Is $243.60 a good price for a clutch shipped?
Is $243.60 a good price for a clutch shipped? it's from courtesy nissan it is the non key value one, it includes th cluth, pressure plate, throwout bearing, and the clutch alignment tool. all shipped to my house for $243.60. Where else is there a better deal if this isnt?
- thanks
- thanks
Originally Posted by Terran
unless your doing it yourself I would think you probably don't need the alignment tool right?
please let me know if i am getting ripped off on buying this clutch
its not a horrible deal, but if you look around you can get others much cheaper, depending on what you are after. I picked up an Exedy (part # 06044) for $140 shipped, including pressure plate, friction disc, throwout bearing, and alignment tool. The pedal feels quite a bit lighter than the stock one, but it grabs great.
Okay, explain this to me.....is the Exedy better than the OEM. Right now, my cluch is slipping in the higher gears and my clutch is sooooooooooo HARD. Like my left calf is twice as big as my right. Chickan, when you said "lighter than the stock one" did you mean the clutch pedal itself was light to press down? In addition, where can I get an Exedy clutch for a cheap price. When replacing the clutch, what else do i need to replace (i.e. presure plate.....)
THanks a lot for your input guys
MAXSE5SPD
08-23-2015 12:06 PM
