vq35 Forged Rods
Old 04-18-2008, 04:07 PM
MattyBlacc's Avatar
vq35 Forged Rods
Im currently building up my 3.5
and i was lookin for a set of Forged rods for the motor.
just wondering if you guys can help me out price wise and quality.
i saw a set off of stillen.com
http://www.stillen.com/product.asp?i...N&model=MAXIMA
wondering if these are pretty good and will hold up.
the motor is being built for boost and before i order these i just want to make sure im ordering the right thing. i dont want to waste time and money.
thanks for your help.
are there any other brands that run for the same price??...any other websites that have them cheaper???
MattyBlacc is offline
Old 04-19-2008, 12:55 PM
dot dot dot ...
NmexMAX's Avatar
Stock rods are forged
NmexMAX is offline
Old 04-19-2008, 12:58 PM
'Trynna' is not a word
mtrai760's Avatar
ANY website is going to have cheaper prices than Stillen.
mtrai760 is offline
Old 04-19-2008, 07:38 PM
03BlkSETE's Avatar
If you are not reading up on www.my350z.com, you should. Tons of info on built motors and tons of vendors. Good luck.
03BlkSETE is offline
Old 04-19-2008, 09:00 PM
MattyBlacc's Avatar
aftermarket....
Old 04-19-2008, 09:09 PM
dot dot dot ...
NmexMAX's Avatar
I know, I was just being a smart pooper.
NmexMAX is offline
Old 04-20-2008, 06:35 AM
MattyBlacc's Avatar
nothing new....lol
any websites or links? i have a couple but wanna see if you guys have some different choices for me to look at..
thanks for the help.
Old 04-20-2008, 06:57 AM
mforrest100's Avatar
Please search here:
http://www.my350z.com/forum/forumdisplay.php?f=370
All I can say is be patient. I found a set of Brand New Eagle Rods and Arias Pistons for $900 from a member. A lot of guys on that forum buy parts for builds and don't end up going thru with it. To be honest, I hope you are getting pistons as well for your build. If you are stuck between making a choice between pistons and rods, get the pistons. The rods are strong enough for the power you want achieve because you shouldn't be going for more than 450 whp. Reason being is its a FWD car. Anything past that is pretty useless for the street. And you definitely need a great EMS. Also search, in the same forum for that. Talk to "Jime" on this forum about the UTEC engine management system. They go for about $600 - $700 used and is a great tuning system. Another resource is ebay. Check this out:
http://cgi.ebay.com/ebaymotors/Wisec...QQcmdZViewItem
Good luck in your build.....
mforrest100 is offline
Old 04-20-2008, 07:11 AM
nismology's Avatar
Eagle Eagle Eagle.
nismology is offline
Old 04-20-2008, 07:13 AM
nismology's Avatar
Originally Posted by mforrest100
Please search here:
I'd go the opposite way. The rods are more of a weak point than the pistons, IMO.
Old 04-20-2008, 07:23 AM
SLOW
Nealoc187's Avatar
Eagle rods fo sho. Pistons of your choice. You can find combos on ebay for just over $1000.
Nealoc187 is offline
Old 04-20-2008, 07:28 AM
I would go pistons to lower the compression. You know that the stock rods are more the capable of handling the power output that the person may be trying to achieve.
Old 04-20-2008, 08:12 AM
nismology's Avatar
If the question is "which of the two is more likely to fail?" the answer is the rods, easily; the stock compression ratio notwithstanding.
Old 04-20-2008, 08:52 AM
OK. I hear you.
Old 04-20-2008, 07:27 PM
03BlkSETE's Avatar
Here's a link to Z1 Performance.
http://www.z1auto.com/prodmore.asp?m...ne&prodid=1538
The owner is Adam. He seems to be one of the most knowledgeable and level headed of the vendors I've read about in the 350z forums.
+1 on the 350z classifieds. Lots of goodies for good prices.
Old 04-21-2008, 12:54 AM
MDeezy's Avatar
Please search here:
utec works on the 5.5th gens?
I heard a member got it to work with their 6th gen but figured 5.5th for good EMS are pretty much limited to the EU, (excluding standalones).
MDeezy is offline
Old 04-21-2008, 04:59 PM
MattyBlacc's Avatar
I already have my mind set on a choice of pistons. i will be going low compression. (8.8.1)
^^^^from Z-1auto.com
Just wanted to see what you guys think about the rods.
"MDeezy, Diymaximakid, and myself are taking our time with this build. both top and bottom end will be fully built.
Im purchasing a Utech EMS along with a harness that is made for the 5.5th gen thanks to another "org" member. Im lookin to achieve around or should i say close to 500whp. thats it. i will not go any higher. lol
Old 04-21-2008, 05:12 PM
MattyBlacc's Avatar
Currently Active Users Viewing This Thread: 2 (2 members and 0 guests)
MattyBlacc , streetzlegend<----wuddup mang?
