threw my belt again collateral damage
Well I threw my belt again I think this one lasted about 5 weeks. I lost both belts and manage to take out the crankshaft position sensor (REF). I order a new sensor $59 not so bad I guess I will also be taking this opportunity to change to the 3.25 pulley my stock one is chewed up might be why its throwing the belts. I will also be changing the bolts to the s/c dose any one know the part # for the ones that hold the s/c to the bracket v2 charger /bracket. looking for the flat alan head bolts. thanks PS not sure which bolts they are on the parts list.
Part # / Item
407000-36--- M12x70mm Flat head bolt (2)
407000-74--- M 12X50 mm Flat Head Bolt (1)
407000-37--- 3/8-16 x 4 1/2 flat head cap screw (4)
407000-76--- 3/8-24 x 1 Flat Head Bolt (1) (allen screw which holds pulley to blower)
Hope that helps.
James
litch
123
01-04-2024 07:01 PM
