Turbo Emissions
Old 11-26-2004, 06:04 PM
The Crazy Azz Cracka
choray911's Avatar
Turbo Emissions
The Air In Chattanooga, Tennessee Sucks. Emissions Start In April And I Don't Want To Park My Car. Can Anyone Pass The Pipe Test With A Turbo?
Holla Back
Choray
choray911 is offline
Old 11-26-2004, 11:03 PM
subs1000w's Avatar
put your stock ypipe back on and cat if you dont have it on the car
subs1000w is offline
Old 11-27-2004, 06:50 AM
SLOW
Nealoc187's Avatar
How's he going to put his stock Ypipe back on if he's got a turbo? Unless he has some weird turbo piping setup that uses an aftermarket ypipe as its shape.
Nealoc187 is offline
Old 11-27-2004, 07:27 AM
subs1000w's Avatar
as long as he has stock length cat back he can just bolt his stock y and cat up with no problem
if he has custom catback then i dont know
Old 11-27-2004, 08:03 AM
Ad·min·is·tra·tor
DanNY's Avatar
i believe if you have all your emissions components on (EGR, cat - in good shape) and no crazy cams you should be ok.
DanNY is offline
Old 11-27-2004, 09:16 AM
SLOW
Nealoc187's Avatar
Well I don't know this particular guy's setup but on most if you remove the Ypipe that feeds exhaust to the turbo, you have to remove the turbo, which means undoing all the fittings, bringing it back to stock tune, etc. Seems like alot of work. Basically he would have to uninstall his turbo kit.
Old 11-27-2004, 09:18 AM
subs1000w's Avatar
good point i forgot the turbo was not mounted to anything else
the car might pass emitions with the turbo and everythinjg installed as long as there is a cat
Old 11-27-2004, 09:21 AM
choray911's Avatar
I Still Hav Ethe Factory Catback And Y Pipe But That Is Too Much A Pain In The Ars
Old 11-27-2004, 11:43 AM
hlh0501's Avatar
Depends on your emissions test, but I was able to pass
(with highflow cat and no muffler)
You'll want to make sure your idle and cruising tune is good.
hlh0501 is offline
Old 11-27-2004, 12:10 PM
choray911's Avatar
the exact specs of the test haven't been released but I am planning on a hi flow cat. Its time for the test pipe to go. I just renewed, so there is a year to get it right.
Hal you made my day thanks
Old 11-27-2004, 01:32 PM
be the change u want2C
Ninos_Maxima's Avatar
my dad has this trick, it got his old chevy astro to pass emisions, dump in a munch of ethanol into your gas tank, you can buy it at a local hardware store, o and run your car on the highway right before at around 80mph for like 15 min and your gaurenteed to pass, this thing would smoke like no other, and it passed,
Ninos_Maxima is offline
Old 11-27-2004, 08:33 PM
subs1000w's Avatar
and just incase you go to a hardware store and dont find any ethanol its also called denatured alcohol and it will be with the paint thinners. i used this trick in my 92 f150 to pass i used 1 gallon of the denatured alcohol to about 5 gallons of premeium
litch
123
01-04-2024 07:01 PM
aw11power
10-10-2021 04:57 AM
09maxshawn11
09-30-2015 10:28 AM
carid
09-09-2015 05:06 AM
Quick Reply: Turbo Emissions
