Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-08-2007, 09:08 AM   #41
3.5 in the works
DandyMax's Avatar
Send a message via AIM to DandyMax Send a message via MSN to DandyMax
Just got back into the country and saw this. Thanks for a great post Neal (and the other contributors too).
Timely too, what with the Quaife GD going on right now and me trying to decide what I'm going to do longer term about my tranny...
__________________
2000. 3L. 5-spd. Black on black. SE. (DD)
1998. 3L. 5-spd. Sterling Mist. SE. (fun car)
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
DandyMax is offline   Reply With Quote
Old 03-08-2007, 08:16 PM   #42
Quote:
JClaw brought up a very valid point in a discussion we were having - that point was that the 6spd is available with a Helical Limited Slip Differential - a superior design to the viscous limited slip so coveted by many. For some, this is a strong selling point. No need to buy a Quaife. Also better reliability (VLSDs will fail if overheated. Some last 150k miles, others have ruined theirs in a single day of hot lapping around a road course in high powered cars that like to spin one tire coming out of corners - or so I've heard)
Quote:
All of these procedures could also be done to the 6spd if one wanted, and of course you’d end up with a transmission at least a bit stronger than a built 5spd would be.
If one is to forgo the aftermarket gears (the last straw - for the hardcore only AKA people trapping in the ridiculously high 120+ mph club like you), and deburr+shot pen, then the 6-speed is the most polyvalent, strongest, most convenient option.
So IMO, I would suggest going with the 6-speed if one is serious - perhaps 400WHP serious - but not hardcore enough to take the final step and buy the aftermarket gears. Then the 5-speed with the big dog gear set is the strongest option.
But for all that was mentionned (the HSLD, the gear ratios, the stronger stock gears right off the bat) I would rock the 6-speed.
Quote:
Originally Posted by MardiGrasMax
You da man Neal, take'm into the 10's (Or at least into the deep 11's hundreds and hundreds of times with no more broken gears!) For he's a jolly good fellow... sing it with me... that nobody can deny!
True - I dont even own a maxima anymore but that post was so informative and well put together that I couldnt help but read every single word in it. Nice work Neal!
And dude - please tell me you aint quitting till 10.99 shows up on your timeslip with a stock VQ30
JClaw is offline   Reply With Quote
Old 03-08-2007, 08:26 PM   #43
Super Moderator
Send a message via AIM to nismology
Quote:
No input shaft and diffy bearings issues that we know of yet either.
I dunno if you saw my post or not but: http://forums.maxima.org/oldpost.php...2&postcount=10
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
nismology is offline   Reply With Quote
Old 03-08-2007, 08:42 PM   #44
Yep. Because of the better gearing it eats up the extra drivetrain loss. 1 more point for the 6-speed (now we just need to find out if they make aftermarket gear sets for the 6-speed, the same trans is used on the Tiburon and other cars definately).
The 3-4 shift is a problem on the 5-speed too. With the stock 3.82 gearing, if your car is NA you will NEVER be able to fully take advantage of 4th gear because it tops out at over 125 MPH and the moment you are trapping higher than 100, 105 mph TOPS, you have to shift into 4th.
With that said, if one really wanted to do an ideal, efficient, bulletproof 5-speed build for a lightweight NA car, this is what I would do:
OPEN Diff 5-speed transmission
Quaife
4.471 Axxess ring and pinion
Shot penned and deburred 1st and 2nd gears
PPG 3rd and 4th gear sets
0.74 1993-2001 Altima 5th gear for reasonable highway RPMs
The 4.4 final drive actually relieves the stress from the drivetrain because it makes it easier to take the car from a complete stop to rolling. And of course it enables you to FULLY use 4th gear without having to trap 120+mph.
To note that the 4.47 gear will ONLY fit on an OPEN DIFF differencial (thus the Quaife too) because it uses a 10 bolt pattern VS the 14 bolt pattern on the VLSD tranny. I know this first hand, Ive opened my trans 3 times (it was 2 summers ago already). And finally, 3rd gen guys are often forgotten but the 4.47 gearing WILL work on any 1985-2001 5-speed Open Diff.
