just dynoed 2k1 auto w/v2
confident nissan owner
ok i have a v2 s/c and exhaust but thats it and i am running stock injectors at 11 psi w/2.87 pulley and they told me i'm running rich the dyno shop also did a/f ratio and it's off the chart rich they said it's hurting me so i'm still wondering why all of you are saying i need bigger injectors? here is a copy of the dyno
dyno chart
dyno chart
well i have the complete v2 kit from stillen it has the vortech fmu and whatever disc it comes with i have not changed any of that. and if you check the dyno sheet you can see that my a/f ratio goes off the chart rich
Dude thats some good numbers. What exhaust setup are you running? I've got the 3.125 pulley w/ a 8:1 disk and stock injectors so seeing the a/f chart makes me feel a little more comfortable. Do you have a walboro fuel pump?
thanks guys yeah i was definitly happy, especially at the end of the dyno run when a plume of black smoke came out of my exhaust i knew it was rich,
i have whatever extra fuel pump came with my v2 kit, i'm running both fuel pumps, factory and vortech, (well whatever brand comes in the stillen kit)
yeah i wanna get an safc2 but is apexi the best one? also at the dyno shop they where trying to sell me some kinda aem computer, have any of you heard of this before?
You don't want to use SAE numbers on FI cars.
Uncorrected on FI cars is best, since SAE and STD overcorrect/exaggerate the correction factor.
Did they give you SAE numbers too or just the STD numbers.
1)Stock FMU disc is 8:1 IIRC, so that means at 11psi you're pushing 105psi or so of fuel pressure. At 105psi, you're pushing ~80% duty cycle(assuming BSFC and auto driveline loss). If you dropped down to the 6:1 disc(~83psi), you'd be around 90% DC, which would be safer IMO and once you tune out the excess fuel, you'd be <90% probably. You really do need larger injectors, since pushing past 80% DC isn't recommended and pushing 80+psi isn't long term reliable, however people here have done it pretty often.
2)No.
2)No.
If you're considering injectors, these 380cc would be P-N-P:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
I believe StephenMax recently posted both.
Ice do you know of any dynos on the net showing the difference between SAE or STD vs uncorrected on an FI car at sea level? I want to see how much of a difference it can make.
Just to make sure....don't just toss in a 6:1 FMU disc blindly and drive it. Make sure you get it tuned again.
I don't want you following my "keyboard" advice and blowing your engine, since math and guesstimates can only get you so far.
Originally Posted by Nismotech1
ahh ok thankyou for helping me on this ice, it does make a little more sence now
nah ice. me blind? ha!
(who told you?)lol
i don't even know where to get the disc at... i am a nissan tech, but at the dealer we only do factory repairs so i'm still new to the blown world.
-jeff
(who told you?)lol
-jeff
You can find them cheap sometimes on eBay or here in the Classifieds or you can just order them from Vortech at http://www.vortechsuperchargers.com/...tegory_Code=FC .
Not per Stillens' part list:
http://forums.maxima.org/showpost.ph...18&postcount=6
Plus, if it was 6:1, it wouldn't even add any fuel over the OEM FPR until 6psi, which doesn't make sense on stock 3.6" pulley kits. 8:1 over takes the OEM FPR at 4psi.
TallTom
50
07-08-2022 09:54 AM
AaronL
08-08-2020 10:31 AM
