Turbo size poll
Turbo size poll
I need to compile some info off of you turbo guys. Basically what I'm trying to find out is what exhaust a/r housing you're using if you have a T3 hot side, and roughly where you're spooling at. VG30E, VE30DE, and VQ30DE guys only just to keep the numbers relatively close.
Basically this is the info I'm looking for:
T3 turbine a/r
Ball bearing or journal bearing
RPM in which turbo is at full spool
Engine type
Thanks in advance!
T3 turbine a/r
Engine type
Thanks in advance!
VQ30
T3/T04S, non ball bearing
.81AR hot side
Full boost at approximately 3500 rpm. Starts boosting below 3000.
Setup is custom, but turbo feed pipe is pretty much like the PFI setup.
.81AR hot side
T3 turbine a/r
Engine type
Thanks in advance!
T3 turbine a/r
Engine type
Thanks in advance!
I'm not so much trying to find a good turbo as I am just compiling data. I think for my VG30E the T04E 50 trim fits very well. Should support upwards of nearly 480 hp at around 24 psi or so.
I'm just basically wanting to see what everyone is running and the spool times they're seeing. I have a couple ideas I want to mess around with in an attempt to speed up spooling while keeping the top end.
Originally Posted by pawnstar12
VQ30DE
forward Y pipe
t3/t4 60trim .63ar non-bb
2500 rpm builds boost
3800 full boost 9.5psi
314hp
343tq
forward Y pipe
314hp
343tq
i had it for sale for $350 but my boy picked it up. i bought it new for $600-700 ish
damn **** , would you happen to have the ability to get yor hands on another one?
VQ30DE
forward Y pipe
314hp
343tq
forward Y pipe
314hp
343tq
Is this from a low RPM roll?
What I am really curious about is from say a 4th gear roll starting below 2000 RPMs, when do you reach 5, 8, and 10 PSI.
Since I am getting that exact turbo, I am extremely interested.
Thanks!
VQ30DE
forward Y pipe
in 2nd gear
314hp
343tq
forward Y pipe
in 2nd gear
314hp
343tq
2nd gear pulls
i have an auto so i really cant give you accurate rpm ranges in certain gears
Cool, I was worried that you might be posting 3800 RPM figures for something like a 4th gear roll (manual tranny).
I am hoping my combo will spool to ~8 PSI around 3000 RPMs with that turbo from a 4th gear roll (manual tranny).
litch
123
01-04-2024 07:01 PM
knight_yyz
11-01-2015 01:34 PM
