stillen Super charger part numbers
Old 04-16-2003, 11:23 AM
JAY25's Avatar
stillen Super charger part numbers and Belt part numbers
Stephen Max posted
I've got this:
Bill of Materials
Packing Check-off Sheet
Stillen Super Charger 95-99 Nissan Maxima
P/N 407000
oAssembly person _________________________
oDate: _____/_____/_____
oSales Order # ____________________________
oSupercharger serial number:________________
o Instruction sheet with pictures and schematics
o STILLEN SUPERCHARGED Plaque 100505 Assembled
by__________________ Date ___________
Materials supplied:
(1) Air Filter Assembly Assembled
(1) Silicone Hose, Blue - Æ3 ½” air filter to
supercharger 407000-11
(1) Steel Insert-air filter to supercharger 407000-02
(2) Hose clamp, #56 407000-14
(1) Blow-off hose nipple 407000-61
(1) Air filter with holes drilled 407000-10
(1)Vortech Supercharger assembly. Assembled
(1) Supercharger 407000-01
(1) Supercharger adapter plate assembly 407000-07
(1) M12x50mm Flat head bolt 407000-74
(1) Idler pulley 407000-26 (2) M12x70mm Flat head
bolt 407000-36
(1) Supercharger drive belt 407000-29 (4) 3/8-16 x
4 ½ Flat head bolt 407000-37
(1) ½-20 x 1 ½ Hex head bolt 407000-72 (1) M12
Flat washer 407000-73
(1) Fitting, -4AN Male – 1/8NPT male 407000-56 (1)
3/8-24x1 Flat head bolt 407000-76
(1) Intake tube w/blow off mount, Æ2 ½” with STILLEN
decal 407000-03 Assembled by__________________ Date
___________
(1) Modified thermostat housing assembly. Assembled
(1) Modified thermostat housing 407000-05
(1) Thermostat housing gasket 407000-63
(1) Crankcase breather hose assembly Assembled
(1) 36” Æ5/8” ID Crank case breather hose 407000-15
(1) 90° Æ5/8” OD Plastic vent line adapter 407000-66
(1) 45° Æ5/8” OD Plastic vent to air filter 407000-65
(1) 2” Æ5/8” ID Crankcase breather hose NEED P/N
(1)Oil feed line, -4 S.S braided line 407000-25
Assembled by__________________ Date ___________
(4) Adel clamps, Æ5/16”, w/Æ1/4” bolt hole 407000-51
(1) Oil Tee adapter assembly 407000-56,57,58
(2) M6x1.0x30MM HHCS 407000-46
(2) Aluminum spacers, ƽ” OD x Æ ¼” ID x ½” Long
407000-17
(1) Blow off hose to air filter Assembled
(1) Æ1” ID x 20” Long 407000-62
(1) Fuel pump assembly Assembled
(1) FMU (Fuel Management Unit) – Comes from Vortec
assembled
(1) Bracket, Auxiliary fuel pump 407000-09
(2) Rubber Insulators – Fuel pump bracket 407000-67
(2) Adel clamps fuel pump holder 407000-87
(2) ¼-20 Male stud/Female rubber isolator 407000-27
(2) ¼-20x1/2 Flathead cap screw 407000-85
(2) ¼ Flat washer 402991
(2) ¼-20 Nylon locking nut 407000-40
(8) Mini Hose clamps 407000-75
(4) 5/16” F/I fuel line 24” long each 407000-64
(2) Isolator to assembly bracket 407000-68
(1) FMU Bracket 407000-47
(1) –8 female AN to –4 Male AN, fitting 407000-59
(1) Electrical nuts to fuel pump (packaged from
Vortec)
(2) M6x1.0 HHCS w/washers
1) Auxiliary Fuel Pump electrical assembly
(1) Fuel pump relay electrical assembly (Bosch relay
from Vortec, Stillen Assembly Dept. to wire)
(1) Fuel pump pressure switch 407000-49
(1) Blue 3M splice NEED P/N
(1) Hobb/boost switch bracket 407000-55
(2) 48” Blue silicone hose each 407000-16
(1) Power Steering oil cooler-Stillen (1999 models)
See P/N 407100
(3) Adel clamps SG-6 (1999 models) Part of BOM of
P/N 407100
(3) M6 x 1.0 x 10mm Flange bolt (1999 models) Part of
BOM of P/N 407100
(1) M6x1.0 Nylon locking nut (1999 models) Part of
BOM of P/N 407100
(1) Back strap 18” long (1999 models) Part of BOM of
P/N 407100
(1) Coolant bottle relocation bracket 407000-50
(1) 48” 5/16” hose, radiator overflow to coolant
