My Max:
05-15-2008, 11:06 AM
Quote:
Wasn't he running 450s?
__________________
05-15-2008, 11:27 AM
Yes he was . Have you tried to pm him and see if he had similar problems?
__________________
Led retro's Pm me
05-15-2008, 11:31 AM
Just got off the phone with Ben at JWT and he told me that if I try to run this ECU w/ my 370ccs, it will run lean at idle and pop a lot (and it's definitely popping), and will run rich throughout the power band. Looks like I'm going to have to get it reprogrammed.
Is the car driveable with the stock ECU, Z32 MAFs, and 370s?
I'm going to try flipping the MAFs and recheck my fuel lines today to see if I can get it running.
__________________
05-15-2008, 11:43 AM
Yep. Hope to hear back from him soon.
__________________
05-15-2008, 12:00 PM
Do you have a afc of some sort? I mean i think you can get away with it but i wouldnt drive it hard at all.
__________________
Led retro's Pm me
05-15-2008, 04:27 PM
Nope, I don't have an AFC. I was hoping that the JWT would take care of everything. (A local member had great results with the JWT alone, and I was hoping for the same.)
