Belt shredded on V2
Belt shredded on V2
Was on the freeway, windows down, stereo booming. Smelled a weird odor and thought it was a dead animal on the road or one of the many 18-wheelers piping noxious fumes from it's exhaust. Then the battery and brake light come on, so I assume it's my battery because I've been having electrical problems with the stereo recently. When I get home 5 minutes later, checked under the hood, belt is shredded. Crap.
Guess I can finally get the 3.125" pulley installed.
I'm getting the Goodyear Gatorback Poly-V belt, part number 4060705. If this one shreds, the SC comes off and goes on the "for sale" forum. I can go without boost until the STi arrives.
This has actually happened to me twice now. I'm going to my installer tonight to have the belt replaced for the third time. The first time it happened was at my house and the belt just jumped a rib on the pulley. I finally got it fixed friday night and on my way home it shredded again. I had a 3.125 pulley installed while the plate was apart and we did shave the bracket so that didnt shred the belt. A few members on the org suggested that it is an alignment problem and the plate needs to be pulley needs to be moved by placing spacers in between the plate and the blower. Check maxi-overdose's thread on s/c alignment info. it's very informative. Well I hope you figure out what caused the belt shredding, good luck.
Do not just drop the car off stay there and see what is the problem. When you remove the plate you will see evidence of what the problem is. I did you can see lots of belt residue on the plate.
Well, the belt was the same one used by the previous owner of the SC from 2+ years ago. It looked in good condition and the shop that installed the SC in my car couldn't get the SC off the bracket to change the belt when they installed it last summer. It's a Gates belt with the stock pulley and DanNY's aluminum idler and tensioner pulleys.
I was making a left turn at an intersection and probably going a little too fast. I didn't notice the oil slick in the left turn lane, so I spun out in the intersection and my car did a 180 spin-slide. Luckily I didn't hit anything, and just kept driving. The force of the slide may have caused the engine mounts to give and the engine buckled or something in the engine bay moved so the belt may have hopped off the pulley tracks then. I kept driving around for another 10 miles, then the battery light turned on, which is when I guess the belt shredded. Before that, it must have been off the tracks, but still turning the pulleys.
Jay25, I will stay with the mechanic, but honestly it's been working fine for a while. I'm not sure what I did today to make it fail, maybe like I said above.
Hi Tan:
where have you been? havent seen you for a while.
sorry to hear about your belt problem. Just wondering, was the belt running in the center of the idler pulley? It should, otherwise, the belt is not aligned. You can also try this when the new belt is in: take a look at the belt and compare the section before the SC pulley to the section after the SC pulley and see if the sections of belt overlap each other. Mine is still off by a rib.
when you go down to a smaller pulley, belt alignment issue may become more noticible, because larger pulley has more surface area to contact with the belt. More contact surface area = better grip to the belt.
They couldnt get the SC off the bracket because the hex bolts are loctited?? Be careful with those bolts, it's very easy to strip them. Several members here use anti-seize on the bolts instead of loctite. If your shop had a hard time dealing with the bolts, ask them to heat up the bracket a little bit and then tap the bolts with a hammer. maxxboost00 used this method to take the blower off for pulley swap. Credit: Jay25.
still in Wyoming?
still in Wyoming?
Originally posted by [maxi-overdose]
Hi Tan:
still in Wyoming?
Hi Tan:
still in Wyoming?
I'm kind of nervous about the pulley swap because there's only one tuner shop that I know of in town and they've never worked on a Vortech\Stillen SC before. I'll have to tell them about the plate grinding, alignment, etc, but I don't want to step on their toes. First try, and they think it's only going to take 4 hours for $200. I hope they can do it that quick and reliably. I have to drive long distances for work, so I'd hate to shred a belt on a long empty highway.
Thanks for the suggestions about the belt alignment and removing the bolts from the bracket. Talk to you later,
Tan
Originally posted by BlackCat
They couldn't get it off? That's weird! I couldn't do it by hand so I got a local garage to use an air tool to loosen the bolts that held the blower to the plate. I supplied the bits.
The blower unit is directly attached to the engine block. Is it possible that the mounting plate is a bit loose?
05' MaximaMan
10-08-2017 06:36 PM