Krismax, Im looking at you
Old 03-09-2007, 03:47 PM   #45
How does the nissan HLSD compare to quaife?
hacim105 is offline   Reply With Quote
Old 03-09-2007, 05:45 PM   #46
Super Moderator
You do that and you're looking at like 4000+ RPM at 80 MPH.
__________________
Old 03-09-2007, 08:35 PM   #47
Quote:
Nope. With the stock 5-speed you turn 3000 RPMs at 75 MPH. If you replace the stock .795 5th gear with an Altima .74 5th gear and go with 4.47, you will turn 3250 RPM at 75 MPH instead of 3000 flat. Not the end of the world by any means. God knows the 4th and 5th gears on the 4th gen are too close to one another anyway. I bought my Altima gears for like 40 bucks each LOL
But I forgot to add that in my post so Ill add it now.
Old 03-09-2007, 09:03 PM   #48
Super Moderator
Well i was basing that on the fact that with the 5-speed the rpm's are around 3300-3400 @ 80. With such a drastic shortening of the final drive ratio the RPM's @ 80 would be around 4000 or more. I was just speaking in terms of stock gear ratios.
Old 03-09-2007, 09:21 PM   #49
Mine was 3000 flat at 120 kmh which translates into 74 mph. And we all know the stock tach is optimistic. That was on WORN stock SE Yokohama 215-60-15 tires. In all cases the RPM rise with the .74 5th gear will only be a little less than 300, which aint nothing to commit brutal suicide about.
Old 03-09-2007, 09:42 PM   #50
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
Quote:
Fundamentally they are the same. The Quaife is a helical planetary gear limited slip differential just like the OEM nissan HLSD. Whether or not there is a significant strength difference between the two, I don't know. I haven't seen inside either differential.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 03-10-2007, 06:31 AM   #51
Thats why the 6-speed is such a good deal. You can buy two 6-speed transmissions for the price of the Quaife alone. One in the the car and one spare that you can shot pen meantime and ready to go in if you blow 3rd cause youre putting down 400+WTQ.
Old 03-21-2007, 05:31 PM   #52
96sleeper's Avatar
Send a message via AIM to 96sleeper
Getting closer, one down, one to go. Those other gears sure do look weak compared to the new ones...
The new input shaft should be here tomorrow and I will send it out to be treated and have it back within a week. After that, its assembly time. I hope I don't have to order any shims, I do have a large variety now.
96sleeper is offline   Reply With Quote
Old 03-21-2007, 11:02 PM   #53
SLOW
Nealoc187's Avatar
Lookin good matt.
__________________
Old 03-22-2007, 06:36 AM   #54
Send a message via AIM to MardiGrasMax
Quote:
I've actually been considering trying to get an HLSD to work in the 5spd, but being as I don't have an HLSD sitting around it hasn't gone much further than being a thought in the back of my head.
oh no you didont!
__________________
Parted out and sold the fastest that was...
Now a G35 Sedan, Built Motor, Greddy TT... Trying to be as fast on street tires and the Max was on slicks
MardiGrasMax is offline   Reply With Quote
Old 03-31-2007, 08:46 PM   #55
THT
Throbbing member
THT's Avatar
Send a message via AIM to THT
Wonderful thread filled with more information regarding transmissions than I've read anywhere on on the org; thank you!
If I purchased a third and fourth gears from PPG, is there a need or benefit to having them shotpeened and deburred? Or will those processes have been applied to them already?
THT is offline   Reply With Quote
Old 04-01-2007, 07:05 AM   #56
96sleeper's Avatar
I chose not to do anything to the PPG gears. PPG says they are good for 500-600hp, so I decided not to mess with them. Just focus on the rest of your gears. They are probably deburred at the factory, but they are not shot-peened.
Old 04-05-2007, 04:59 PM   #57
96sleeper's Avatar
Almost done. Seems like these gears will be fine. All I need to do now is get the tranny back in the car and see if I remember how to drive a 5spd...
