New PLX SM-AFR MSRP $195
Old 07-25-2006, 03:59 PM
Fastest Fantasy Maxima Evar
IceY2K1's Avatar
http://www.plxdevices.com/products_SMAFR.htm
IceY2K1 is offline
Old 07-26-2006, 12:26 AM
IceY2K1's Avatar
Nobody?
Choosing this over the LC-1 is a no brainer IMO.
Can't wait for the eBay sellers to discount MSRP. I love how inexpensive quality parts are getting.
IceY2K1 is offline
Old 07-26-2006, 12:32 AM
IceY2K1's Avatar
They're also releasing an EGT for $89/$125(w/sensor):
http://www.plxdevices.com/products_SMEGT.htm
IceY2K1 is offline
Old 07-26-2006, 12:34 AM
IceY2K1's Avatar
Fluid temp $89 for 1-sensor or $109 for 2-sensor:
http://www.plxdevices.com/products_SMFluidTemp.htm
IceY2K1 is offline
Old 07-26-2006, 05:58 AM
Kevlo for President
Kevlo911's Avatar
Oh, so that's why they slide on each other... I was confused for a second. Yeah I woulda bought this but I got my PLX300 with external gauge a few weeks ago.
Kevlo911 is offline
Old 07-26-2006, 07:38 AM
SLOW
Nealoc187's Avatar
hot damn $109 for a two sensor fluid temperature gauge. I'll be getting one shortly I think, temp is a big worry for me with this custom radiator setup.
Nealoc187 is offline
Old 07-26-2006, 08:21 AM
IceY2K1's Avatar
Yeah, I think this FINALLY answers my needs/wants/future upgradeability.
As long as the HDD and box isn't too expensive, I could see running 4-inputs.
IceY2K1 is offline
Old 07-26-2006, 08:33 AM
LatinMax's Avatar
So you just run a seperate gauge with this? Like who's gauge can you run with this setup.
LatinMax is offline
Old 07-26-2006, 08:44 AM
IceY2K1's Avatar
For the $195 unit, you'd have to run a datalogger, ie emanage, etc.
However, with its 0-1V narrowband output, you should be able to hook it up to any cheap narrowband gauge. Not 100%, you might need their convertor for $30, I think.
This setup is mainly for running their uber cool HDD gauge, but is also now the cheapest WB02 and IMO the best WB02 on the market.
IceY2K1 is offline
Old 07-26-2006, 08:59 AM
IceY2K1's Avatar
Gabe,
IceY2K1 is offline
Old 07-27-2006, 04:34 AM
BUY MY CARS PLEASE!!!
pawnstar12's Avatar
plx has some bad @ss **** at great prices this year
pawnstar12 is offline
Old 07-27-2006, 11:26 AM
3.5 in the works
DandyMax's Avatar
I wish this was available when I bought the Zeitronix.
DandyMax is offline
Old 07-27-2006, 11:32 AM
IceY2K1's Avatar
eBay it Dandy...
IceY2K1 is offline
Old 07-27-2006, 12:00 PM
mforrest100's Avatar
So since I have the EU what all would I need to purchase to datalog?
In the case I decide to go boost, what additional accessories will be beneficial?
This could not have come at a mor perfect time seeing I was in the market for one.
mforrest100 is offline
Old 07-27-2006, 12:13 PM
IceY2K1's Avatar
http://www.mohdparts.com/emanage/ind...tional%20Parts
The AF harness for ~$20 on mohdparts.com or you can make your own with an old PC CPU fan 3-wire harness.
A pressure sensor or just buy a P/W/H Greddy Pressure gauge and tap off the included pressure sensor.
IceY2K1 is offline
Old 07-27-2006, 12:34 PM
And this is to use the wideband unit in this thread correct? I am so slow qwhen it comes to this stuff but I am coming along slowly but surely. =)
Old 07-27-2006, 01:05 PM
IceY2K1's Avatar
It is universal and can be used with any WB02 that has a 0-5V output. You have to connect some wires and per PLX use 2-capacitors they provide, ie it isn't Plug-N-Play.
Check out page 2 of this to give you an idea of what is involved:
http://www.plxdevices.com/Installati...UsersGuide.pdf
IceY2K1 is offline
Old 07-27-2006, 01:15 PM
3.5 in the works
DandyMax's Avatar
eBay it Dandy...
Likely I'll sell it to a friend, who has already been sharing the use of it with me. I may just keep it for now, the Z does fine enough for my use currently, it's just not linear output so a bit more hassle to work with, but nothing major.
