HID break in period
HID break in period
I had the hanabi hid kit for my 98 max (7 months)and I was wondering if there is a break in period for the bulbs. I have the blue bulb kit and I was driving around today thinking if they are as bright as it gets? deezo, njmaxseltd, 1hotmax??? any ideas??? Btw, does my sig picture look stupid?
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
Hmm, I don't know about any break in period. Freddie never said anything about that. Is the hanabi's getting dimmer for you? I have had mine for about 2 months now and it is as bright as I first turned them on.
Re: HID break in period
I have had my kit for about 3 months now, since the first day i got the kit i had 2 different blues. It really ****** me off! I went back to Freddie and we changed both bulbs and they are still 2 different colors, even after 3 months. I am thinking about selling the kit honeslty.
I've had mine for a few months and they're fine. Sometimes when I turn mine on cold, the bulbs are a tad uneven (color/intensity) but give it a few minutes and they even up.
Originally posted by njmaxseltd
I think 30 hours of use was the burn in time for HID bulbs.
I love flashing my HID"s!!
Its so fun on my 2k2, i wonder how many times it takes before they blow!!
It seems nissan designed my car so i can flash them at will!! (headlights off, flash to pass on)..
So if nissan gave me the future i will continue to do it!!
ED
ED
I have the Hanabi's from Freddie, the 6500k set. I installed this last Thursday, and have been using them constantly to burn in the bulbs. However, the color of the bulbs do not match. One bulb is a blue color, the other is a white color. Its kind of embarrassing. I called Freddie and he tells me to give it a week to see if the colors even out.
So my question is, do the colors ever even out? I mean, my bulbs are VERY noticeably different color.
Ant
There is
If you look it up, there is a break in period. After being broken in, your lights will be slightly brighter and have slightly less colour. The break in period varies for differing manufacturers according to the manufacturers. As for my Volvo, about 4-5 months after I installed Philips on it, I noticed a slight increase in brightness and change in colour. This was before I knew about the break in period. I figured something was wrong and that I should try to figure it out. After doing some research, I found out about the break in period.
Re: There is
Re: Re: There is
Originally posted by costcowholesale
if they are slightly off now (color wise, one is like blue/white the other one is white only) do you think they'll match if I give it more time? mine has only been on for less than 10 hours.
Re: Re: Re: There is
If colouration is not balanced, it's because of low quality bulbs. Sorry, but colour change will most likely not balance out.
when I'm a few inch of someone's bumper i can see one light whiter than the other one. They're osram D2R bulbs.
Re: Re: Re: Re: There is
they don't look that off http://www.pbase.com/image/8501769
Re: Re: Re: Re: Re: There is
Osram huh? What are the rest of the component manufacturers?
Re: Re: Re: Re: Re: Re: There is
What you might want to try is switching left and right bulbs and seeing if the colour difference persists. If they do, try a warranty replacement.
Re: Re: Re: Re: Re: Re: Re: There is
That's odd because I've always thought of Osram as a good company. Personally, I'm a Philips fan. I won't buy any HID components unless they are made by Philips, although I also hold high opinions of Osram and Sylvania (btw, some of these companies are actually the same as a result of some buy overs, although I can't remember which are which). BTW, are you sure the bulbs are Osram? You can see the Osram on the ballast, but are you sure about the bulbs? And hopefully, the ballasts are genuine Osram.
Re: Re: Re: Re: Re: Re: Re: Re: There is
the bulb's case doesn't say osram but it is etched onto the black plastic of the bulb. I don't really mine, they're not that noticable but I'm just wondering if they'll match if I use them more.
Re: Re: Re: Re: Re: Re: Re: Re: Re: There is
If you don't really mind, then that's fine. There is the possibility that they will eventually match up after break in. But I've been involved with many halogen to HID upgrades now (over 20 of my friends and friends of friends) that I have helped install, and of all of them, they either matched up from the very beginning and stayed matched up, or they didn't match up and never matched up. Then again, you may get lucky and they will.
maybe next year i can pick some 6000k bulb up?
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: There is
where they off a lot? the ones that didn't match... or do they look like mine? mine is only a little off.
All I can say is, if you don't mind, leave it alone. If you do mind, get a warranty claim.
As for 6000K bulbs, I wouldn't bother. I personally believe in ONLY using kits that the manufacturer pairs together, i.e. if switching bulbs, I would switch to the recommended ballast by the manufacturer. So if you want to switch bulbs, I would contact Osram first to enquire as to the compatability of the bulbs you want to use with the ballasts you have.
BTW, when I think about your situation, assuming you have high quality Osram parts throughout, the only reason I can think of that the colours don't match is that one of the bulbs is used. As bulbs break in, they are very non-coloured at first. At the end of the break in period, they are as white as they are ever going to get. After that, they tend to colour more and more until they burn out.
Mine are way off. One is Acura TL HID color (a whitish yellow) and the other is an Audi HID blue (you know the purplish blue). I will be contacting Freddie for replacements soon.
The Frye
09-02-2021 11:03 AM
MaxLife17
06-27-2019 01:37 PM
Need help
23
10-02-2015 08:56 AM
