when is the v2 supposed to reach full boost?
confident nissan owner
i just installed v2 kit and i notice i don't get to full boost untill around 5000rpm is this normal? does anyone have a graph or chart that shows the boost curve? also what should i do about the redline at 6600 rpm should i get a computer upgrade and if so what rpm is a safe redline this is my everyday driver (still making payments
thanks for all you help
jeff
jeff
Depens on the size of your pulley. With a 2.875 I see boost at pretty low rpm's. And max boost will be at redline. Also I don't think there is ant way for us to raise are redline.
Anyone correct me if I am wrong.
Well if you look at his sig pic and his profile "he has a 01"...raised rev limiter are only available on the 95',96' and some early 97's....as for the 01' I'm pretty sure they havent cracked that yet...there still workin on the 97-99
-matt
-matt
that really sucks how we just got passed through an era...they missed us, a very important item in a car's performance, no one is going to even make for us. We'll always be at a disadvantage. It's a setup i tell ya! Someone hatin on the better 4th gens
There is one situation where max boost will be before redline, and that is if your belt starts to slip. When that happens your boost will drop as the coefficient of friction between belt and pulley transitions from static to the lower kinetic value.
jeff heh i feel what ur saying ill go see ur S/c when i get the max. As for the ecu a friend of mine named danny a 5th gen 2k u never met yet called Technosquare. They are currently in the process of testing a ecu for 2k-2k1's so when it comes imma up for grabs.
btw its jon XD
btw its jon XD
Originally Posted by Nismotech1
well ok i guess the better question then is. when should i start seeing/feeling boost at what rpm range should it start?
thanks for all your help
-jeff
-jeff
it has whatever pulley and belt comes from stillen, however i do have the greddy sp2 cat back and my s/c came with a stillen cai i also have a y pipe and have hollowed out my cat. i want to get a high flow cat but i have not heard of any that are better for power than just straight pipe
litch
123
01-04-2024 07:01 PM
Calabar
10-05-2015 09:57 PM
220k+ A32
25
10-03-2015 09:09 PM