__________________
96 Pebble Beige SE
14.2@97mph as an auto
13.7@102mph as a 5spd
12.9@106mph after 3.5 swap
11.6@120mph with the S/C
Cardomain link
Latest Dyno 431hp/368tq click here
CAR IS FOR SALE
Old 04-06-2007, 01:37 PM   #58
96sleeper's Avatar
I just took the car for its first test drive after the addition of the PPG 3rd and 4th straight cut gearsets. Some people were concerned about the noise that these would make. The transmission is silent in gears 1,2,5 just as I had hoped it would be. In 3rd and 4th gear, it was as we thought, the sound that reverse makes, high pitched gear whine. It is really not as loud as I thought it would be though. I am extremely pleased. I am glad I took a gamble on these, and thanks to Neal and Mardi for all the help. I will post another update when I have a little more seat time.
I made alot of other changes to the car at the same time, so it will take some getting used to before I can report (lightweight flywheel, clutchnet 6puck clutch, VLSD tranny and PPG 3rd and 4th gears, V1 S/C kit and all the acc.) It is hard to believe I have been down for almost 6 months.
I got tired of waiting for shims on backorder for the differential, so I made my own. Luckily I had the main shaft and input shaft shims on hand from a previous build. Everything on the installation of these is straight-forward if you have a FSM. (And a way to measure for the main shaft shims.)
__________________
96 Pebble Beige SE
Cardomain link
CAR IS FOR SALE
Old 04-08-2007, 06:16 AM   #59
96sleeper's Avatar
After a little more driving and some time on the dyno, 3rd is not very loud at all, I barely notice it most of the time. 4th gear on the other hand is pretty loud and I definately notice the whine. It is not obnoxious or anything, but I am glad that 5th gear is stock so silence is only a gear away for long interstate driving.
__________________
96 Pebble Beige SE
Cardomain link
CAR IS FOR SALE
Old 04-11-2007, 10:42 PM   #60
VQ Wizard
Send a message via AIM to SR20DEN
Quote:
Originally Posted by mtcookson
A 5-speed should theoretically be better with boosted engines anyways due to the way they make the torque. I've noticed a lot of guys getting better times with wider gearing gearing when going with a boosted engine. I don't know of the 6-speed's gearing off hand but I'd assume it would be quite a bit more narrow than the 5-speed, depending on the diff. ratio.
The 6 speed is more narrow but it has a bunch of gear options from Nissan. Typically 3 to 4 ratio options per gear.
SR20DEN is offline   Reply With Quote
Old 07-19-2007, 09:16 PM   #61
SLOW
Nealoc187's Avatar
added some info on alternate gear ratios to my original posts.
__________________
Old 08-01-2007, 11:14 PM   #62
SLOW
Nealoc187's Avatar
added some more ratios to the beginning
Old 03-03-2008, 08:06 PM   #63
2nd Gen Boostinator
Big_E-Dog's Avatar
NVM found it
forms from nissan and others just incase any body needs part numbers
__________________
CUSTOM HEADLAMPS/CARBON FIBER/FT&RTSB/OIL COOLER/LED'S/VG30ETT/PATHFINDER INTAKE MANIFIOLD/2.5" EXHAUST/NISMO MUFFLER/HKS TT, BOV, BOOST GUAGE/Q45 BBK/K&N/2x GARRETT T-25/NISTUNE/......
Big_E-Dog is offline   Reply With Quote
Old 03-27-2008, 10:42 PM   #64
SLOW
Nealoc187's Avatar
Quote:
Originally Posted by mooseq30 View Post
Just got new fidanza flywheel + act clutch kit, and the 3rd and 4th helical cut with syncro engagement gears from par-engineering, I`m very exited to put them in! I`ve blown third before from to much torque i guess, i was making 335whp 320 lb/ft @9psi and i boosted to 11.5psi and third just shattered. I eventually want to change the input shaft+1st and 2nd+syncros+++ in the tranny but its very expensive and will have to wait till next summer!
Post back after install!
the input shaft for the GTIR won't work in the maxima, you'd need to get them to make you a custom one. it doesn't have any reverse teeth on it. so it would technically work, you'd just never be able to go into reverse.
__________________
Old 03-28-2008, 04:17 PM   #65
I was told it works, but I'm pretty sure your right! If i end up doing it next summer I'd have them make one custom that fits. But for now I'm very exited to do 3rd and 4th and put in some red line mt-90 or maybe some royal purple gear oil, or maybe neo gear oil? not sure yet!
