Sx7r Fuel rail off-fitting
Hey!! Any of you guys purchased this fuel rail off-fitting from SX7R. I assume you would need to remove the stock fpr to install the fitting in the fuel rail. But my concern is the fitting itself.. It seems a bit weak... Does this thing require rubber washers or O-rings to keep the seal tight in the fuel rail? Will it leak fuel if I install it as is?? There is no documentation on this, but I wanted to be absolutely sure before installing!!! I dont like to **** around with fuel... Any thoughts or suggestions... Thanks.
I couldn't fix your brakes, so I made your horn louder
You re-use your o - ring that sits on the oem fpr and you also reuse the two screws that hold the oem fpr in.
Take your time removing those two little screws. Use the right size phillips and take it easy so you won't thread the screws and you can reuse those screws.
Yeah just use your old O-ring and it'll be fine. Has been for me...
Ok.. Thanks for your help...
i used a locking set of needle nose pliers and lots of patience in addition to the right size phillips screwdriver to assist in getting the screws started coming off so as to ensure i would not strip them out.
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
