Just got the news: SC is FAWKED
Well the blades on my s/c are thrashed the the cylinder closest to my s/c is only puttin out 50? compression ratio compared to all the other cylinders which are at 150+. So how does one go about getting their s/c rebuilt, should I contact vortech directly, and how long does the process usually take?
Thanx
-Arnaud
Thanx
-Arnaud
Did you suck in a rock or something?!
Sounds like it's going to be expensive with the engine work too.
Vortech can rebuild the S/C if you remove the pulley and the bracket off. Don't know how long, though or how much seeing you need more than just a "rebuild".
Originally Posted by MaximaRider
I honestly don't know what happened, possibly my filter was dirtier than I thought it was? When my belt snapped it was very cold outside, did my sc seize up? Is this something I can bring to vortech's attention? I am getting a new head gasket and they are fixing the cylinder that went bad. I don't see what else I would need besides the blower being rebuilt and this head being rebuilt is there?
How much is it costing you to fix your motor? it might be cheaper to just replace it. Maxima motors are pretty cheap.
Ian- I will be sure to take pics as soon as I go pick up my car this afternoon.
CMAX - did you go through stillen, or did you deal directly with Vortech? I think I'm just gonna send me blower directly to vortech, I've heard they are much quicker than stealin.
Well is the head all that is messed up? It's possible, but i can hardly imagine that to be the case if pieces of the impeller were ingested into the engine, I'd expect the cylinder wall to be scored and the piston itself to even be damaged. Replacing the head won't help a thing if this is the case.
150 compression is low but it's possible you just didn't turn the car over enough when checking the compression and that would explain low but consistent readings on the other 5 cylinders.
it took roughly 2 months to get my blower back after getting it rebuilt and cost me 400. Matty sent his out recently and it only took a few weeks. This is supposed to be the nonbusy time for vortech, most people put their drag cars to sleep for the winter i guess....
My mechanic buddy said to replace the one busted head and have it machined about ~$500, I figure this is cheaper than finding a used motor and paying someone to put it in. Also i was wondering my other cylinders read at 150+ for compression is this too low?
ugh if I have to pull the motor I am selling the S/C, enough with the headaches this is the first time my car has ever given me problems. Anybody know where I can get a cheap VQ, i checked online, cheapest I found was $640 for one with 15k miles.
Originally Posted by 1MAX2NV
I think you ran lean in that cylinder. Did you ever boost the car while the tank was close to empty? Do you have a fuel pressure gauge?
Ok so i've come to the decision to swap my motor and possibly keep the s/c (shhhh don't tell my parents, they'll be pissed) What websites do you recommend to get used motors from, I am thinkin about pickin up a 98 Motor with 15k Miles from Cherry Autoparts Network, they say its in "A" condition and that compression and leakdown tests were performed and its selling for $640 shipped? Any other reliable sources to get engines from cheap online?
Not a bad deal for shipped..plus a leak down test is the best test without a total tear down. Something failed on your old motor, I would try to use everything you got from the new motor. Unless you really found out what the root cause of the problem, it would sucks to have to do another motor swap later down the road.
That is not too bad of a price. I paid $400 delieverd for a 97 75K mile motor and a 1 year warrenty
Originally Posted by iansw
You paid $800 shipping?!
Or did you mean "$800 shipped"
I am not sure if they sell the VQs, but I did mention that there is a low mileage VQ for sale in the DC forum....
Link to VQ motor for sale in VA
Getting it shipped to a place with a loading dock will save you some serious $$$$
vadim8
10-25-2002 07:20 PM
