OSCAI Question?
Originally posted by 2001SE
Will any dirt and other crap get in the tube/shopvac causing the air filter to get more dirty which means you'll have to replace it more oftenly?
Seriously, if you keep the tube inside the splash guard, you probably won't get much more dirt that you would through the stock air scoop. If you place the tube outside the splash guard, however, you'll probably end up ingesting more dirt.
UMD_MaxSE has the right idea. Just check your K&N panel filter regularly for signs of excessive dirt buildup and clean it as necessary.
How did you guys stick it out? Did you use the shopvac kind, thanks for the info guys
Originally posted by nc00max
On the other hand it doesn't look as nice as a shop vac tube, but I preferred the functionality to looks seeing as how it's difficult to see anyways.
hehehe...the OSCAI is not known for its looks....
Actually though, I had my filter out just the other day and it ins't any dirtier than normal. It doesn't appear that I'm taking in too much cr@p at all... which is very suprising living here in AZ with all of the dust, dirt and construction going on here (as you have already experienced).
Unclejunebug
04-02-2016 05:42 AM
Stagnet04
10-11-2015 08:16 PM
