Fuel Delivery Setup question.
If running the 255LPH Walbro fuel pump with 370cc injectors and Z32 MAF hooked into a SAFC II, would both an AFPR and FMU be needed (or a SFMU)?
Or, would just a FMU be needed- (I read from another post that the ECU can compensate and give a stoich mixture at an acceptable pressure).
Or do you suggest just playing it safe and getting a SFMU to cover both ends of the spectrum and avoid any potential problems and possibly open up some fine tuning options?
(anyone have an idea what WHP this setup would be good to?)
Thanks a lot,
Jeff
Thanks a lot,
Jeff
From what I have read, you should be able to get by w/o an AFPR. The 370's shouldn't give you too much of a problem on cold start. In addition, your probably going to want an FMU because you gonna have to make too large of corrections with just an SAFC. Not good to be adjusting large amounts with an SAFC, try and stay under +/- 10%.
But if your gonna buy an FMU then just get a SFMU then you can adjust base fuel pressure if you need to.
Originally Posted by MaxInProgress
HOld on so im gonna need a fmu and a sfmu? And whats the s before the fmu. i was guesssing safety..?
litch
123
01-04-2024 07:01 PM
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