DandyMax is offline
Old 07-27-2006, 01:17 PM
IceY2K1's Avatar
How often do you calibrate it? Is it in the car full-time or only when you plan on logging?
IceY2K1 is offline
Old 07-27-2006, 01:43 PM
3.5 in the works
DandyMax's Avatar
It's not in the car full time, only when I needed to re-tune or specifically wanted to log A/F.
Of course switching over to the pressure sensor now I'll be having to do that a few more times to dial in weather changes and also when I get on the dyno.
DandyMax is offline
Old 07-27-2006, 04:24 PM
IceY2K1's Avatar
IceY2K1 is offline
IceY2K1's Avatar
IceY2K1 is offline
Old 07-27-2006, 04:25 PM
IceY2K1's Avatar
http://www.plxdevices.com/products_iMFD.htm
IceY2K1 is offline
Old 07-28-2006, 04:41 AM
pawnstar12's Avatar
thats so hot. im thinking of chucking my c2 gauges
Old 07-28-2006, 09:56 AM
IceY2K1's Avatar
Yes, I know. I think I'm going to keep my Greddy P/H/W gauge and run one of these HDD gauges. I haven't seen a price, but suspect it won't be cheap. However, once you add on 4-sensors, it has to be cheaper not to mention a hell lot cleaner then having a bazzillion gauges all over.
I'm going to have a J&S knock gauge, the Greddy Boost, and the PLX HDD. If I need more, I guess I'll daisy chain and put them below the single DIN slot.
IceY2K1 is offline
Old 07-28-2006, 12:56 PM
Made in Taiwan
GodFather's Avatar
great snit you found...Props. I'll be shopping soon.
GodFather is offline
Old 07-30-2006, 12:54 PM
GoalieKeg's Avatar
I can't find this thing anywhere for sale. Any idea of where to purchase it online?
GoalieKeg is offline
Old 08-02-2006, 12:55 PM
IceY2K1's Avatar
They've updated their online store:
http://www.plxdevices.com/cgi-bin/sh...D&keywords=all
IceY2K1 is offline
Old 08-04-2006, 10:47 AM
pawnstar12's Avatar
put the hdd-100, dm-100, sm-egt, sm-afr on order today
Old 08-04-2006, 11:25 AM
IceY2K1's Avatar
Very nice...update us with pics.
IceY2K1 is offline
Old 08-10-2006, 12:06 PM
my 02 cents
Just some food for thought...
1) Reading through the both Innovate and PLX forums for months now.... I see a lot more threads related to..."I need help, my xxxx doesn't work" on PLX's site.
2) Also, I don't exactly want to start mounting SM's and DM's all over the place. That will get messy really fast. With Innovate, one AUX box will do it all. (I think)
3) New technology always has problems. Look at the EU. Personally, I go for things that are "tried and true" and I always wait a short time to hear feedback from others/let some of the introductory bugs get worked out. Look at how may software upgrades there are for the EU. And hardware versions too! Software is upgradeable, but the hardware isn't. There's no "exchange program" that I've ever heard of. I'm getting pretty close to buying the EU, but I'm hesitant because maybe a new hardware unit will be produced.
4) The preferred choice amongst Supraforum members for a nice WB unit is Innovate.
I'm torn, but I'm leaning towards Innovate's LM-1/LC-1 with XD-16 gauge.
I'm no expert at this stuff, just my observations and from what I've heard from people that have used both Innovate and PLX units. Feel free to correct me if I'm wrong.
Ahhhh... choices, choices.
The Wizard is offline
Old 08-10-2006, 12:19 PM
IceY2K1's Avatar
1)Most are R-series or moron installs.
2)You only need one DM per gauge, which can display 4-sensors.
3)EU worked fine for me. Latest revisions just make it better..definitely not a reason to not buy one.
4)Innovative makes a nice unit, but PLX is better technology and now cheaper.
PLX SM-AFR is based on the "tried and true" M200, just different modular packaging.
IceY2K1 is offline
Old 08-11-2006, 07:11 AM
jmeister's Avatar
Expected release date Sept. 06, pre-orders only
jmeister is offline
spidgeon
01-22-2016 05:54 PM
jc53
10-12-2015 05:12 AM
MaximaRaj
27
10-02-2015 07:31 AM
coasterswim
09-01-2015 05:27 PM
phattyaltnatl
08-18-2015 01:56 PM
Quick Reply: New PLX SM-AFR MSRP $195
