Transmission!!! need hELP!! MANUAL SWAP
I think it is time for a manual swap because I think my auto is going to die!!!! I'm SO ****ED!!!!!!Well I'm not sure if it is the tranny, but I'm almost certain it is. Here is the problem, when i give the car gas it seems as if the trans is slipping, because the cars rpm's rise but it is not going as fast as it normal does. If i floor it the rpms will rise then drop and then finally start going somewhere. So my question is how much it it for a 00 gxe to go from auto to manual. All the parts and labor what am i looking at for the price? I found this tranny on ebay http://cgi.ebay.com/ebaymotors/ws/eB..............BTW I think is becasue of that drop resistor mod. I know it did more harm than good.
Originally Posted by andrew3616
man im right at 60k do you think theyll still do it. BTW how much for a manual swap?
I dont know how much a conv. is.
Manual conversion will run anywhere from 1500-3000 depending on the cost of the tranny whether you get a standard or LSD tranny, then aftermarket flywheel, heavy duty clutch, all these things add cost. Then the cost of labor. Labor on this conversion runs 900-1000 for it.
Im doing the whole setup myself, and Ive got a custom lsd, fidanza flywheel, spec stageii kevlar clutch, custom lines, and the whole setup is running me about 2000 not to mention im doing the whole thing myself.
Dixit
Dixit
Dixit
Dixit
custom lines? just bending lines from the Master Cylinder to the Slave Cylinder?
The stereo wont matter to them. The intake and stuff will.
Dixit
Dixit
Dixit
sctludwig
09-01-2022 01:32 PM
hez8813
03-12-2020 12:06 AM
The Wizard
24
10-01-2015 08:47 PM
