Re: Climate Control
Re: Climate Control
climate control . i have an manual climate control on my 95 se. and i want to change it to auto climate control. can i just replace the controler? or is there a simple way to do it? cause my manual fan **** is busted anyways. it doesn't light up and it only works when i turn on the 4th speed. e-mail me at gotrize168@aol.com if u can help me out. i would appreciate. thank you!
Re: Re: Climate Control
- The in-vehicle sensor, attached to the A/C control finisher.
- The ambient sensor, attached to the radiator core support.
- The sunload sensor, located on the right defroster grille.
- The intake sensor, located on the cooling unit housing.
I believe this conversion is possible but costly and probably not worth the effort. To judge by past posts on this forum, the automatic climate control is more failure-prone than the manual type and replacement parts are expensive.
tarun900
19
12-20-2021 06:57 PM
tseng1023
10-15-2015 08:30 AM
RealityCheck
10-02-2015 06:34 PM
DC_Juggernaut
09-28-2015 04:07 PM
