Lite Glow Neon Rods
Maxima owner since 2000
Lite Glow Neon Rods
so i'm walking around target and i notice that they sell the 10'' rods. they come standard with a cigarette adapter plug. my question is, if i want to put a rod under the driver's dash and one under the passenger's dash, how do i go about connecting both of them to the cigarette adapter?
Re: Lite Glow Neon Rods
Somewhere near that section in the store, you'll probably find an adapter for the cigarette lighter, that'll make another 3 adapters, kinda like a power bar does to the ac adapter in your house. So, you'll plug in the adapter, then you can plug up to three things using your cigarette lighter... it might be kinda clumsy on the dash, but that's one solution.
-Phantom
-Phantom
Wal-Mart has the same ones for only $10...You can thank me later. Anyways, just cut the wires on the neon and wire them directly to the battery,fuse box, whatever, then put a switch between the power or ground, your choice, and forget about the cigarette adapters. It will take more time, but will look great!
Rob
Rob
street-glow
Originally posted by euromaxima
i put neons under my seats and wired them together to the battery hen run your ground and to a switch. looks sweet at night
I got my 15" street glow neon blue accent tube today, and i was testing out the looks of it still plugged into the lighter.....and the best was under the glove compartment on the passenger side & probably under pedals(but i got indiglo pedals already) ..... I tried the under the seat thing....but it didn't look too good cuz it wasn't bright enough...the seat carpeting and stuff covered most of the light.
I'm also getting in the street-glow neon blue wires 10ft ..... im gonna see what i can do with that too.
but defintely take the wires out of the cig adapter and rewire them...i suggest the tail light on yer fuse block....that way it only turns on when u turn on lights in yer car (meaning its night)
good luck.
i understand what you guys are saying, but the only problem is... i'm not really sure how to do all that. which parts do i buy and where can i get them? is there a place where i can get written instructions?
Re: street-glow
good luck.
good luck.
Rob
Rob
Help me on this..
If I tap it to the cig light, it will always be on right? Unless I put a switch in between. I dont want to install a switch, but I want the neons to turn on when I turn the head lights on, so should I wire it to the fuse box? If I do, its the fuse box thats above the break pedal right? Sorry, I'm a newbie to the fuse box area.. Some step by step would be very helpful. Thanks.
Hahaha Target, I work there. Anyway, just wire one wire to power and the other to ground, make sure u ground though. If you hve any q's email me at homerbaffoon@aol.com
Originally posted by Max4Good
I know this is kinda outdated thread but I'm looking to see how I can put neons under the dash(footrest). I'm either going to cut the neon wire and connect them to either fuse box, or cig light.
Help me on this..
Help me on this..
Originally posted by aznsap
ya, i jus did this. it's pretty easy. this is what i did. i picked up a switch from radio shack, and wired a power from my cigarette lighter FUSE to the switch, and the power from the neons (which goes to a transformer thing, and then splits off into the 2 neons in mah driver and passenger side footwells). this way, i can jus flip the switch to turn on mah neons, but mah key has to be turned at least to the ACC position. also you have to wire the ground wire. I used the same ground as mah indiglo gauges. I dropped the steering column down, and there's a screw in the bak behind the gauge cluster that werks. i knew that was a good ground cuz thas what mah indiglo gauges were grounded to, so i didnt' bother lookin newhere else, but u can try to find another one. hope this helps.
haha I bought one of those last year from Walmart for 10 bucks too. Cool thing about it was it was sound sensative so u can either switch to stay continuously on or have it light up to sound... it was pretty damn cool, it still in my celica
http://www.radioshack.com/product.as...5Fid=275%2D730
great help guys, thx
actually, using a switch isnt a bad idea. I'll turn it on only when i want to. Could one of these switches from radioshack work? If so, how can i use these fellas...
i have 2 blue 15" neon rods under the dash (driver side and passanger side) i spliced them in to the wires for the cigerete ligter and on a switch because its illegal to have them in your car so when i get pulled over i can just turn them off
97BLKMAXSE
97BLKMAXSE
97BLKMAXSE
97BLKMAXSE
when you spliced the wires to the cig lig, if dont mind, how did you do it? Did you open up the bose deck cover and took out the cig lig? steps on how you did this would definately help..
97BLKMAXSE
ya, im pretty sure any switch will work. i have a small silver colored lever, and i just hooked it up to my fuse box cover, so it's hidden, but i can switch it on/off easily. okay, to wire to the fuse, this is what i did. you have to cut the wire and have a little bit of wire exposed at the end, an 1/2" or so. just pull out the fuse and wrap the wire around one of the metal contacts, and jam the fuse back in (i used cigarette lighter fuse btw). this will be your source of power. then run this wire to your switch, which should have at least 2 prongs sticking out. wire it to one of the prongs, and the other prong will have a wire running power directly to your neons. make sure when u wire to the switch, the 2 wires don't touch. be generous with the electrical tape. feel free to ask any more questions.
However, I'm tempted to try the fuse box jamming option.. Sounds very easy. However, I'm going to need a professional help on this: Will it be safe to hook up 2 10" neon tubes to it? Like not burn any wires or set my car on fire... I'm thinking of combining the + wires of the two neon tubes, same for - wires, and jam the combined + wire to the cig lig fuse hole and ground the combined - wire to any metal surface. Correct me if i'm doing something wrong. Oh yea, I will probably attach a switch also..
knight_yyz
11-01-2015 01:34 PM
zzznightmarezz
09-21-2015 06:32 PM
