Brakes!! Need advice
I'm looking to upgrade my brakes, but don't want to spend too much. seeing as the rotors are 75 a piece @ the dealer I was thinking of going with crossdrilled or slotted, will it improve the braking really or just look good. And what about the pads 70$ for dealership whatcan I get to go with my upgraded rotors?
By the way HI I'm new to the forum I'm Velcro I have a 97 max with 130k running good since I bought her but she's starting to need some work and I need advise
Cross drilled is just mainly for looks.
Slotted is actually functional in two ways --
1. If you are really hard on your brakes (like driving down a mountain hill really fast), the slots actually help the gasses that build up between the pad and rotor to escape to keep your brakes from fading. Cross drilled also does that as well but slotted rotors are mechanically more robust. For just cruising the streets, you won't notice this advantage.
2. The slots help to deglaze the pads and continously wipe off any dust buildups and keep contaminants from making grooves into the rotor face. This would by far be the most significant contribution for the slots. Its basically a nice preventative measure to keep them in good condition over time but won't actually making your braking any faster in most street conditions.
Get some stainless steel brake lines too. That will take up the mushy slack that is in your brake pedal. It won't actually make you stop faster, but makes the pedal feel much better.
A set of performance brake pads would grant you some better braking performance at the expense of faster brake pad wear. But you can only stop as fast for as much traction as you have in the tires.
www.tirerack.com has some nice Maxima brake parts. The got Brembo rotors that are OEM size and look nice (no rusty rotor look). They have an OEM size slotted front brake rotor as well as plain front rotors. Their rear rotors are solid.
Re: Brakes!! Need advice
BPuff57
04-16-2020 05:15 AM
HerpDerp1919
09-29-2015 02:02 PM
