Which Clutch should I Get???
Are you going to heavily mod your engine? If not, then an OEM clutch will be more than sufficient. but be sure NOT to get the "Key Value" kit. it's crap. get the good OEM clutch parts, and they'll last you another 10 years.
Well, I plan on doing every mod that I can. I want something that will hold with a 100 shot of NOS or Turbo,
and since I have the turbo and the exaust manifolds I plan on using them when I can afford the rust or the parts I need. Will the centerforce Dual Friction hold that kind of power?
Originally posted by Matt93GXE
the centerforce might, but I would recommend the ACT clutch instead. it's quite a bit heavier and will withstand just about anything short of 400hp.
(from what I hear)
(from what I hear)
Centerforce make 2 clutches for the Max Stage 1 And the dual friction. The stage 1 will hold 30% more than stock and the dual friction will hold 90% more.
Stage 1 $212.31
Dual Friction $289.09
Prices are at NOPI
You will also need a new release bearing
Stage 1 $212.31
Prices are at NOPI
hez8813
03-12-2020 12:06 AM
spencerwh1
06-30-2016 05:44 AM
carlosvq30
09-26-2015 09:44 AM
