Finally turbo for 5th gen.
#321
nope never did and no i wasn't just dieing to man i just had to drop it in there.
i mean there is nothing wrong with the kit and the numbers i just knew the kit would make the power off of low boost
#322
You took the Altima kit and made it work for your car. What is yours putting down?
#323
#324
actually i was just running that tune that they sent me and i blew the motor and rebuilt it so im getting a three new tunes 10 psi 93 octane
15psi 93 octane and 20 psi race fuel so hoping to hit 600-800 whp
#325
And how did you blow the motor, its a very safe kit or did you go do something that you shouldn`t of like jack the boost up or something
#326
Definitely keep us updated on your new tunes. My goal is 600whp with the SFR kit and a 100 shot direct-port for the track.
#328
1swtmax, is your 6-speed HLSD?
Also, what size was the exhaust they had to upgrade to finally get all the power?
That's a sweet set up. I've been looking at that kit for a while but somehow missed this thread till now. I'm strongly considering doing this later this year using my hotshot headers as turbo manifolds instead of the stock manifolds.
I may hit you up later with some specific questions about the kit if that's ok.
#329
Matter of fact my car goes in the shop on Monday for the new tranny. To everyone out there don`t use the Stillen short throw shifter. It apparently trashed my tranny. I was told that, that short throw shifter is junk because it doesn`t really come the whole way out of gear before it starts to shift, which is really hard (and the destorying) on the sinkronizors. Just my luck. And I know someone is going to say that I`m full of it, well that is what happened to my car. So if anyone wants a Stillen short throw shifter for a 03 manual trans. you will have to go to my local land fill to get it.
#330
and for some reason with my auto and my nankang ns2, the tires dont break lose unless i use the stall and or the parking break (burn outs are great)
#331
#333
Well the new tranny is in and along with the new motor mounts and sub frame mounts everything seems really tight.
Come on spring!!
Just waiting on the front bumper to get repainted and I`m done. Can`t wait to hit some shows this spring.
Come on spring!!
#335
I don't know if you figured this out already but Toyo R888s are not drag radials. They are an R compound road race tire. I know some guys that use them on RWD cars with big power and they work pretty well on the street, but still not as good as a drag radial for launching at the track because the sidewall is very stiff on them. Also you don't want to expose those tires (or any R compound or DR) to temperatures under about 35 degrees or it will make the rubber much less sticky. I see you live in PA so that is a consideration for you.
#336
#337
Looks like a great kit. Just wanted to point that out to anyone curious about the quality of it. They even have a flex section in the hotside to give it a little give and keep the hotside from cracking.
Top quality componets too. We are VERY lucky guys that a company has decided to invest a lot of time and research on what will turn out to be prob very low production and return for them. Their Intake manifold is priced fairly as well, if not on the low side, hate to say it but its true.
Would like to know some stats about the IM. Looks like those runners are pretty short. Should be fine for FI but as said before this will prob be more of a race manifold. It increase area under the curve hopefully but will still shift the powerband up a little higher. What are you guys doing for tuning?
EDIT: Re-read the write up on the kits and saw how you are addressing tuning. You guys are getting rid of the MAF though, I'm assuming just running off the MAP and IAT like speed density. How do you keep it from pulling codes though, I know really nothing about the electronics/pcm of the Vq35?
Thanks for the compliments.We are still using the MAF.It is on the charge pipe right before the throttlebody.CNC bung is welded to the pipe.
#338
The BFG Dr's will be better for you then the R888's, in my opinion.We built this crazy widebody 750WHP BMW and it has 325 BFG Dr's on the back and this thing hooks up.This car is cary fast.The owner like to drive it on race fuel and 28-30 psi of boost daily!!!!!!!
#342
Looks like I`m going to go with slicks on my old factory rims (just the front 2 lol) cause I can haul them with me from track to track without needing a second vehicle. And for the street I believe I`m going to go with Nitto Invo 255/35/19 or 245s. Anyone used these before. I just got everything back together. New tranny install, new urathane bushings, front bumper repainted, and the Umnitza predator orion V2 (angel eyes) installed. Looks cool as chet.
#343
A little bit of an old thread, but definitely some good information. I'm looking to turbo mine and this seems to be the only kit produced for it now. I just think that ~$6k W/O labor is quite pricey.
1swtmax, if you don't mine me asking, how much did this kit run you with install? If you want to go with more boost later, can you do that with the engine management it has or do they send you more maps? How does that work? Do you think it would have been cheaper to piece everything together and do a UTEC or something? Really looking for some answers. Thanks man, enjoy the car!
#344
As far as price I have about $7500 w/o labor cause the car also got a 3" stainless steel exhaust. Labor I didn`t pay for cause it being a test car for the kit. I know the engine will not handle more boost than 10psi which I can control with the Greddy profec mounted by the gear shifter. As far as the rest of your questions dunno. I can tell you I don`t have the knowledge or the patients to mess around with cars. Construction is my trade. So I would tell you to call Tim from Speedforceracing. He can help you with any questions you might have.
But I will comment. The car runs just perfect. It is really fast. Can`t wait to get to the track.
Hope that helps you, but honestly I would call Tim he can diffently help you with your questions.
#345
VQ30DET ; the turbo setup for this is fine for nissan maxima VQ30DE .
http://www.turbocare.co.nz/nissan-vq...turbo-upgrade/
#346
fair enough to remove my post
, any turbo can easily fit any car , only have to lower compression if running high boost. dont know why my post got removed "cleaned up" but reality is bigger the displacement of engine (eg torque ) the bigger the turbo you can have without lag. thats why diggers have shuge turbos. so for 5.5 gens if its 30 go garret 28 if its a 35 go garret 30 , . super charger and small turbs is probably best set up .
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