__________________
vq30dek turbo 2000se
mooseq30 is offline   Reply With Quote
Old 03-31-2008, 09:58 PM   #66
These are pics of my Par gears from AU they still have oil/wax on them to protect them till install!
__________________
Old 04-01-2008, 10:55 PM   #67
High Res Image of Par Gear
__________________
Old 04-07-2008, 08:20 PM   #68
Par 3rd and 4th
stock 3rd and 4th
__________________
Old 04-07-2008, 08:22 PM   #69
-This is 4 images of the teeth on stock gears vs the teeth on the Par gears:
__________________
Old 04-07-2008, 08:26 PM   #70
As is easily seen in the pics the teeth are fewer in number on the par gears and less angeled the stock teeth are much thinner and pointy compared with the square cuts and thickness of the Par gears!
__________________
Old 05-15-2008, 02:43 AM   #71
!!!!!!!!FIRST EVER!!!!!!!!!!
Full first through forth set with input shaft and needle roller bearings for nissan maxima made by PAR;
As seen in the photos set has been made with the lagest tooth profile possible!
Pics are of helical cut set, straight cut is available as well!!
Set comes with superior design with gears ridding on needle bearings!
1st-4th set with input shaft and needle bearings
is available now in both helical and straight cut for 4000$AUD
-This is the first ever full 1st-4th set built for the nissan maxima and the first to have the superior benefits of needle bearings! Fifth gear can be purchased as well and ratio can be adjusted!!
THANKS goes out To PAR Engineering for making this set possible for all us maxima lovers who hate our garbage stock 5spd!!!
PM if need answers to questions!
__________________
Old 05-30-2008, 01:42 PM   #72
Pictures of the shaft and gears from PAR
If you notice the teeth are backwards in the middle photo its cause when I photo shopped them together I flipped that photo rev the teeth, sorry!
3rd PAR gear, 4th PAR gear, and 5th stock gear are all ridding on needle roller bearings now instead of the stock metal on metal design!
__________________
Old 06-02-2008, 02:58 PM   #73
Input and Output shafts fully assembled 1st,2nd,3rd,4th are PAR 5th is stock
__________________
Old 06-21-2008, 02:57 PM   #74
autobrokerdave@gmail.com
maximadave's Avatar
Send a message via Yahoo to maximadave
awesome info Neal
__________________
http://www.coronacarbrokers.com
maximadave is offline   Reply With Quote
Old 01-21-2009, 05:33 AM   #75
Hi, im new here and I have a question about the diff on the RS5F50 gearbox.
As the gearbox in my car is an open wheel diff, can the diff be replaced with a stock LSD unit. Will the LSD fit inside my diff housing and what is involved in this?
BobsN13 is offline   Reply With Quote
Old 01-21-2009, 05:54 AM   #76
Send a message via AIM to MDeezy
installing it is a very small part. Finding one for our transmissions is the challenge. the 4th gen transmissions never came with LSD, some of the I30 and Canadian versions of the Maxima had a VLSD. Some 5th gens had an LSD but I'm not sure if that fits into the 4th gen transmission.
MDeezy is offline   Reply With Quote
Old 01-21-2009, 06:23 AM   #77
96sleeper's Avatar
I know at least the driver side of the transmission case is different because the bearing is much larger on the VLSD. I did not compare the other half of the case when I swapped mine.
__________________
96 Pebble Beige SE
Cardomain link
CAR IS FOR SALE
Old 01-21-2009, 06:57 PM   #78
SLOW
Nealoc187's Avatar
I seem to remember trying to mate the case halves at one point and discovering that it wouldn't work but I might be imagining that - memory is foggy on that. I will try to mate my VLSD case with open diff bell housing in the next few days at work if I remember, and I will report back. I have both of them sitting disassembled on a shelf.
As stated, you can't just put the VLSD in the open diff case because of the bearing size difference.
__________________
Old 01-24-2009, 05:07 AM   #79
Thanks. I am sick of one wheel going nuts when the car comes on boost.
Old 02-20-2009, 01:02 PM   #80
SLOW
Nealoc187's Avatar
You can't bolt one case half from a VLSD to the other half of an open diff trans. I tried it the other day. Most of the bolt holes line up but a few of them do not.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
