put on 2.87 pulley & now belt rubs
confident nissan owner
after installing 2.87 pulley today i noticed the belt shreding and i look at the pulleys and found the belt is rubbing against the bracket of the compressor
i think the idler pulley is to big for that small pulley any one else have this problem?
I have that same post on the v1 too! You will be ok without it. You have 5 or 6 other bolts . I have run mine missing 2 of the longer bolts , no problem. It has been done. Ready for hin? The blower will be fine with out that bolt. My bro has v2 with v2 bracket with that post cut off. no problems.
I would think you could use that, its softer than steel.
I have seen some actually cut a notch out for the belt to clear and I guess you could still use the bolt if you wanted. More work and not really needed though.
Im not 100% sure on price. I think around $16k. Its my younger brothers car. He just got a sti so ..... The car is nice and runs perfect, has cattman y too. I would buy it myself but now is not a good time for me to have to toys.
hey your max is hot man and it sounds like you got it hooked up as far as running goes, but if you want to p.m. me the actual price and i'll ask around at this fridays MAXOUT there where a couple of guys about a 5th gen last time
I will ask him about the pics, im sure he has plenty. Its dark grey with factory 17's. Its as clean as mine. thanks by the way, my blower is at vortech right now getting rebuilt
Is this a new record for the longest 2 person post?
Well , it started to sound like crap. To some the v1 already sounds like that but it was noticable. That and it has 97k miles on it so I new it was time. The E trim is on the site, you have to look on the right side and find it in the matrix charts or something
Go to products/ charger units/ and you will see it on the right of the page/performance matrix
http://www.vortechsuperchargers.com/...rformance.html
The specs of the E trim are very similar to the T trim. I wonder if the T trim is still more potent.
just grind that sucker down with a grinder thats what i did. i had the 2.87 pulley came close to just cutting it off but i just grinded it down till it couldnt anymore. like some said you can even cut the post off not really needed.
Originally Posted by Soul Fly
The E trim is in the efficiency range longer and is higher too. It looks to be a bit better than the T trim.
If more efficient is shown by one # being greater than the other you may have misread the chart. If it is the opposite....then I stand corrected
Type
Rotation
Finish
Air Inlet Opening (Hose Diameter)
Air Inlet Opening (Inducer Diameter)
Air Discharge (Hose Diameter)
Air Discharge (Inside Diameter)
Impeller Speed (Efficient Max)
Impeller Speed (Absolute Max)
Performance @ Absolute Speed (Max PSIG*)
Performance @ Absolute Speed (Max Flow CFM*)
Performance @ Absolute Speed (Horsepower Range)**
Adiabatic Efficiency
Supercharger
V-1/V-2 S-Trim
STD/HD
Clockwise or Counterclockwise
Satin or Polished
3.50”
3.10”
2.75”
2.38”
45,000
50,000
20
1,000
680
72%
V-1/V-2 SC-Trim
STD/HD
Satin or Polished
3.50”
3.10”
2.75”
2.38”
50,000
53,000
20
1,000
680
75%
V-1 T-Trim
HD
Satin or Polished
3.75”
3.29”
2.75”
2.38”
52,000
55,000
26
1,200
825
73%
V-2 SQ E-Trim
STD
Satin or Polished
3.63”
3.33”
2.75”
2.38”
62,000
65,000
26
1,200
750
76%
Type
Rotation
Finish
Supercharger
V-1/V-2 S-Trim
STD/HD
Satin or Polished
3.50”
3.10”
2.75”
2.38”
45,000
50,000
20
1,000
680
72%
V-1/V-2 SC-Trim
STD/HD
Satin or Polished
3.50”
3.10”
2.75”
2.38”
50,000
53,000
20
1,000
680
75%
V-1 T-Trim
HD
Satin or Polished
3.75”
3.29”
2.75”
2.38”
52,000
55,000
26
1,200
825
73%
V-2 SQ E-Trim
STD
Satin or Polished
3.63”
3.33”
2.75”
2.38”
62,000
65,000
26
1,200
750
76%
I don't see much advantage to the T-trim. The max effic. is 52,000. The E-trim is 62,000. You would over spin the T-trim at 55,000.
T-trim At 6,550 rpm with 3.12 blower rpm will be 45195.
At 6,550 rpm with 2.87 blower rpm will be 49210.58
At 7,200 rpm with 2.87 blower rpm will be 54094.08
At 6,550 rpm with 2.62 blower rpm will be 53906.25
E-trim At 6,550 rpm with 3.12 blower rpm will be 47160.
At 6,550 rpm with 2.87 blower rpm will be 51350.17
At 7,200 rpm with 2.87 blower rpm will be 56445.99
At 6,550 rpm with 2.62 blower rpm will be 61832.06
Wouldnt it make more sense to run in the effic. area longer?
S-trim compressor map shows 70% effic. @ 40,000 rpm, peak @ 35,000
basing this off of v1 vs. v2 calculations
So you're assuming for RPMs that are perfect. If you don't allow for at least some slip you'll burnup the accessories because of the very high belt tension. And the smaller pullies are going to slip even more.
The point is that the T trim will still make more power, and lower RPMs, according to the data that Vortech has provided.
Go ahead and buy the E trim so we can have some real data to compare against the T trim data that we'll have in a few months.
Who is upgrading to the T trim? I was looking at doing something like that but didn't know for sure that i could.
rpm's are not perfect . redline of 6550 is not perfectly correct either. Its probably more, maybe 6700 since the factory tach is usualy off. Im not trying to argue with you, the way I am interperting the information I would say the E-trim is a better unit. Im just looking at the #'s and to me E-trim looks better. Im not rulling out the T-trim at all. Very posible the T-trim is better. I hope soon someone might show prove or clarify this.
