Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Thread Tools Display Modes
Old 05-10-2008, 10:42 AM   #1
TD04 Turbo on a VQ30DE?
A friend of mine is thinking about building up his WRX and offered to sell me the turbo for cheap. It's a Mitsubishi TD04 and I was wondering if that could be used on a VQ30DE? I understand that it's recommended for 4cyl applications but I couldn't find a solid answer. I'm not looking for a lot of boost here, probably only about 7 or 8 psi. A friend of mine is getting a Mustang GT (parents are buying him one that is) and I'd love to wipe the smirk off his face.
I'm researching as much as I can about turbos and looking at different options at this point, I don't have a ton of cash but I'm willing to make it a lengthly project if need be. I'm still working on understanding compression maps, but here is a link with the TD04 listed on it.
I am new to this so any advice is appreciated.
http://www.rbracing-rsr.com/turbosupermaps.html
__________________
'96 GLE: Y pipe, Test pipe, Cone filter on stock mid-pipe, Debadged, Re-Wired Amber Corners, Megan Catback, Clear bumper lights, tinted tails
Coming soon: oovi, and wait for my tranny to blow...(starting to lust after 5spd)
Future plans: 3.5, RMT, 6spd
Shoto925 is offline   Reply With Quote
Old 05-10-2008, 11:37 AM   #2
00VI Guy
Tatanko's Avatar
Send a message via AIM to Tatanko
Quote:
Then a turbo for your Maxima simply isn't going to be a good option. You could gather parts over time for a rear mount setup maybe. Define "not a ton of cash."
Also, TD04 isn't specific. Tons of turbos are based around that.
__________________
SHIFT_obsession
Tatanko's Maxima Site & VQ35DE.com
Tatanko is online now   Reply With Quote
Old 05-10-2008, 12:36 PM   #3
I was thinking about spending about 3k or so over a period of about 6 months. I did some digging and found out that the turbo I was referring to would be a TD04L-13T
I'm not sure on the turbine size, but one website said .51 A/R
__________________
Old 05-10-2008, 01:20 PM   #4
ewuzh's Avatar
Send a message via AIM to ewuzh
Don't do it. It's a fairly lousy turbo to begin with and it's way too small for a 3.0L! You're going to be spooling at like 2000, dying off falling out of efficiency after 5000rpm, and then choking your top end.
__________________
ewuzh is offline   Reply With Quote
Old 05-10-2008, 04:06 PM   #5
how are we rating this compressor inefficient. If any one does their research they would see that the 6a12tt used two 16g turbos. so with a little time and real effort this would be possible. but go with two and tear the tread off the tires!!!!!! Good luck!!
Romey is offline   Reply With Quote
Old 05-10-2008, 04:37 PM   #6
Turbee'd
chopstix2nrz's Avatar
Send a message via AIM to chopstix2nrz
Quote:
he is only getting one and is probably doing a budget build
__________________
00' Maxima
95' 240sx sr20det
chopstix2nrz is online now   Reply With Quote
Old 05-10-2008, 05:13 PM   #7
00VI Guy
Tatanko's Avatar
Yeah...TWO turbos that are each bigger than the ONE he's going to use.
__________________
SHIFT_obsession
Old 05-11-2008, 09:14 PM   #8
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
What in the world does using two 16Gs have to do with using a single 13T?
To the OP - That turbo is just plain too small. Pointless - waste of effort. Spend $250 on a used 50 trim or something if you really want to do a budget build that is worth the effort.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto Drag Radials
3.5L - I/Y/E - USIM
13.26 @ 101 - 1.80 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - stock 3.0L - I/Y/E/MEVI/JWT ECU - Totalled
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Totally Stock - winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 05-12-2008, 06:54 AM   #9
Thanks for the help nealoc187. I think I'm gonna do an oovi swap with injectors fuel rail and pathy tb, finish off my exhaust and do my research. Then I'll start collecting parts from there.
__________________
Old 05-17-2008, 08:29 AM   #10
Send a message via Yahoo to nwell2k3
When you are ready. Look at Master Power Turbo's. You can pick them up for $400 to $500 new. The only thing is, they are not made to order like Garrett and Turbonetics, you have to find one to fit your needs. WHat you do is, have Turbonetics spec out a turbo for your needs and then look for a Master Power with those specs. Or look for a used turbo. I have found used turbos on dsmsource.com..
Good luck with your build....
__________________
nwell2k3 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