bottle 405030-9
(2) Spring clamps, overflow radiator hose 407000-70
(1) Fuse box mounting brackets (teardrop) 407000-31
(1) Fuse box relocation mounting bracket 407000-30
(2) Flat head 10-32 x 5/8 451070-4
(2) 10-32 Nyloc nuts 407000-42
(2) 90° 3” OD tube w/Air temp sensor hole & crankcase
vent Assembled by__________________ Date
___________
(push in type and bolt in type air sensor) w/nipple
(407000-20)
(1) Modified oil drain back plate 407000-06
(1) Blower oil drain back hose-preformed 407000-32
(2) Hose clamps, # 10 407000-23
Hardware – Intake tubes Assembled
(1) Silicone hose, Black - 90°, supercharger to cross
over tube 407000-13
(1) Silicone Hose, Blue - MAS to 90° Ø 3.00 tube
407000-12
(1) Silicone hose, Blue - 90°tube to Throttle body
407000-12
(4) Hose clamp #48 Hard pipe/Mas/Throttle body
407000-19
(1) Blow Off Valve Assembly with adapter 407000-24,
-8
(4) Cable Ties, 11” Black 405030-6
(2) Aluminum spacers – Stand off to valve cover
407000-17
(1) M8x1.25x40mm Flange Head CS 407000-69
(1) M8x1.25 Prevailing Lock Nut 407000-86
(8) M6x1.0x55mm Hex bolt 407000-45
(8) M6 lock washer 318109
(2) M10x1.5x60mm Hex bolt 407000-33
(2) M10 flat washer 407000-34
(6) M6x1.0 Nyloc nuts 402993
(12) M6 Flat washers 318110
(6) M6x1.0x25mm Hex bolt 402990
(2) M6x1.0x40mm Hex bolt
(2) Hose Clamp #40 – Supercharger to 90°hose
407000-18
Vacuum line assembly Assembled
(3) Vacuum Tees, 3/16” 407000-28
(5) Cable Ties, 6” black 505053
(5) Vacuum lines, 3/16” ID 503215-6
(1) Air-bypass adapter 407000-78
(1)Cam sensor retainer 407000-84 Assembled
(1) C.A.R.B. Decal EO#D436-6
(1) 92 Octane Label WARNING
(1) Stillen SuperCharged Decal STISUPERdd
95-99 pancake filter number
Stillen's PN: 400700-10
K&N's: RA-0980
JAY25 is offline
Old 05-01-2003, 06:28 PM
[maxi-overdose]'s Avatar
scanned parts list from Stillen
[maxi-overdose] is offline
Old 08-03-2003, 01:04 PM
JAY25's Avatar
Belt part numbers
Gates belt sizes for V2:
3.60 to 3.33 - K060710
3.25 to 3.125 - K060705
3.00 to 2.87 - K060703
Posted by the V1 moderator Delio
Well for a fact I can tell you that anything @ 3.25 too and including ASP's 3.0" pulley will use the 6 rib 695 length. I think that is the stock belt in the V1 kit which means it will work with the 3.33, 3.48, and 3.6, but I didn't buy the kit new so I can't speak for sure.
JAY25 is offline
Old 08-17-2014, 11:39 AM
TravisCadello's Avatar
I know this thread is old is shiiiit, but man i cant find NONE of these parts even if i google it.
i need to order the modified thermostat housing and find a aluminum belt tensioner. the one from stillen melted! anybody have a clue where to find?
TravisCadello is offline
Old 08-17-2014, 12:52 PM
I'm confused. A modified thermostat housing implies a V1 bracket, while asking about an aluminum belt tensioner implies a V2 bracket.
Which bracket do you have?
The Wizard is offline
Old 09-04-2014, 08:19 PM
matty's Avatar
Yes first you need to figure out what bracket you have.
V2 bracket utilizes the factory thermo housing
V1 requires a modified thermo housing which I sell to order.
Matt
matty is offline
Old 09-04-2014, 08:23 PM
Fakie J Farkerton's Avatar
Pretty sure he gave up and sold it.
Fakie J Farkerton is offline
Old 09-04-2014, 10:49 PM
Matt
Yeah, we figured it out in his other thread. It's a V2 plate.
Yeah, unless he can find that pulley. Not looking good so far.
mrc00l88
01-25-2024 01:14 PM
MAXSE5SPD
09-17-2022 04:00 AM
AnsonJ
06-02-2017 01:35 PM
BassAddictJ
08-04-2015 11:38 AM
Quick Reply: stillen Super charger part numbers