Old 04-21-2008, 05:24 PM
03BlkSETE's Avatar
Hmm, is that org member willing or planning on making more harnesses?
Old 04-21-2008, 06:09 PM
MattyBlacc's Avatar
i can find out for you..
im logging off now..ill pm you before i go
Old 04-22-2008, 09:02 AM
dot dot dot ...
NmexMAX's Avatar
http://forums.maxima.org/showthread....986&highlight=
NmexMAX is offline
Old 04-22-2008, 09:24 AM
Not sure to be honest. I thought it was done on an Altima which is why I thought it could be done on a 5.5 gen....
Old 04-22-2008, 09:48 AM
dot dot dot ...
NmexMAX's Avatar
02 - 04 Altima = Same software package as 02 - 03 Maxima
05+ Altima = Same software package as 04+ Maxima
04+ Maxima Software = identical to 350z (non HR) software package
Jime got it (UTEC) to work on his A33B ECU (5.5 gen ECU / software). It takes some wiring, but it can work. For the 6th gen guys(04+ Maxima) it is PLUG N PLAY, no wiring needed.
NmexMAX is offline
Old 04-23-2008, 04:53 PM
MattyBlacc's Avatar
youre right. i do remember that silver atlima boosted with utech.
Old 04-24-2008, 06:08 AM
dot dot dot ...
NmexMAX's Avatar
What year was it?
NmexMAX is offline
Old 04-24-2008, 05:44 PM
MattyBlacc's Avatar
dam..i honestly cant remember but i know it was a 3.5.
im assuming he had a sloppy tune or not so good of a build...he was pushing 10-12psi and was only putting down 300+ whp....it was less then 400hp...
HAS ANYONE SEEN THE TURBO 5.5TH GEN ON THE NYC FORUMS?...I HAVE YET TO SEE THE VIDEO..OR STATS ON IT. i hear its something crazy like 430+whp @ 7psi....true ?
Old 04-25-2008, 08:28 AM
wat
AceofSpds's Avatar
Ive seen some videos of it driving, it really doesnt look like its at 430 at the wheels. For the most part a majority(not all) of the posters from the nyc area with a built car dont like to share their info on their build or anything except possibly though pm. Apparently keeping stuff secret is a big deal over there even though after one or two pulls on the street most people are gonna know what you have anyways but w/e. Or you will hear allot from "my boy" but not the person who owns or built the car. But try PM's.
The altima you are probably talking about is the show car.
AceofSpds is offline
Old 04-25-2008, 03:12 PM
MattyBlacc's Avatar
yea..i honestly didnt believe those stats anyway. just he/she say crap.
yea...up in new york the racing scene is crazy. when people find out what u have done to the car....if they cant afford it, they'll try and take it.
born n raised...i should know.
you wouldnt happen to have a link to those videos would you?
Old 04-25-2008, 03:33 PM
3.5 in the works
DandyMax's Avatar
Same VTC maps?
DandyMax is offline
Old 04-25-2008, 04:30 PM
dot dot dot ...
NmexMAX's Avatar
Originally Posted by DandyMax
Same VTC maps?
I apologize, that is incorrect.
I should have clarified; basically, the ECU’s (Z33 & A34) are interchangeable (connectors are the same).
No, A34’s have A33B CVTC maps.
NmexMAX is offline
Old 04-25-2008, 06:20 PM
3.5 in the works
DandyMax's Avatar
That's what I figured...
DandyMax is offline
Old 04-27-2008, 09:30 PM
maximariceboi's Avatar
another boosted 5.5 gen? =] are you doing .02 overbore?
i saw a few people on my350z selling forged pistons for about 500bux.
maximariceboi is offline
Old 04-28-2008, 06:20 AM
dot dot dot ...
NmexMAX's Avatar
Forged pistons @ 0.02" OB?
NmexMAX is offline
Old 04-28-2008, 07:38 AM
yes, forged pistons .020 ob 96mm...
less than $600 for wiseco pistons that are 8.8:1
mattyblacc - I saw a set of Arias pistons stock bore 95.5 on my350z going for 500 shipped. If I were you...i would jump on that asap..
Old 04-28-2008, 06:44 PM
MattyBlacc's Avatar
im jumping on em..hopefully everything goes well..
i really appreciate it bro...thanks alot
Old 04-28-2008, 10:47 PM
np
James92SE
142
01-02-2024 09:23 AM
hcarter1112
42
07-18-2022 03:35 PM
mclasser
22
11-12-2020 01:58 PM
knight_yyz
11-01-2015 01:34 PM
londonflu
09-19-2015 02:33 PM
Quick Reply: vq35 Forged Rods
