What is our max oil pressure under normal operation?
Old 08-08-2005, 10:51 PM
SLOW
Nealoc187's Avatar
I'm redoing the oil feed/return system on my turbo and if I find that there is no restrictor on this turbo then I'm considering getting one, but I'd like to know our max normal oil pressure first to help me decide.
Nealoc187 is offline
Old 08-09-2005, 02:00 AM
SomePsychoGuy
SPiG's Avatar
According to the eFSM it is
at Idle: ~10psi
at 3000rpm: 63.1 - 79.9
SPiG is offline
Old 08-10-2005, 08:19 PM
The Crazy Azz Cracka
choray911's Avatar
My auto meter reads 7 at idle, and between 60 and 70 at 3000 rpm depending on engine temp.
choray911 is offline
Old 08-10-2005, 08:41 PM
NWP Engineering.com
Aaron92SE's Avatar
I have found my VE and others to be around 95-100 psi at WOT. According to Maximum Boost, you don't want anything more than 70psi going into the turbo or you'll risk smoking. But I am pretty sure your motor is over 70psi while near redline at WOT. So, you'll need a restrictor. The SR guys commonly use a .060" restrictor. That is also what Maximum Boost speaks about the most.
Also, some food for thought, it also says that the absolute minimum pressure you want going into your turbo near redline at WOT is 25psi. So, you want 25-70psi at your turbo at WOT. I am thinking about rigging up my gauge during my design phase just to determine the pressure going into the turbo under maximum load.
BTW, you need an oil pressure gauge. You can get a cheap Sunpro electric OP gauge at Auto Zone for like $25. Buy a nice adapter housing for $20 and you're set. Here's a link: http://www.stealthmodeperformance.com/blockfitting.htm
Do you have any good links that show how to choose a proper restrictor?
Aaron92SE is offline
Hailstatejig
09-02-2015 06:52 AM
MaximaDrvr
08-19-2015 08:20 PM
acw
08-13-2015 12:50 AM
Balkins
08-12-2015 06:39 AM
altome15
08-10-2015 07:05 PM
Quick Reply: What is our max oil pressure under normal operation?
