Is HKS the only maker of AN fuel rail adapter?
Originally Posted by Tatanko
Those aren't AN, though, Wizard. Those are barbed fittings.
Blackcat, does it have to be AN fitting? Upgrading to high pressure fuel lines? or?
Lol..sorry I should have mentioned that I already have sxr7's barbed end adapter.
Been cruising the net looking and found this:
http://www.dsmparts.com/customer/pro...cat=164&page=1
Would a DSM part fit? It certainly looks the same.
Reason I'm looking is because I had a close call yesterday morning...
http://forums.maxima.org/showthread.php?t=532895
Just found this diamond shaped one for only $29.95:
http://www.3sx.com/store/comersus_vi...dProduct=24518
I got mine from here: http://www.240sxmotoring.com/furaread6co.html
I was waiting to install it and make sure everything fit okay before I posted it up though. It is an HKS fitting despite what is pictured.
Originally Posted by wunfstmax
Thats what I was fixing to say, is that I got my fitting from weapon-r, and I thought they sent me the wrong part because it said dsm. It fits perfectly though no problems.
Could you tell me what the distance is between the two screw holes, center to center?
Originally Posted by BlackCat
Looks good! Shipping is $15 extra for me.
I dug through my box of car parts and found the stock adapter. Its about 33cm centerline to centerline.
Got info about the DSM part from FuelInjectorClinic.com and learned that it won't fit. The 2G is closer (about 36mm) and the 1G is further (about 48mm).
I smelled gas leaking again when I fired up the car this morning so I had to bus it to work. I'm not happy about that adapter!
did you ever get to check and see if it fit. I had been searching for an AN fitting for our rails, but still no luck.
Yes, it fits. I installed mine yesterday. I still want to wait until I get fuel pressure on it before I give it a 100% endorcement, but it went together snug and looks like it should work. The allen head bolts are a nice touch as well.
Originally Posted by MDeezy
sounds good. I'll await the official green light before ordering.
It will probably be about 2 weeks, just as an FYI. Car is slowly going back together now.
I did not have to re-drill anything, mine fit perfect.
Just so we are clear, I got mine from here: http://www.240sxmotoring.com/furaread6co.html
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
magiconthetire
10-26-2015 09:03 PM
worldwiderecognized
09-30-2015 01:16 PM
