2000 Max ECU cylinder map?
Old 02-24-2006, 02:19 PM
teddibear703
JdoubleOe703's Avatar
Does anyone have a picture or a diagram of the 2000 max noting each cylinder? I will be installing a J &S this weekend, but need the diagram...
JdoubleOe703 is offline
Old 02-24-2006, 04:06 PM
teddibear703
this is for a 2000 maxima.
injector 1 = terminal 101
injector 2 = terminal 103
injector 3 = terminal 105
injector 4 = terminal 107
injector 5 = terminal 102
injector 6 = terminal 104
ignition signal 1 = terminal 21
ignition signal 2 = terminal 22
ignition signal 3 = terminal 23
ignition signal 4 = terminal 30
ignition signal 5 = terminal 31
ignition signal 6 = terminal 32
rpm= 25
vias=16
ground=58
MAF= 61
coolant temp= 70
intake air temp= 64
vehicle speed= 86
throttle position= 91
crank (pos)= 85
crank (ref)65, 75
cam (phase)= 66, 76
knock= 93
Old 02-25-2006, 01:33 PM
Haterz's Avatar
Are you asking for an ecu diagram? What is your email, I'll try and send it to you.
Haterz is offline
alahjahwan09
18
09-21-2015 09:12 PM
ballerchris510
09-10-2015 09:35 PM
GregL65
09-07-2015 10:33 PM
mix master
09-04-2015 05:50 PM
Quick Reply: 2000 Max ECU cylinder map?
