Little black box connected to Auxiliary Fuel Pump Switch?
Hi guys,
I was planning to take off the auxiliary fuel pump pressure switch that came with the V2 kit and noticed that the red wire from it was attached to a small black square box (circled in red). The yellow wire wasn't attached to anything as you can see and the black wire went to a ground. What's the little black box all about? It has the name Siemens on it. I didn't see any writeup in the Stillen instructions about it.
Licensed to Spell
:o)
Originally Posted by BlackCat
No idea! I'd better look up your notes.
You're right, the Stillen V2 instructions do not mention the installation of the auxiliary fuel pump relay (the V1 instructions do).
Lol! Thanks guys!
I see now that the relay was listed under the Stillen Auxiliary Fuel Pump Electrical Assembly list. I guess I can just cut the connections to the relay?
Originally Posted by ptatohed
Which yellow wire are we talking about? The yellow wire on the auxiliary fuel pump pressure switch need not be used. The yellow wire on the auxiliary fuel pump relay should be connected to the OEM relay by the driver side kick panel.
homewrecker
08-24-2015 08:56 PM
MaximaDrvr
08-19-2015 08:20 PM
Viralkill
08-17-2015 10:54 AM
