front strut tower bar installaation prob
i just boughta a front strut tower bar and when i try to put the right brace on i cant put it down flat because theres a bump there and i bolt cant be put on and i cant close the hood, i have some pics to show you the bump.
right side
[IMG]javascript:ShowImage('/member_pages/show_image.pl?migration=1&image=http://images.cardomain.com/member_images/11/web/443000-443999/443186_1_full.jpg', 575, 431)[/IMG]
left side( the side with no problems)
javascript:ShowImage('/member_pages/show_image.pl?migration=1&image=http://images.cardomain.com/member_images/11/web/443000-443999/443186_2_full.jpg', 575, 431)
right side
wrong links
right side( the side with the problem)
[IMG]javascript:ShowImage('http://www.cardomain.com/member_pages/show_image.pl?migration=1&image=http://images.cardomain.com/member_images/11/web/443000-443999/443186_1_full.jpg', 575, 431)[/IMG]
[IMG]javascript:ShowImage('http://www.cardomain.com/member_pages/show_image.pl?migration=1&image=http://images.cardomain.com/member_images/11/web/443000-443999/443186_2_full.jpg', 575, 431)[/IMG]
follow these EXACT instructions - https://maxima.org/shoptalk/sub_modi...rs/index.shtml
did u try to put that plate on the other side?
more howto's can be found in teh 4thgen How-To section, link can be found in my sig
the right side plate wont lay down straight cause of the groove thats next to the handle if you can see it, i cant use the other plate and flip it around cause then it would get in the way of that bottle on top
Originally Posted by XoPtOn
if som1 had a 199 9maxima gle and had a close pic of there strut bar, it would help alot
Congratulations! You bought a bar that only fits 95-98. Now you have 2 choices:
1. Cut off that nub that does absolutely nothing.
2. Buy a bar that can fit on a 99 (that's what I did)
Or also you might have overlooked the fact that when you remove those nuts, you can slip that little "wing" section on the bar under that nub and it all fits.
this is the strut bar i bought http://cgi.ebay.com/ebaymotors/ws/eB...tem=2435035298
k u were right i found out you have to cut a peice of it, if any1 wants the web site its here http://home.earthlink.net/~maxfaq/stb/
lowpost99
05-16-2021 11:18 AM
Maxima30
09-07-2015 06:13 PM
