vibrating...(read)
Old 01-07-2003, 07:53 PM
A5295's Avatar
vibrating...(update)
gut a problem, i have a vibration/sound that i cannot figure out. It changes with speed, but comes more pronounced when braking hard. i have haeard nothing from the cv shafts/joints, but i am not the biggest expert on cv shafts or cars for that matter. this feels almost like a flat spotted tire, but i can feel it in my steering wheel. becomes more pronounced as road conditions get worse. Ita also feels like maybe a rubbing or possibly like a wheel vibrating- could it be more of a wheel bearing or a tire out of balance?? Dunno. Its a little hard to explain, but would someone please help me? ANother thing-i can take out of gear and it still persists, so if that helps any let me know.
Thanks so much
Mike
A5295 is offline
Old 01-07-2003, 09:18 PM
iansw's Avatar
Re: vibrating...(read)
Thanks so much
Mike
Hmm, I have what I think is a inboard CV Joint going bad.
The typical symptoms of this are:
No "click" when turning right/left - this would be an outboard joint,
not inboard
Vibration at freeway speeds - mostly when braking/accellerating, but can be at all times
Personally, I only feel mine above 50 and when braking/accellerating, but apparently it can be when out of gear/coasting also
This may be your problem. Try moving your rear tires to the front and seeing if the vibration changes - could be a bent rim, could be a flat spot on the tire.....
If not, then it's most likely either your rotots (cost $5-10 each to have your local Autozone check them out and resurface/turn them)
From there, it's probably a CV Joint.
IanS
iansw is offline
Old 01-07-2003, 09:37 PM
A5295's Avatar
is there anyway to see if the rotor needs turning without removing it??? why would the inboard go bad first?? i hope the front tires are not flat spotted- they are about two weeks old. if the flat-spotted tire was on the back would i feel it in the steering wheel or hear it like i do? would having different size tires on the back make it more pronounced, or cause the problem?? i have 215/60's on the back-those horrible pirellis. I have nitto nt 450's in a 215/55 on the front.
Peace,
Mike
A5295 is offline
Old 01-07-2003, 09:56 PM
sharkulator's Avatar
Check your tires. I had that problem and I went to discount tire thinking something was wrong. There was a lump the size of a titty on my tire. It caused a bad vibration when driving. Try the easiest thing to check first (visual inspection of tire) then move on to the more complicated stuff.
sharkulator is offline
Old 01-11-2003, 11:34 AM
A5295's Avatar
thanks so much for your help and insight on this. i found a bad flat spot on my rr tire...i also have a cv boot that is split and has slung grease everywhere! would u guys just replace the boot, or wait and just replace the shaft?
Thanks,
mike
A5295 is offline
Old 01-11-2003, 01:32 PM
iansw's Avatar
Thanks,
mike
It doesn't cost awhole lot more just to replace the axle. It's about $150+shipping from raxles.com...it's only 7 beolts, and is easy to do yourself with a friend.
Marti there is on heck of a nice guy....
IanS
iansw is offline
mclasser
22
11-12-2020 01:58 PM
chisam14
11-06-2018 08:56 PM
mkaresh
03-12-2018 06:48 PM
maxinout93
10-31-2015 02:04 AM
Quick Reply: vibrating...(read)
