VQ35 Midmount Turbo...
#121
thats good to hear bro. sucks that you had to go thru that whole ordeal. why are you replacing your neutral position switch?
why has no one answered my turbo question? anywho.. still readin and searchin bout turbos and what would fit what im lookin for.
#122
I have had my Transmission down about 5 times, and during the last install of the transmission I broke the neutral position sensor, I honestly wouldn't care about it but it throws a CEL and I need to pass emissions...
#124
My plans were to hit full boost at 4k, prefer to not hit much boost until 4k so that I can grab traction and not rape my already sad gas millage...
Really it comes down to application though :-D
#126
Turbo spools from the low 3000s but it doesnt make full boost until 4k. YES it does help plenty with traction, and gas milage is actually the same as with NA. If you floor it everywhere like I did the first 2 weeks, yea u'll get 12-13MPG, but now Im getting about 18-20mpg (just as good, and slightly better than my NA average).
But in MY case its not because the turbo is that big that it doesnt spool up until 4k. Its that damn SSIM (arg!)... it works GREAT for NA, but for boost.... its kind of annying to know that the turbo is spooling, you COULD already be hitting full boost but you WONT because the IM you gutted doesnt flow good until 4k, so all of a sudden at that RPM the boost just rockets up to full boost and the steering wheel wants to fly out your hand, LOL.
Im not sure if you have an SSIM but if you do, you may end up lookin for either IM spacers or buy a non-gutted IM. Personally I have a Z33 IM sitting behind me right now awaiting installation. Im not expecting to make any power from it over my SSIM, but simply to reshape the powercurve for a more linear extraction of power.
#128
It's sitting in the backseat, right now.
Here's the basic idea: http://mdpagi.com/merlyn/TurboExhaust.png
if you do it like that you gonna have so much turbo lag you will come in to boost at abot 4200 4500 rpms
#129
We found a nice little pancake filter that'll be right on the turbo from K&N, I believe it was. I'll try to find the part number, I saved it in Google Docs somewhere.
Here it is: K&N RX-4130-1
Well we've already mocked it up under there, surprisingly enough there's actually a decent amount of clearance around the turbo.
It's a possibility...looks appetizing, doesn't it?
look at mine
#130
#131
yes it will the exhuast has to go to the turbo (4-5 feet) reach spool and then suck/send air to the intercooler though the charge piping and in the intake (6-7 feet) so on estimate it has to go though 10 - 12 feet of pipe so yes bad turbo lag bad spool up time
#132
actually, my piping is probably the same length if not shorter then yours...
I am going side mount intercooler, thus my intercooler is not in the front, and it will be a straight line from the turbo to the engine (aside from the 180 degree at the intercooler) and the most exhaust restriction I really have is a 180 degree to the turbo.
AND, if you cared to do your research no one has ever experienced any noticeable lag, if any at all from a rear / remote mount turbo setup versus standard setup, my setup is a better flowing setup then yours, and thus I believe you need to keep your mouth shut.
you have a reverse-y setup, where you are feeding exhaust under or around the engine to the turbo then down and back with a front mount intercooler which is always full of 90 degree bends... my setup is straight back just like any exhaust... trust me I have done my research and if any lag is there at all it will be virtually unnoticeable
#134
Okay, filters get dirty.
When that happens, you clean them.
Problem solved.
Cliffs: If you don't know what you're talking about, stay out of the AP section. That is all.
#138
Obviously I will have upgrades tires by the time the turbo goes on, but let me think about this...
