Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Thread Tools Display Modes
Old 05-13-2008, 11:34 PM   #1
Send a message via ICQ to maxima92se Send a message via AIM to maxima92se
2.87 pulley, 440cc injectors, Vortech Bypass Valve and FMIC
Okay I am really tired but i wanted to get this thread up and running before I go to bed( Systems Analysis Final exam in the morning but I couldn't wait) Anyway here we go.
My blower has t come out so I can fix that oil leak and while its out I wanted to install the mods listed. I need to clock the blower pointing down wards when I have it off the car then here are the questions
1. I read that there are two 90degree bends on the charged side, one from the blower and another to the IC inlet.
2. I need a BOV flange and I was thinking of buying 2.5" piping (only because I hacked my original charge pipe to fit with the 00VI and it already has a flange for the BPV) but now I am deciding to go with 3" piping instead what are you takes on this size. No-one has a clear cut answer !!
3. With the stock FMU (stillen kit) and 440cc would that be enough for fuel delivery for the 2.87 pulley.
4. Would I be able to cut time from the IC install by looking for the PR CAI and using that intake to join up with the IC cold side for a quick IC install or SEE NUMBER 5.
5 A friend of mine is helping me and he was suggesting we use couplers only when we absolutely need to ie on the charged side and the IC inlet then weld all the piping to the TB on the other side. Seems kind of expensive (and I like the aluminum piping and couples, ricer look) but I wont have to blow hoses with the high boost.
Any other suggestions would be welcome. i was thinking of ordering all the stuff this weekend (IC and piping everything else I have) and get this last piece of the puzzle finalized next up will be Headers .
__________________
98 Nissan Maxima..
Mods..
Supercharged, FMIC, K&N CAI, 00VI, VAFCII, Short Ram intake, Budget Y, warpspeed high flow cat, Greddy SP2 Catback, dropped!!
Zeitronix wideband and datalogging laptop just for tuning
18x8 G35 rims wrapped in Dunlop W10 235/40/18 tires.
Z32 4piston calipers, Cobra Xdrilled/Slotted.
14lbs Super Charged Sleeper@332fwhp
SOON: RC440cc injectors, Transmission, clutch and headers!!
maxima92se is offline   Reply With Quote
Old 05-20-2008, 09:53 AM   #2
Bump!! i really need input on intake sizing. I was thinking 3" but I have to get a flange but if i get 2.5" piping I don't need the flange i will just hack my original stillen piping.
__________________
98 Nissan Maxima..
Mods..
Old 05-21-2008, 07:46 PM   #3
Personally I think the best size is 2.75' mainly because the SC outlet is 2.75' inchs. And 440cc injectors I believe should enough fuel for that motor and setup, in fact with stock 290cc injectors, 255lbs walbro, and the cartech FMU has my car running a 10.1A/F under boost with 311whp.
BTW what do you have to tune the car with??? I plan on using the EU, 440cc(No FMU) perfect size FMIC, and a SI trim SC with 2.62 pulley...Hopefully I'll see close to 400whp
__________________
Nissan lover with an TC Maxima and 700whp turbo S13..
Ghase is offline   Reply With Quote
Old 05-22-2008, 07:22 AM   #4
Thanks!!! I have the vortech FMU and walbro 255 for the rough tune and the VAFCII for for a near 12.1AF all the way till redline. When I do the 2.87 pulley I hope to be doing 11.5AF to be on the safe side. I talked to one of my friends and he suggested I use 3" piping just in case I decide to build the motor and run higher boost.
What pulley were you using to run 311whp?
How much is the SI trim going to run you?? I called vortech about a week ago and he said I had two options either a rebuild(basic if there is nothing else wrong with ther blower) or the T-trim. I asked him about the SI trim and he said I would have to buy a new blower for that (I have the V2 blower) maybe I will call back and talk to someone else but that was a project I want to do in teh winter time.
I was hoping to run 350whp with the mods I have now and an intercooler, 2.87, headers (cattman ftw), 440cc and I really agressive tune, not street tune but dyno tune.
__________________
98 Nissan Maxima..
Mods..
Old 05-24-2008, 01:36 PM   #5
My dyno was done on the 3.33 pulley. And Vortech quoted me for $700 with rebuild and SI upgrade but after re-thinking I'm just going to take the rebuild because I will be running a 2.62 pulley which is about 14-15psi, and IMO that's good enuff for a nearly stock motor. And your friend is right about the 3' piping, hell I also run 3' inches on my 240sx with a fully built, sleeved, stroked SR20det-That'll make 700whp forsure.
So GL
__________________
Old 05-25-2008, 05:21 AM   #6
Send a message via AIM to PharoNDmist
Im running 3' piping with 3.33 pulley and I'm seeing about 10 to 10.5psi with just a y-pipe, and thats with a v1 blower!
__________________
Supercharged 99 Black SE 5spd
MODS:V1 3.33 pulley @10psi\3' piping\CAI\budget y-pipe\ stock exhaust\ 1 step colder plugs NGK\Spec 3 clutch\Quaife\Fstb\Cattman-progress coilovers\Brembo Cross Drilled rotors\ Diamond clears\7%tint\ Stillen Front Lip\ Sarona side skirts\ Aluminum dash Kit\Self made rear red clears\shaved a$$& keyhole\ Colbalt guages\Panasonic DVD
PharoNDmist is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
