just want to confirm ?'s about installing oem 95 fog lights to gxe
Old 09-25-2003, 06:26 PM
Custom User Title...
Jepht20's Avatar
i searched and there were tons of threads but i'm just trying to confirm from you guys directly that i'll be all set. got good condition fogs for $105 shipped, got the light stalk for $10 at a junkyard, hopefully getting the mounting brackets for $30 shipped from another member(waiting on that). is that all i need or is there anything else? do i really need a relay? is there a cutout that comes in the kit someone could scan and send me? i just want it to go smoothly when i do the install. i'm not worried about the headlight/foglight stalk swap cuz i've done that before with the intermittent wipers. the only thing i'm not 100% on is cutting the holes and such.
so if you guys could leave me some good words of advice and such, i'd appreciate it greatly. thanx!
Jepht20 is offline
Old 09-25-2003, 06:42 PM
Jedi Knight
nupe500's Avatar
u first need to make sure you have the comfort package...if you do its basically plug and play and you might need a relay to put in the foglight spot under the hood...but that should be it. Good luck
nupe500 is offline
Old 09-27-2003, 08:55 AM
Jepht20's Avatar
i don't believe i have the comfort package. however, when i looked the other day i saw orange (plugs/clips/harnesses - whatever you'd call them) that i'm pretty sure are for fogs. any idea where to get the relay and what to look for? thanx!
Jepht20 is offline
Old 09-27-2003, 11:47 AM
Jedi Knight
nupe500's Avatar
hopefully someone might have a relay sitting around...I'll check and let you know...but the other stuff...a junk yard might be your best option
nupe500 is offline
Old 09-27-2003, 03:01 PM
Jepht20's Avatar
is this where the relay i need goes? anyone know how much that part goes for? maybe i'll go back to the junkyard and try to get it unless someone advises otherwise
Jepht20 is offline
Old 09-27-2003, 03:03 PM
Jedi Knight
nupe500's Avatar
that is exactly where the relay goes...dunno how much they go for...but I might have a spare one...I'll check tomorrow and let you know.
O
nupe500 is offline
Old 09-27-2003, 03:23 PM
Jepht20's Avatar
thanx man! i appreciate you helping me out and responding
Jepht20 is offline
Old 10-01-2003, 11:49 AM
Jepht20's Avatar
well i got the relay from a junkyard for $5. should be getting my mounting brackets friday. anyone have advice on cutting the holes??? i think i'm gonna use a dremel. do you guys think i should put the car up on ramps? that might make it easier to do. also, can anyone tell me about the plastic shielding on the bottum of the car...mine sticks out in one spot and i figured out that it is just bent funny and can be fixed, but can they all be removed easily or do you have to be careful when taking out those screws. thanx
Jepht20 is offline
Old 10-01-2003, 02:30 PM
UncleMax98's Avatar
Before you do any cutting, maybe you can install the stalk first to make sure the car is prewired for fog. There is a plug in the steering that plugs into the new stalk. Also, check to see if the plug under the front bumper really plugs into the fog light. I saw in the instruction sheet that the car needs the comfort and convenience package.
UncleMax98 is offline
Old 10-01-2003, 02:51 PM
ivelweyz
There should be a few spare ones in the fuse boxes. I had 2 or 3 when I did my light rewiring...
Old 10-01-2003, 05:17 PM
Jepht20's Avatar
that's a good call, i was gonna do that soon to get it over with anyways so that'll be a good way to double check. i can't imagine what else those plugs go into cuz they're right where they'd need to be, but you never know. i'll do that tomorrow and then post results.
Jepht20 is offline
Old 10-01-2003, 05:32 PM
ch13f's Avatar
Not to hijack.. hopefully, but does anyone know if the fog light kits that dealerships sell such as the one listed on this page, http://www.nissandealer.com/jerry-rome/part_catalog.cgi include absolutly everything? including the wiring and headlight stalk for those of us who have a totally base model GXE? I've been wanting some fog lights but unfortunatly I do not have the C&C package, so it might be a bit more difficult to install them.
ch13f is offline
Old 10-01-2003, 11:47 PM
UncleMax98's Avatar
I got the fog light kit from ABC Nissan and it came with everything. Stalk, relay, fuse, brackets, bolts, fog lights (of course!), instructions, etc. Mine is a 98 + C&C package so the installation was very easy. Bumper already has the cut-out from the factory.
Old 10-05-2003, 10:53 AM
Jepht20's Avatar
crap ballz! i'm an idiot. the damn plug wasn't for foglights and you were all right like you said now i don't know what to do. stupid nissan having all these random plugs fooling me. i wish i just bought a max with all this stuff stock. now i have fogs that i can't use unless i wire them myself and i don't know how to do that. crap
Jepht20 is offline
vingodine
45
05-21-2016 12:46 PM
EuroDriver
09-14-2015 06:08 PM
Viralkill
08-17-2015 10:54 AM
Viralkill
08-16-2015 05:09 PM
98nismomax
08-13-2015 12:44 PM
Quick Reply: just want to confirm ?'s about installing oem 95 fog lights to gxe