If I raise my redline to 7100 RPM... and I don't hit boost till 4k hell even start building boost till 4k... let me jump back to all my times at the track... when I shift at redline, I usually plant myself at about 4,500 to 5,000 RPM if I am not mistaken... must be fun hitting full boost at 2,500 or whatever you hit it at and have it drop off at 5,500 to 6,000...
again you have your setup, I have mine but in reality you have NO clue about turbos what so ever and prob just paid a shop to make you a kit without putting any plans into the kit aside from the size of your intercooler piping which I hope you are running .5" piping or else you might run out of boost... *sarcasm*
#139
#140
I don't plan to hit boost till about 4000 RPM... I have a Turbonetics 62-1 with a .96 A/R that is a VERY large A/R which allows for more top end power with the loss of low end power... if I was to go with a .63 or something of the sort I would build boost lower but I am not sure if you have ever actually driven your car, but personally, I don't need low end power at all, hell I can barely keep an axle on my car let alone grab any sort of traction.
okay i did the kit and i don't lose boost
#141
#143
Gotta do what you gotta do when a moron tries to argue with me in my thread about things he doesn't even know about... I don't like false information to go in my threads and thus I will shut them up. No worries, he has proven in under a day or 2 that he is a complete moron.
#144
#147
#148
Well, here is an update, won't say it is good news... but it is an update...
My transmission fails, or I fail at driving or a mix of both, maybe I just beat my car too hard NA... anyway, I am buying a 2006 HLSD 6-Speed (to replace my 04 HLSD 6-Speed that already replaced my Open Diff 2002 6-Speed).
That is going to put a pretty dent in my pocket but I feel more comfortable doing that then rebuilding my transmission again especially since I can try to build the 04 HLSD up to handle power, but with that I am also getting a new clutch / flywheel surface because I don't ever want to take this transmission off.
From there we will see how the car reacts and how it drives with the new RAxle as well...
#150
New Update:
The transmission is on its way to Dave B (2006 HLSD 6-Speed) and I am in the works of getting a used Cusco Twin Disc Carbon Clutch.
I really don't need the power of the Cusco Twin Disc, but lets just say, I might get a really good deal on it and I want / need a new clutch anyway. I will keep everyone posted. We are 99% sure the 350z Twin Disc will fit the Maxima aside from the dowel location which we will take care of. Hope to have everything here and ready to install in 2 weeks or so.
#152
Got some pictures of the Cusco how it sits now and also inside my transmission. Everything looks like it will work so I am probably getting that (which will force me to sell my Fidanza Lightened Flywheel and Spec Stage 2 Clutch with 5k miles on them)
#154
The best prices I can find online for brand new parts for the 2 are...
Spec Stage 2 Clutch / Pressure Plate - $469.56
Fidanza Lightened Flywheel - $519.99
(That was from a froogle search)
You can buy a Fidanza Replacement Friction Plate for like $60~.
I would say $500 for the 2 with 5k miles on them? I have never sold used wear items even though the flywheel really isn't wear since you can replace it... If anyone thinks that is outrageous give me a heads up but basically 50% of used items? *shrugs*
This is the insert (part number 221001) even though it fits the Evo that is the part # from Fidanza's parts catalog. $41.99
http://www.maperformance.com/store/p...roductid=17907
#155
It's not that late; on my old setup, my t3-t04s 60-1 hit full boost ~3500 rpm and that's on a VQ30. FWIW, I think I was the first one running a 60-1 turbo on a Maxima (this was over 4 years ago). Everyone else at the time (not that many to begin with) had T4's on a PFI kit or T3/T04e's. When I did it, everyone told me that it wasn't going to work well; the turbine and compressor housings had too much of a difference in size, it wasn't efficient, blah blah. But it actually worked very well for me. Full boost came on later than on a friend's turbo we built with a T3-T04E, but it resulted in my car having better traction. His car would lose traction much easier than mine. Plus a 60-1 is a lot of fun on the highway when the car is alread loaded.
A friend of mine bought my car and transferred the turbo to his Maxima. Euromaxima is his SN I think. He's done a lot of work to the setup since he's owned it.
#158
Not so much gave up, just moving to different things. If I had more time the turbo build would have already been done. The selling of it had nothing to do with the turbo setup at all, more so the fact that I am going to pay off a lot of debt and probably pick up a G35 6-speed Coupe. I am tired of modifying my DD.
#159
i must say i am a little concerned on your choice of filter..i know you will be limited on space but i had similar issues with my other car (not a maxima) and i was using a filter close to that one a bit larger and it sucked the element in under boost..just in case you are curious my turbo that i am talking about is a 60-1. just be thinking about this while your at it.
